Offline Voice Recognition
Input Device
DIP Switch Usage Guide
Module GPS v2.0
Module GNSS
Module ExtPort For Core2
Module LoRa868 V1.2
Module ExtPort For Core2 DIP Switch Explanation Document
1. Overview
To avoid complications, the Module ExtPort For Core2 module uses DIP switches to flexibly switch the connection of key pins. Users can adjust the corresponding Grove pin configuration according to their needs.
拨码开关示意图拨码开关示意图
2. DIP Switch Position and Pin Mapping
2.1 DIP Switch Position
The DIP switch is located in the specified position on the module, as shown in the image below:
Module AppearanceDIP Switch Partial
As shown in the image, the DIP switch is used to switch the signal pins of two Grove ports (Port D and Port E). The pin sequence for Port D and Port E is VDD GND PortD2 PortD1 and VDD GND PortE2 PortE1.
2.2 Pin Mapping Table
The available pin mappings for different hosts are as follows:
CORE2
PortD1 G34
G22
G3
PortD2 G35
G21
G1
PortE1 G27
G2
G0
PortE2 G19
G25
G2
Note:
  • PortD1, PortD2, PortE1, PortE2 can all be selected using the DIP switch to connect to specific pins. For example, on the Core2 host:
    • PortD1: can be selected as G34, G22, or G3 (three options)
    • PortD2: can be selected as G35, G21, or G1 (three options)
    • PortE1: can be selected as G27, G2, or G0 (three options)
    • PortE2: can be selected as G19, G25, or G2 (three options)
3. DIP Switch Adjustment Procedure
Please follow these steps to adjust the DIP switch configuration:
  1. Power Off Operation
    Before adjusting the DIP switch, ensure that the module is completely powered off to avoid hardware damage.
  2. Set the DIP Switch
    Select the corresponding pin mapping based on the host you are using.
DIP Switch Setting Diagram 1
As shown in the image above, the DIP switch is set as follows: (Core2 + Module ExtPort For Core2)
PortD1 → G34
PortD2 → G35
PortE1 → G27
PortE2 → G19
  1. Rewire and Power On
    After completing the DIP switch settings, reconnect the module and power it on for subsequent use.
