Real-Time AI Voice Assistant
AtomS3R-M12 Volcengine Kit
Offline Voice Recognition
DIP Switch Usage Guide
Module GPS v2.0
Module GNSS
Module ExtPort For Core2
Module LoRa868 V1.2
M5StickC-Plus Factory Firmware
Factory Firmware
If the device encounters operational issues, you can try re-burning the factory firmware to check for hardware faults. Refer to the following guide. Use the M5Burner firmware burning tool to burn the factory firmware onto the device.
2. USB Driver Installation
Baud Rate Limit
When performing the device program download operation, it is recommended to select the following serial port baud rate options. If other speeds are used, it may result in the program being unable to be downloaded properly.
1500000 bps / 750000 bps / 500000 bps / 250000 bps / 115200 bps
Driver Installation Tips
Connect the device to the PC and open the Device Manager to install the FTDI driver. Take Windows 10 as an example: download the driver file matching your operating system, extract it, and install it through the Device Manager. (Note: In some system environments, the driver may need to be installed twice to take effect. Unrecognized device names are usually M5Stack or USB Serial. It is recommended to use the driver file for direct installation via the Device Manager (custom update) on Windows, as the executable installation method may not work properly.) Click here to download the FTDI driver.
For MacOS users, before installation, check System Preferences -> Security & Privacy -> General -> Allow apps downloaded from -> App Store and identified developers.
3. Port Selection
Connect the device to the computer via USB cable. After completing the driver installation, the corresponding device port can be selected in M5Burner.
4. Firmware Burning
Click "Burn" to start burning.
The result is as shown below:
