Offline Voice Recognition
Input Device
DIP Switch Usage Guide
Module GPS v2.0
Module GNSS
Module ExtPort For Core2
Module LoRa868 V1.2
OpenAI API
We provide a usage method compatible with the OpenAI API, you only need to install the StackFlow package.
Preparation
  1. Refer to RaspberryPi & LLM8850 Software Package Acquisition Tutorial to complete the installation of the following model package and software package.
sudo apt install lib-llm llm-sys llm-llm llm-openai-api
sudo apt install llm-model-qwen3-1.7b-int8-ctx-axcl
Each time a new model is installed, you need to manually execute sudo systemctrl restart llm-openai-api to update the model list.
Curl Call
curl http://127.0.0.1:8000/v1/models \
  -H "Content-Type: application/json"
curl http://127.0.0.1:8000/v1/chat/completions \
  -d '{
    "model": "qwen3-1.7B-Int8-ctx-axcl",
    "messages": [
Python Call
from openai import OpenAI
client = OpenAI(
    api_key="sk-",
client.models.list()
print(client.models.list())
client = OpenAI(
    api_key="sk-",
  model="qwen3-1.7B-Int8-ctx-axcl",
  messages=[
    {"role": "user", "content": "Turn on the light!"}
print(completion.choices[0].message)
ChatBox Call
Get ChatBox
Click settings to add a model provider
Fill the API Host with the RaspberryPi's IP and API path, retrieve and add the installed models
Create a new chat and select the qwen3-1.7B-Int8-ctx-axcl model provided by LLM8850
Modify the maximum context message length to 0
Supports setting System Prompt
