Input & Output Devices
HID Input Devices
Audio Playback Devices
CLIP
  1. Manually download the model and upload it to raspberrypi5, or pull the model repository with the following command.
Tip
If git lfs is not installed, please first refer to git lfs installation instructions for setup.
git clone https://huggingface.co/AXERA-TECH/LibCLIP
File Description
m5stack@raspberrypi:~/rsp/LibCLIP $ ls -lh
total 157M
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 09:09 cnclip
-rw-rw-r-- 1 m5stack m5stack 156M Aug 11 09:08 coco_1000.tar
-rw-rw-r-- 1 m5stack m5stack 3.8K Aug 11 09:08 config.json
-rw-rw-r-- 1 m5stack m5stack 779K Aug 11 09:08 gradio_01.png
drwxrwxr-x 5 m5stack m5stack 4.0K Aug 11 09:08 install
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 09:08 pyclip
-rw-rw-r-- 1 m5stack m5stack 6.0K Aug 11 09:08 README.md
python -m venv clip
source clip/bin/activate
  1. Install dependencies
pip install -r pyclip/requirements.txt
  1. Set environment variables
export LD_PRELOAD=/usr/lib/
  1. Copy the dynamic library
cp install/lib/aarch64/libclip.so pyclip/
  1. Extract the test images
tar xf coco_1000.tar
  1. Start the web service
python pyclip/gradio_example.py --ienc cnclip/cnclip_vit_l14_336px_vision_u16u8.axmodel --tenc cnclip/cnclip_vit_l14_336px_text_u16.axmodel --vocab cnclip/cn_vocab.txt --isCN 1 --db_path clip_feat_db_coco --image_folder coco_1000/
After successful startup, you will see information similar to the following:
(clip) m5stack@raspberrypi:~/rsp/LibCLIP $ python pyclip/gradio_example.py --ienc cnclip/cnclip_vit_l14_336px_vision_u16u8.axmodel --tenc cnclip/cnclip_vit_l14_336px_text_u16.axmodel --vocab cnclip/cn_vocab.txt --isCN 1 --db_path clip_feat_db_coco --image_folder coco_1000/
Trying to load: /home/m5stack/rsp/LibCLIP/pyclip/aarch64/libclip.so
❌ Failed to load: /home/m5stack/rsp/LibCLIP/pyclip/aarch64/libclip.so
   /home/m5stack/rsp/LibCLIP/pyclip/aarch64/libclip.so: cannot open shared object file: No such file or directory
🔍 File not found. Please verify that libclip.so exists and the path is correct.
Trying to load: /home/m5stack/rsp/LibCLIP/pyclip/libclip.so
open libax_sys.so failed
open libax_engine.so failed
✅ Successfully loaded: /home/m5stack/rsp/LibCLIP/pyclip/libclip.so
Available devices: {'host': {'available': True, 'version': '', 'mem_info': {'remain': 0, 'total': 0}}, 'devices': {'host_version': 'V3.6.3_20250722020142', 'dev_version': 'V3.6.3_20250722020142', 'count': 1, 'devices_info': [{'temp': 62, 'cpu_usage': 1, 'npu_usage': 0, 'mem_info': {'remain': 7022, 'total': 7040}}]}}
[I][                             run][  31]: AXCLWorker start with devid 0
input size: 1
    name:    image [unknown] [unknown]
        1 x 3 x 336 x 336
output size: 1
        1 x 768
[I][              load_image_encoder][  50]: nchw 336 336
[I][              load_image_encoder][  60]: image feature len 768
input size: 1
    name:     text [unknown] [unknown]
        1 x 52
output size: 1
        1 x 768
[I][               load_text_encoder][  44]: text feature len 768
[I][                  load_tokenizer][  60]: text token len 52
100%|███████████████████████████████████| 1000/1000 [00:00<00:00, 163246.95it/s]
* Running on local URL:  http://0.0.0.0:7860
* To create a public link, set `share=True` in `launch()`.
  1. Open http://127.0.0.1:7860 in a browser, enter the desired search content in the text box, and click Search Image.
