Text-to-Speech API
The speech synthesis endpoint accepts text and uses a speech synthesis model running on the device to generate an audio file. This example uses a MeloTTS model package for the AX630C platform.
Preparation
Before calling the endpoint, install the speech synthesis model and tools required by the example. Refer to the model library for platform support.
Tip
AI Pyramid provides a dedicated text-to-speech solution with voice cloning. For details, please refer to the CosyVoice section.
Before running this example program, please ensure that the following preparations have been completed on the LLM device:
  1. Use the apt package manager to install the llm-model-melotts-en-us model package.
apt install llm-model-melotts-en-us
  1. Install the ffmpeg tool.
apt install ffmpeg
  1. After installation, restart the OpenAI service to make the new model take effect.
systemctl restart llm-openai-api
Example Program
On the PC side, use the OpenAI API to pass text information to implement the text-to-speech function. Before running the example program, modify the IP part of base_url below to the actual IP address of the device.
from pathlib import Path
from openai import OpenAI
client = OpenAI(
    api_key="sk-",
    base_url="http://192.168.20.186:8000/v1"
speech_file_path = Path(__file__).parent / "speech.mp3"
with client.audio.speech.with_streaming_response.create(
  model="melotts-en-us",
  voice="alloy",
  input="The quick brown fox jumped over the lazy dog."
) as response:
  response.stream_to_file(speech_file_path)
Request Parameters
Parameter Name Type Required Example Value Description
input string Yes "Hello, welcome to the system" Text content to generate audio from, with a maximum length of 1024 characters
model string Yes melotts-zh-cn Available TTS models include melotts-ja-jp, melotts-zh-cn, melotts-en-us, etc.
voice - No - The MeloTTS model does not support voice style selection
response_format string No mp3 Audio output format, supports mp3, opus, aac, flac, wav, pcm, etc.
speed number No 1.0 Speech generation speed, range 0.25 ~ 2.0, default value is 1.0
Response Example
  • The generated audio file data will be stored in the speech_file_path path defined in the example program.
