Input & Output Devices
HID Input Devices
Audio Playback Devices
RIFE
RIFE is a real-time video frame interpolation model based on deep learning, capable of efficiently predicting intermediate frames to increase video frame rates. It is used in video smoothness enhancement and animation production.
Tip
If git lfs is not installed, please refer to git lfs installation guide for installation.
git clone https://huggingface.co/AXERA-TECH/RIFE.axera
File Description:
m5stack@raspberrypi:~/rsp/RIFE.axera $ ls -lh
total 52K
-rw-rw-r-- 1 m5stack m5stack 1.1K Sep 29 14:28 build_config.json
-rw-rw-r-- 1 m5stack m5stack    0 Sep 29 14:28 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Sep 29 14:28 model
-rw-rw-r-- 1 m5stack m5stack 6.9K Sep 29 14:28 ms_ssim.py
-rw-rw-r-- 1 m5stack m5stack 1.8K Sep 29 14:28 README.md
-rw-rw-r-- 1 m5stack m5stack   88 Sep 29 14:28 requirements.txt
-rw-rw-r-- 1 m5stack m5stack 9.2K Sep 29 14:28 run_axmodel.py
-rw-rw-r-- 1 m5stack m5stack 9.2K Sep 29 14:28 run_onnx.py
drwxrwxr-x 2 m5stack m5stack 4.0K Sep 29 14:28 video
python -m venv rife
source rife/bin/activate
  1. Install dependencies
  1. Run
python3 run_axmodel.py --model ./model/rife_x2_720p.axmodel --video ./video/demo.mp4
Run result:
(rife) m5stack@raspberrypi:~/rsp/RIFE.axera $ python3 run_axmodel.py --model ./model/rife_x2_720p.axmodel --video ./video/demo.mp4
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 77cdc0c2
./video/demo.mp4, 128.0 frames in total, 25.0FPS to 50.0FPS
The audio will be merged after interpolation process
 99%|██████████████████████████████████████▋| 127/128.0 [02:45<00:01,  1.30s/it]
