UIFlow Guide
UiFlow1 Blockly
Event
Unit
UiFlow2 Development Guide
UI Editor
Device Security & Sharing
Unit TMOS PIR
Example
Continuously update and print TMOS PIR sensor data in the main loop, including motion state, presence state, ambient temperature changes, and object temperature.
from m5stack import *
from m5ui import *
from uiflow import *
import unit
tmos_0 = unit.get(unit.TMOS, unit.PORTA)
while True:
  tmos_0.tick_callback()
  print(tmos_0.get_data_ready())
  print(tmos_0.get_motion_state())
  print(tmos_0.get_motion_value())
  print(tmos_0.get_presence_state())
  print(tmos_0.get_presence_value())
  print(tmos_0.get_tamb_shock_state())
  print(tmos_0.get_tambient_raw_value())
  print(tmos_0.get_temperature_data())
  wait_ms(2)
API
  • Checks if the sensor data has been updated. Returns True if the latest sensor readings are available; otherwise, returns False.
  • Checks if motion has been detected. Returns True if the sensor has detected motion; otherwise, returns False.
  • Retrieves the motion detection value. This may indicate the intensity or range of detected motion, typically returned as an integer.
  • Checks if presence (i.e., a person in the area) has been detected. Returns True if presence is detected; otherwise, returns False.
  • Retrieves the presence detection value, similar to the motion detection value, but used to determine if someone is within the sensor's range.
  • Checks if a sudden change in ambient temperature has been detected. Returns True if a significant temperature change is detected; otherwise, returns False.
  • Reads the current ambient temperature, typically returned as an integer.
  • Reads the temperature of an object in front of the sensor, returned as a floating-point number.
def tmos_0_ambient_temperature_shock_detect_event(arg):
  # global params
  pass
tmos_0.set_callback(tmos_0_ambient_temperature_shock_detect_event, tmos_0.AMBIENT_TEMPERATURE_SHOCK_DETECT)
  • Triggers an event when the sensor detects ambient temperature changes. This block can be set to perform actions under certain conditions, such as temperature variations.
  • Repeatedly executed operation in the program's main loop. This can be used to regularly check the sensor's state or read values.
tmos_0.get_gain_mode()
  • Retrieves the sensor's gain mode. The gain mode determines how the sensor processes signals, typically represented as an integer.
tmos_0.get_tmos_sensitivity()
  • Retrieves the sensor's sensitivity. This is a floating-point number, with higher values indicating greater sensitivity.
tmos_0.get_motion_threshold()
  • Retrieves the threshold for motion detection. This is an integer value; a lower value may mean even slight movements will be detected.
tmos_0.get_motion_hysteresis()
  • Retrieves the motion detection hysteresis value, which defines the stability that must be reached before the sensor stops reporting motion.
tmos_0.get_presence_threshold()
  • Retrieves the threshold for presence detection. Setting this value adjusts when a presence is considered detected.
tmos_0.get_presence_hysteresis()
  • Retrieves the presence detection hysteresis value, which determines the stability period before the presence reporting stops.
tmos_0.get_tambient_shock_threshold()
  • Retrieves the threshold for detecting rapid changes in ambient temperature. This threshold is used to trigger events for significant temperature changes.
tmos_0.get_tambient_shock_hysteresis()
  • Retrieves the hysteresis value for detecting rapid changes in ambient temperature. This setting helps prevent false alerts due to minor temperature fluctuations.
tmos_0.set_gain_mode(0)
  • Sets the sensor's gain mode to wide gain mode. This mode may offer a broader detection range or greater signal amplification.
tmos_0.set_tmos_sensitivity(0)
  • Sets the sensor's sensitivity. This value can be adjusted from 0 to 4080, with higher values indicating increased sensitivity.
tmos_0.set_motion_threshold(200)
  • Sets the threshold for motion detection. This value determines how much movement is recognized as valid motion, adjustable from 0 to 32767.
tmos_0.set_motion_hysteresis(0)
  • Sets the motion detection hysteresis value. This value helps prevent the sensor from frequently switching states under borderline conditions, adjustable from 0 to 255.
tmos_0.set_presence_threshold(200)
  • Sets the threshold for presence detection. Similar to the motion threshold, this setting determines what level of "presence" is considered valid, also adjustable from 0 to 32767.
tmos_0.set_presence_hysteresis(0)
  • Sets the presence detection hysteresis value. This value stabilizes the sensor's output, preventing frequent changes due to minor variations.
tmos_0.set_tambient_shock_threshold(200)
  • Sets the threshold for detecting rapid changes in ambient temperature. This value determines what speed of temperature change is considered significant.
tmos_0.set_tambient_shock_hysteresis(0)
  • Sets the hysteresis value for detecting rapid changes in ambient temperature. This setting helps prevent false alarms due to slight temperature fluctuations.
