UIFlow Guide
UiFlow1 Blockly
Event
Unit
UiFlow2 Development Guide
UI Editor
Device Security & Sharing
Unit LoRaWAN868
Example
Configure LoRaWAN868 and connect to the network
from m5stack import *
from m5ui import *
from uiflow import *
import time
import unit
setScreenColor(0x222222)
LoRaWAN868_0 = unit.get(unit.LoRaWAN, unit.PORTC)
flag = None
LoRaWAN868_0.set_join_mode(0)
LoRaWAN868_0.config_OTAA('', '', '')
LoRaWAN868_0.set_frequency_band_mask('')
LoRaWAN868_0.set_rx_window_param(0, 0, 869525000)
LoRaWAN868_0.set_class_mode(2)
LoRaWAN868_0.set_uplink_downlink_mode(1)
LoRaWAN868_0.join(1, 1, 8, 8)
flag = False
while True:
  if not flag and LoRaWAN868_0.check_join_status():
    flag = True
    print('Joined')
  if flag:
    LoRaWAN868_0.send_data('M5STACK', 1, 5)
    print(LoRaWAN868_0.check_downlink_data())
  wait(10)
  wait_ms(2)
API
LoRaWAN868_0.uart_port_id(1)
  • Set Core UART ID
print((str('ckeck downlink data:') + str(LoRaWAN868_0.check_downlink_data())))
  • Check and Receive Downlink Data
print((str('status:') + str(LoRaWAN868_0.check_join_status())))
-Check Join Status
print((str('uplink data status:') + str(LoRaWAN868_0.check_uplink_status())))
  • Check Uplink Data Status
LoRaWAN868_0.set_class_mode(0)
  • Configure Config Parameters
    • frequency band mask:Frequency band mask
    • RX window param:Receive window parameters
    • RX1 offset:RX1 window offset
    • RX2 datarate SF12 BW125:RX2 window data rate (Spreading Factor 12, Bandwidth 125kHz)
    • RX2 freq(H1):RX2 window frequency
    • class mode classA:Device mode (Class A)
    • uplink downlin same frequency mode: Uplink and downlink same frequency mode
LoRaWAN868_0.config_OTAA('afeafe53453453adsfsdf423', 'gffgfds-546fgdg-ggfd', '33453453-4564-54')
  • Config OTAA mode
    • device eui
    • app key
    • app eui
print((str('ABP Config:') + str(LoRaWAN868_0.get_ABP_config())))
  • Get ABP Configuration
print((str('OTAA Config:') + str(LoRaWAN868_0.get_OTAA_config())))
  • Get OTTA Configuration
LoRaWAN868_0.join(1, 1, 8, 1)
  • Join LoRaWAN Network Configuration
    • open auto jion
    • period (seconds)
    • maximum number of attempts
LoRaWAN868_0.join(0)
  • Stop Joining LoRaWAN Network
print((str('downlink data:') + str((LoRaWAN868_0.receive_data()))))
  • Receive Downlink Data from Buffer
LoRaWAN868_0.send_data('')
  • Send Data Payload
  • Set Join Mode
    • OTTA
    • ABP
LoRaWAN868_0.set_uplink_app_port(1)
  • Set Uplink Application Port (1~233)
