Input & Output Devices
HID Input Devices
Audio Playback Devices
CoreS3 Thread BR Factory Firmware
Factory Firmware
When the device works abnormally, you can try reflashing the factory firmware to check whether there is a hardware fault. Refer to the following tutorial. Use the M5Burner firmware flashing tool to flash the factory firmware to the device.
2. Download Mode
  • Press and hold the reset button (about 2 seconds) until the internal green LED lights up, then release it. At this point, the device has entered download mode and is ready for flashing.
3. Port Selection
Connect the device to the computer via a USB cable. After the device enters download mode, select the corresponding device port in M5Burner.
4. Firmware Flashing
  1. Click Erase to erase old data.
  1. Click Start to begin flashing.
The result is shown below:
