Input & Output Devices
Audio Playback Devices
Module GPS v2.0 DIP Switch Instruction Manual
1. Function Overview
To avoid issues caused by pin conflicts when stacking the Module GPS v2.0 with the host, the module adopts DIP switches to flexibly switch the connections of key pins. Users can adjust the corresponding pin configuration based on the host used (such as Core/Basics, Core2, or CoreS3) to ensure stable system operation.
DIP Switch SchematicDIP Switch SchematicDIP Switch Schematic
2. DIP Switch Position and Pin Mapping
2.1 DIP Switch Position
The DIP switches are located at a designated position on the module, as shown in the following images:
Module AppearanceClose-up of DIP Switch
As shown in the images above, the DIP switches are used to switch the four functional pins: TXD, RXD, PPS
2.2 Pin Mapping Table
For different hosts, the selectable mappings for the key pins are as follows:
CORE CORE2 CORES3
TXD G17 G14 G17
G15 G2 G13
G12 G27 G6
G0 G0 G0
RXD G16 G13 G18
G13 G19 G7
G34 G34 G14
G35 G35 G10
PPS G25 G25 G5
G35 G35 G10
G36 G36 G8
Note:
  • TXD, RXD, PPS can all be selected via the DIP switch to choose the specific connected pin. For example, on a Core (Basic) host:
    • TXD: can be selected as G17, G15, G12, or G0 (four options)
    • RXD: can be selected as G16, G13, G34, or G35 (four options)
    • PPS: can be selected as G25, G35, or G36 (three options)
3. DIP Switch Configuration Operation
Please follow the steps below to adjust the DIP switch configuration:
  1. Power Down Operation
    Before adjusting the DIP switches, please ensure that the module is completely powered off to avoid damaging the hardware.
  2. Set the DIP Switch
    Select the corresponding pin mapping according to the host being used.
DIP Switch Setting Diagram 1
In the diagram above, the DIP switch positions are chosen as:
TXD → G12
RXD → G34
PPS → G25
  1. Reconnect and Power On
    After completing the DIP switch settings, reconnect the module and apply power for further use.
