Input Device
MixFormerV2
MixFormerV2 is an improved unified Transformer-based object tracking model that enhances tracking accuracy and speed by integrating the feature extraction and matching processes.
  1. Manually download the model and upload it to raspberrypi5, or pull the model repository using the following command:
Tip
If git lfs is not installed, please refer to git lfs installation instructions for installation.
git clone https://huggingface.co/AXERA-TECH/MixFormerV2
File Description:
m5stack@raspberrypi:~/rsp/MixFormerV2 $ ls -lh
total 63M
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 ax630c
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 ax650
-rw-rw-r-- 1 m5stack m5stack  63M Aug 11 18:28 car.avi
-rw-rw-r-- 1 m5stack m5stack    0 Aug 11 18:28 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 onnx
-rw-rw-r-- 1 m5stack m5stack 4.0K Aug 11 18:28 README.md
-rw-rw-r-- 1 m5stack m5stack  15K Aug 11 18:28 run_mixformer2_axmodel.py
-rw-rw-r-- 1 m5stack m5stack  14K Aug 11 18:28 run_mixformer2_onnx.py
python -m venv mixformer
source mixformer/bin/activate
  1. Install dependencies
pip install argparse numpy opencv-python glob2
  1. Run
python3 run_mixformer2_axmodel.py --model-path ax650/mixformer_v2.axmodel --frame-path car.avi -r 10
Example Output:
(mixformer) m5stack@raspberrypi:~/rsp/MixFormerV2 $ python3 run_mixformer2_axmodel.py --model-path ax650/mixformer_v2.axmodel --frame-path car.avi -r 10
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.4-dirty 4ff37520-dirty
====================type================= [1079, 482] <class 'list'> <class 'list'>
First frame initialized!
Video: tracking     1011.0fps
Video: tracking     8.0fps
Reached the maximum number of frames (10). Exiting loop.
video: average finale average tracking fps 121.2 fps
