Input Device
Jina CLIP v2
jina-clip-v2 is a general-purpose multilingual multimodal embedding model for text & images.
Tip
If git lfs is not installed, please refer to git lfs installation guide first.
git clone https://huggingface.co/AXERA-TECH/jina-clip-v2
File Description
(ppocr) m5stack@raspberrypi:~/rsp/jina-clip-v2 $ ls -lh
total 1.7G
-rw-rw-r-- 1 m5stack m5stack  51K Oct 20 12:24 beach1.jpg
-rw-rw-r-- 1 m5stack m5stack    0 Oct 20 12:24 config.json
-rw-rw-r-- 1 m5stack m5stack 351M Oct 20 12:25 image_encoder.axmodel
drwxrwxr-x 2 m5stack m5stack 4.0K Oct 20 12:24 jina-clip-v2
-rw-rw-r-- 1 m5stack m5stack 1.3K Oct 20 12:24 README.md
-rw-rw-r-- 1 m5stack m5stack 3.2K Oct 20 12:24 run_axmodel.py
-rw-rw-r-- 1 m5stack m5stack 1.3G Oct 20 12:26 text_encoder.axmodel
  1. Create virtual environment
python -m venv clip
source clip/bin/activate
  1. Install dependencies
pip install torch pillow transformers timm torchvision
  1. Run
python run_axmodel.py
Execution result:
(clip) m5stack@raspberrypi:~/rsp/jina-clip-v2 $ python3 run_axmodel.py -i beach1.jpg -t "beautiful sunset over the beach" -iax ./image_encoder.axmodel -tax ./text_encoder.axmodel --hf_path ./jina-clip-v2
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 df480136
[INFO] Compiler version: 4.2 27910799
Using a slow image processor as `use_fast` is unset and a slow processor was saved with this model. `use_fast=True` will be the default behavior in v4.52, even if the model was saved with a slow processor. This will result in minor differences in outputs. You'll still be able to use a slow processor with `use_fast=False`.
A new version of the following files was downloaded from https://huggingface.co/jinaai/jina-clip-implementation:
- transform.py
. Make sure to double-check they do not contain any added malicious code. To avoid downloading new versions of the code file, you can pin a revision.
text -> image: 0.3140323
