Git LFS (Large File Storage) is an extension for Git that is used to efficiently manage large files. When working with model repositories on HuggingFace, installing Git LFS is usually required to correctly download and handle large files.
First, update the system package index:
apt update Run the following command to install the git-lfs package:
apt install git-lfs After installation, run the following command to initialize Git LFS:
git lfs install Once initialization is complete, Git LFS will be integrated into the Git workflow, and you can use the git clone command as usual to retrieve repositories that contain large files.
