Offline Voice Recognition
DIP Switch Usage Guide
Module GPS v2.0
Module GNSS
Module ExtPort For Core2
Module LoRa868 V1.2
LLM-8850 Card Hardware Installation
When installing the LLM-8850 accelerator card on a Raspberry Pi 5, you first need to prepare an M.2 HAT+ expansion board. Refer to the official link.
Disconnect power before installation
Be sure to disconnect the Raspberry Pi 5 power before installing the LLM-8850 Card. Do not install while powered on! Use a switching power supply adapter (non-PD protocol) with DC 5V@3A power supply capability. If a PD power supply adapter is used, it may fail to output the maximum power normally due to protocol compatibility issues, which could further cause abnormal device operation.
Installation Steps
  1. Prepare the LLM-8850 Card hardware.
  1. Insert it into the Raspberry Pi 5 M.2 HAT+ expansion board.
  1. Fix it with screws.
