SOLUTION
SOLUTION
Smart Factory
Smart Agriculture
Smart Retail
Weather Station
STORE
STORE
Controllers
Sensors
Modules
Cameras
Kits
Hobby
Accessories
SOFTWARE
SOFTWARE
UiFlow Coding IDE
UiFlow 1.0
UiFlow 2.0
Developer Tools
M5Burner
Block Designer
Ezdata 2.0
EasyLoader Packer
vlw Font Creator
Device Driver
Device USB Driver
DOCUMENT
DOCUMENT
Products Document
Controllers
Sensors
Modules
Cameras
Kits
Accessories
Platform
UiFlow 1.0
UiFlow 2.0
Micropython
Datasheet & Files
Products Certification
I2C Table
Product Selector
3D STL Files
PCB Files
EXPLORE
EXPLORE
Project HUB
YouTube
Forum
Github
ABOUT US
ABOUT US
About us
News
FAQ
UIFlow Guide
UIFlow 1.0 Quick Start
1. UIFlow Web IDE 1.0
2. Firmware & Program 1.0
Basic/Gray/M5GO
Fire
Core2/Core2 For AWS
Tough
Station-Bat
StickC
StickC-Plus
StickC-Plus2
Atom-Lite
AtomU
Atom-Matrix
Atom Display
Paper
CoreInk
Stamp-Pico
UIFlow 1.0 Blockly
Event
Event
UI
Screen
Hardwares
Speaker
Microphone
RGB
IMU
RTC
Power
Touch
Vibration
Watch Dog Timer
SDCard
Easy I/O
PIN
PWM
ADC
DAC
UART
I2C Master
Network
EEPROM
System
SPI
Generic
Variables
Math
Loops
Logic
Timer
Functions
Text
Lists
Json
Map
Bytearray
Advanced
Execute
ESP Now
MQTT
HTTP
Socket
Modbus Master
Modbus Slave
CAN
Blynk BLE
BLE
Pin Servo
NTP
LoRa Bus
Socket
Unit
Unit TMOS PIR
Unit Joystick2
Unit TimerPWR
Unit DMX
Unit Puzzle
Unit CO2
Unit CO2L
Unit CardKB
Unit ENV
Unit ToF
Unit ToF4M
UnitV/StickV V-Function
Unit RFID2
Unit Ultrasonic
Unit Ultrasonic-IO
Unit 8Angle
Unit 2Relay
Unit 4Relay
Unit 8Encoder
Unit 8Servos
Unit Accel
Unit ACSSR
Unit AC Measure
Atom Socket
Unit ADC
Unit ADC v1.1
Unit AIN4-20mA
Unit AMeter
Unit Angle
Unit ASR
Unit BLDC Driver
Unit Mini BPS
Unit Mini BPS v1.1
Unit Button
Unit Buzzer
Unit CAN
Unit CatM
Unit CatM GNSS
Unit Color
Unit DAC
Unit DAC2
Unit DCSSR
Unit DDS
Unit DigiClock
Unit DLight
Unit Dual Button
Unit Earth
Unit Encoder
Unit ENV-Pro
Unit ExtEncoder
Unit EXT.IO
Unit EXT.IO2
Unit Fader
Unit Fan
Unit Finger
Unit FlashLight
Unit Gesture
Unit Glass
Unit Glass2
Unit GPS
Unit Grove to Grove
Unit Hall
Unit HBridge
Unit Heart
Unit ID
Unit Mini IMU
Unit Mini IMU-Pro
Unit IR
Unit RS485-ISO
Unit Joystick
Unit Key
Unit KMeter
Unit KMeter-ISO
Unit Laser RX
Unit Laser TX
Unit LCD
Unit Light
Unit Limit
Unit LoRaWAN470
Unit LoRaWAN868
Unit LoRaWAN915
Unit LoRaE220-920
Unit LoRaE220-433
Unit Makey
Unit MIC
Unit Mini CAN
Unit Mini OLED
Unit Mini Scales
Unit MQTT
Unit NBIoT
Unit NBIoT2
Unit NCIR
Unit NCIR2
Unit Neco
Unit OLED
Unit OP90/180
Unit Pahub
Unit Pbhub
Unit PIR
Unit PoESP32
Unit QRCode
Unit Reflective IR
Unit Relay
Unit RF433R
Unit RF433T
Unit RGB
Unit RGB LED
Unit Roller485
Unit RS485
Unit RTC
Unit Scales
Unit Servo
Unit SSR
Unit Synth
Unit Thermal
Unit Thermal2
Unit Trace
Unit Tube Pressure
Unit Mini TVOC/eCO2
Unit RFID-UHF
Unit UWB
Unit Vibrator
Unit VMeter
Unit Watering
Unit Weight
Unit Weight-I2C
Unit ZigBee
Module
Module13.2 2Relay
Module 4EncoderMotor
Module13.2 4In8Out
Module13.2 4Relay
Module13.2 AIN4-20mA
Module COMMU
Module COMX Cat1
Module COMX GSM
Module COMX LoRaWAN470
