StackFlow AI Platform
Module LLM Applications
CV Vision Application
Vision Language Model (VLM)
Large Language Model (LLM)
Voice Assistant
AI Pyramid Software Package Updates
The factory image already includes the M5Stack APT repository. If you need to add it manually, refer to the following steps.
wget -qO /etc/apt/keyrings/StackFlow.gpg https://repo.llm.m5stack.com/m5stack-apt-repo/key/StackFlow.gpg
echo 'deb [arch=arm64 signed-by=/etc/apt/keyrings/StackFlow.gpg] https://repo.llm.m5stack.com/m5stack-apt-repo jammy ax650c' > /etc/apt/sources.list.d/StackFlow.list
2. Update Software Sources
Step 1: Update the Package List
Run apt update to update the package list:
apt update
3. Install Software Packages
Step 1: View Available Packages
Check the list of available llm deb packages. Packages named in the llm-model-name format are model packages, while those named llm-name are functional module packages.
apt list | grep llm-
Step 2: Install Required Packages
Install the required packages using the apt command as needed, for example, installing the llm-cosy-voice package. Note: Model packages occupy a relatively large amount of storage space. It is recommended to install them on demand.
apt install llm-cosy-voice
4. Package Description
lib-llm
  • Provides the runtime environment required for software operation.
apt install lib-llm
llm-sys
  • Provides the core services of StackFlow.
apt install llm-sys
5. Functional Module Overview
llm-audio
  • Provides unified sound card management services.
apt install llm-audio
llm-camera
  • Provides unified camera management services.
apt install llm-camera
llm-kws
  • Provides keyword spotting services.
apt install llm-kws
llm-asr
  • Provides speech-to-text services.
apt install llm-asr
llm-llm
  • Provides local large language model (LLM) services.
apt install llm-llm
llm-vlm
  • Provides local multimodal large model (VLM) services.
apt install llm-vlm
llm-melotts
  • Provides text-to-speech (TTS) services.
apt install llm-melotts
llm-cosy-voice
  • Provides voice cloning and text-to-speech services.
llm-openai-api
  • Provides OpenAI-compatible API services for quick access to STT, TTS, and LLM/VLM capabilities.
apt install llm-openai-api
