Input Device
PP-OCRv5
PP-OCRv5 is the new generation text recognition solution of PP-OCR, focusing on multi-scenario and multi-text type recognition. In terms of text types, PP-OCRv5 supports 5 major mainstream text types: Simplified Chinese, Chinese Pinyin, Traditional Chinese, English, and Japanese. For scenarios, PP-OCRv5 has upgraded recognition capabilities for challenging scenarios such as complex Chinese and English handwriting, vertical text, and uncommon characters.
  1. Manually download the model and upload it to raspberrypi5, or pull the model repository with the following command.
Tip
If git lfs is not installed, refer to the git lfs installation guide first.
git clone https://huggingface.co/AXERA-TECH/PPOCR_v5
File Description:
m5stack@raspberrypi:~/rsp/PPOCR_v5 $ ls -lh
total 32M
-rw-rw-r-- 1 m5stack m5stack  48K Oct 20 10:40 11.jpg
drwxrwxr-x 2 m5stack m5stack 4.0K Oct 20 10:40 ax620e
drwxrwxr-x 2 m5stack m5stack 4.0K Oct 20 10:40 ax650
-rw-rw-r-- 1 m5stack m5stack 1.3K Oct 20 10:35 cls.json
-rw-rw-r-- 1 m5stack m5stack 958K Oct 20 10:38 cls_mobile_sim_static.onnx
-rw-rw-r-- 1 m5stack m5stack    0 Oct 20 10:35 config.json
-rw-rw-r-- 1 m5stack m5stack 1.2K Oct 20 10:35 det.json
-rw-rw-r-- 1 m5stack m5stack 4.6M Oct 20 10:38 det_mobile_sim_static.onnx
-rw-rw-r-- 1 m5stack m5stack  21K Oct 20 10:35 infer_axmodel.py
-rw-rw-r-- 1 m5stack m5stack  21K Oct 20 10:35 infer_onnx.py
-rw-rw-r-- 1 m5stack m5stack  73K Oct 20 10:35 ppocrv5_dict.txt
-rw-rw-r-- 1 m5stack m5stack 4.4K Oct 20 10:35 README.md
-rw-rw-r-- 1 m5stack m5stack 1.3K Oct 20 10:35 rec.json
-rw-rw-r-- 1 m5stack m5stack  16M Oct 20 10:38 rec_mobile_sim_static.onnx
-rw-rw-r-- 1 m5stack m5stack 121K Oct 20 10:40 res_ax.jpg
-rw-rw-r-- 1 m5stack m5stack 121K Oct 20 10:40 res_onnx.jpg
-rw-rw-r-- 1 m5stack m5stack  11M Oct 20 10:36 simfang.ttf
python -m venv ppocr
source ppocr/bin/activate
  1. Install dependencies
Run:
python infer_axmodel.py --det_model_dir ./ax650/det_npu3.axmodel --rec_model_dir ./ax650/rec_npu3.axmodel --cls_model_dir ./ax650/cls_npu3.axmodel
Run output:
(ppocr) m5stack@raspberrypi:~/rsp/PPOCR_v5 $ python infer_axmodel.py \
  --det_model_dir ./ax650/det_npu3.axmodel \
  --rec_model_dir ./ax650/rec_npu3.axmodel \
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 b98901c3
[[[22.0, 32.0], [307.0, 32.0], [307.0, 77.0], [22.0, 77.0]], ('纯臻营养护发素', 0.9881175756454468)]
[[[24.0, 80.0], [174.0, 80.0], [174.0, 105.0], [24.0, 105.0]], ('产品信息/参数', 0.9941993951797485)]
[[[25.0, 110.0], [333.0, 110.0], [333.0, 135.0], [25.0, 135.0]], ('(45元/每公斤,100公斤起订)', 0.9549185633659363)]
[[[24.0, 140.0], [283.0, 142.0], [283.0, 167.0], [24.0, 165.0]], ('每瓶22元,1000瓶起订)', 0.9522098898887634)]
[[[23.0, 175.0], [302.0, 174.0], [302.0, 197.0], [23.0, 198.0]], ('【品牌】:代加工方式/OEMODM', 0.98729008436203)]
[[[24.0, 206.0], [235.0, 208.0], [235.0, 229.0], [24.0, 228.0]], ('【品名】:纯臻营养护发素', 0.9895920753479004)]
[[[26.0, 238.0], [242.0, 238.0], [242.0, 259.0], [26.0, 259.0]], ('【产品编号】:YM-X-3011', 0.9853904843330383)]
[[[412.0, 233.0], [430.0, 233.0], [430.0, 303.0], [412.0, 303.0]], ('ODMOEM', 0.8154547810554504)]
[[[24.0, 269.0], [181.0, 268.0], [181.0, 289.0], [25.0, 290.0]], ('【净含量】:220ml', 0.9779437780380249)]
[[[24.0, 300.0], [253.0, 301.0], [253.0, 322.0], [24.0, 321.0]], ('【适用人群】:适合所有肤质', 0.9893492460250854)]
[[[24.0, 331.0], [345.0, 332.0], [345.0, 354.0], [24.0, 352.0]], ('【主要成分】:鲸蜡硬脂醇、燕麦β-葡聚', 0.9715114235877991)]
[[[26.0, 364.0], [283.0, 364.0], [283.0, 384.0], [26.0, 384.0]], ('糖、椰油酰胺丙基甜菜碱、泛醌', 0.9863923192024231)]
[[[367.0, 366.0], [476.0, 366.0], [476.0, 388.0], [367.0, 388.0]], ('(成品包材)', 0.8738409876823425)]
[[[25.0, 394.0], [362.0, 394.0], [362.0, 416.0], [25.0, 416.0]], ('【主要功能】:可紧致头发磷层,从而达到', 0.9911136627197266)]
[[[27.0, 426.0], [373.0, 426.0], [373.0, 447.0], [27.0, 447.0]], ('即时持久改善头发光泽的效果,给干燥的头', 0.9935663342475891)]
[[[26.0, 457.0], [137.0, 457.0], [137.0, 478.0], [26.0, 478.0]], ('发足够的滋养', 0.9879047274589539)]