Module COMX LoRaWAN915
Module COMX LTE
Module COMX NBIoT
Module COMX Zigbee
Module DCMotor
Module13.2 Display
Module13.2 Dual Kmeter
Faces Calculator
Faces Encoder
Faces Finger
Faces Gameboy
Faces Joystick
Faces Keyboard
Faces RFID
Module GNSS
Module13.2 GoPlus
Module13.2 GoPlus2
Module GPS
Module13.2 GRBL
Module HMI
IoTBase CatM
IoTBase NBIoT
Module13.2 LAN
Module LoRa433
Module LoRa868
Module Plus
Module13.2 RS232
Module Servo
Module13.2 Servo2
Module Stepmotor
Module13.2 Stepmotor Driver
Module USB
Module LLM
Base
PM2.5
Base LAN
Base DMX
Base X
Hat
Hat 8Servos
Hat 8Servos v1.1
Hat ADC
Hat BalaC
Hat BeetleC
Hat BugC
Hat BugC2
Hat CardKB
Hat CBack Driver
Hat CBack NBIoT
Hat DAC
Hat DAC2
Hat DLight
Hat ENV
Hat Finger
Hat Heart
Hat JoyC
Hat Joystick
Hat Mini EncoderC
Hat Mini JoyC
Hat NICR
Hat PIR
Hat PuppyC
Hat RoverC
Hat RS485
Hat Servo
Hat SPK
Hat SPK2
Hat Thermal
Hat ToF
Hat Vibrator
Hat Yun
Atomic Base
Atomic CAN Base
Atomic GPS Base
Atomic HDriver Base
Atomic Motion Base
Atomic PoE Base
Atomic QRCode Base
Atomic QRCode2 Base
Atomic SPK Base
Atomic Stepmotor Base
Atomic TFCard Base
Atom Socket
Atom DTU Cat1
Atom DTU LoRaWAN470
Atom DTU LoRaWAN868
Atom DTU LoRaWAN915
Atom DTU NBIoT
EzData 1.0
EzData blockly
Remote+
Remote(old version)
IoTCloud
Ali IoT
AWS
Azure Classic
Azure IoT
Blynk IoT
Blynk Legacy
Tencent
MediaTrans
Atom Printer
Audio
Echo STT
Timer Camera
Blockly Custom
UIFlow 1.0 Project
UIFlow 1.0 File Manger
UIFlow 2.0 Quick Start
1. UIFlow Web IDE 2.0
2. Firmware & Program 2.0
Dial
Basic
Core2
CoreS3
Tough
Paper
PaperS3
Station-Bat
DinMeter
Capsule
StickC
Fire
AtomS3-Lite
AtomS3
AtomS3R
AtomS3U
Atom-Lite
AtomU
Atom-Matrix
CoreInk
Cardputer
Stamp-S3
Stamp-Pico
UIFlow 2.0 Blockly
UIFlow 2.0 API Docs
EzData 2.0
EzData 2.0
EzData blockly
UIFlow 2.0 Project
Import & Export Project
Device Share
Project Zone
File Manager
M5Burner
M5Burner Install
Firmware Export
Firmware Publish
Desktop IDE
UIFlow 1.x Desktop IDE
Not Search Result
HOT SEARCHES
Camera
WiFi
RS485
RS232
Relay
LoRaWAN
GPS
NB-IoT
LTE
GSM
Zigbee
Servo
StepMotor
Ethernet
E-Paper
Product
Tutorial
Search
Unit NbIoT2
Example
API
uiflow_block_unit_nbiot2_check_SIM_card
uiflow_block_unit_nbiot2_debug
uiflow_block_unit_nbiot2_get_gprs_status
uiflow_block_unit_nbiot2_get_identification
uiflow_block_unit_nbiot2_get_IMEI
uiflow_block_unit_nbiot2_get_PDP_context_ip
uiflow_block_unit_nbiot2_get_single_quality
uiflow_block_unit_nbiot2_http_data
uiflow_block_unit_nbiot2_http_request
uiflow_block_unit_nbiot2_http_status_code
uiflow_block_unit_nbiot2_http_terminate
uiflow_block_unit_nbiot2_mqtt_poll
uiflow_block_unit_nbiot2_mqtt_publish_topic
uiflow_block_unit_nbiot2_mqtt_server_disconnect
uiflow_block_unit_nbiot2_mqtt_server_is_connect
uiflow_block_unit_nbiot2_mqtt_service_config
uiflow_block_unit_nbiot2_mqtt_service_connect
uiflow_block_unit_nbiot2_mqtt_subscribe_topic
uiflow_block_unit_nbiot2_mqtt_subscribe_topic_cb
uiflow_block_unit_nbiot2_mqtt_unsubscribe_topic
uiflow_block_unit_nbiot2_set_enable_PDP_context
uiflow_block_unit_nbiot2_uart_port_id
