Input & Output Devices
HID Input Devices
Audio Playback Devices
Quick Experience
Model Benchmark
After completing the first two steps, the model benchmarking tool axcl_run_model can be used. This tool has many parameters, which can be viewed with axcl_run_model --help. If you are interested in its implementation mechanism, you can check the source code in the corresponding sample directory. This tool, along with other cv & llm sample, is provided in source code form to help users understand how to use the API.
For example, to test the running speed of a model, use a command like axcl_run_model -m your_model.axmodel -r 10, where -m specifies the model to run, and -r specifies the number of repetitions, allowing for a simple test of the model's speed.
Obtain the model:
wget https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/yolo11s.axmodel
Test:
axcl_run_model -m yolo11s.axmodel -r 10
The execution result is as follows:
m5stack@raspberrypi5:~ $ axcl_run_model -m yolo11s.axmodel -r 10
   Run AxModel:
         model: yolo11s.axmodel
          type: 3 Core
          vnpu: Disable
        warmup: 1
        repeat: 10
         batch: { auto: 1 }
    axclrt ver: 1.0.0
   pulsar2 ver: 3.2 99cf147d
      tool ver: 0.0.1
      cmm size: 10488066 Bytes
  min =   3.391 ms   max =   3.414 ms   avg =   3.402 ms
From the above example, in addition to indicating the model running time, it also shows the toolchain version, model type, and other related information.
CV Example
If the unzip tool is not installed, please install it first with the following command:
sudo apt install zip
  1. Get the Demo:
wget https://m5stack.oss-cn-shenzhen.aliyuncs.com/resource/linux/ax8850_card/cv_demo.zip
  1. Unzip the Demo:
unzip cv_demo.zip
  1. Enter the directory:
cd cv_demo
Classification Model
Using the imagenet dataset’s imagenet_cat.jpg as the classification target, after sample execution, the output will be as follows (note that the model and input image should be adjusted according to the actual situation):
Execution command:
./axcl_sample_classification -m mobilenetv2.axmodel -i cat.jpg
Result:
m5stack@raspberrypi5:~/cv_demo $ ./axcl_sample_classification -m mobilenetv2.axmodel -i cat.jpg
axcl initializing...
axcl inited.
Select axcl device{index: 0} as {1}.
axclrt Engine inited.
model file : mobilenetv2.axmodel
image file : cat.jpg
img height : 224
img width  : 224
282:  9.8%,  tiger cat
285:  9.8%,  Egyptian cat
283:  9.5%,  Persian cat
281:  9.4%,  tabby, tabby cat
463:  7.5%,  bucket, pail
Detection Model
Using the PASCAL VOC dataset’s voc_dog.jpg as the detection target, after sample execution, the output will be as follows (note that the model and input image should be adjusted according to the actual situation):
Execution command:
./axcl_sample_yolov5s -m yolov5s.axmodel -i dog.jpg
Result:
m5stack@raspberrypi5:~/cv_demo $ ./axcl_sample_yolov5s -m yolov5s.axmodel -i dog.jpg
axcl inited.
model file : yolov5s.axmodel
image file : dog.jpg
img height : 640
img width  : 640
post process cost time:0.61 ms
Repeat 1 times, avg time 8.10 ms, max_time 8.10 ms, min_time 8.10 ms
16:  91%, [ 138,  218,  310,  541], dog
 2:  69%, [ 470,   76,  690,  173], car
 1:  56%, [ 158,  120,  569,  420], bicycle
It can be seen that 3 objects were detected and their class ID, confidence, and coordinates were provided. In the sample execution directory, a detection result named yolov5s_out.jpg will be saved, which can be opened with an image viewer to preview the output.
