Real-Time AI Voice Assistant
Offline Voice Recognition
Thread
Module Gateway H2
IoT Cloud
DIP Switch Usage Guide
Module GPS v2.0
Module GNSS
Module ExtPort For Core2
Unit PoE CAM-W v1.1 User Guide
This tutorial demonstrates how to flash the Web Camera firmware for the Unit PoE CAM-W v1.1 and achieve real-time image preview on a LAN webpage. This tutorial is applicable to Unit PoE CAM / Unit PoE CAM-W / Unit PoE CAM-W v1.1 devices.
1. Preparations
    1. Follow the M5Burner Tutorial to download the flashing tool, and refer to the image below to download the corresponding firmware.
2. Firmware Flashing
Using the adapter board provided with the ESP32 Downloader , connect to the programming download interface reserved on the Unit PoE CAM-W v1.1. Follow the steps below to flash the firmware.
3. Obtaining the Device IP
Power Supply
The Unit PoE CAM-W v1.1 can be powered through a 5V supply via the Grove interface or directly via the PoE switch Ethernet cable. When the device's network LED is flashing, it indicates that the network is working properly.
Using M5Burner or another serial tool, reset the device and check its IP address.
4. Real-Time Image Preview
Within the same local network, you can retrieve the device image in real time via the following URLs.
  • Capture URL: 192.168.xxx.xxx
  • Stream URL: 192.168.xxx.xxx/stream
Press the side button on the device to switch the image resolution.
