产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
lcm-lora-sd
提示
git clone https://huggingface.co/AXERA-TECH/lcm-lora-sdv1-5
文件说明:
m5stack@raspberrypi:~/rsp/lcm-lora-sdv1-5 $ ls -lh
total 100K
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 17:10 asserts
-rw-rw-r-- 1 m5stack m5stack    0 Aug 11 17:09 config.json
-rw-rw-r-- 1 m5stack m5stack 1.2K Aug 11 17:09 Disclaimer.md
-rw-rw-r-- 1 m5stack m5stack 1.5K Aug 11 17:09 LICENSE
drwxrwxr-x 4 m5stack m5stack 4.0K Aug 11 17:14 models
-rw-rw-r-- 1 m5stack m5stack 5.7K Aug 11 17:09 README.md
-rw-rw-r-- 1 m5stack m5stack  117 Aug 11 17:09 requirements.txt
-rw-rw-r-- 1 m5stack m5stack  23K Aug 11 17:09 run_img2img_axe_infer.py
-rw-rw-r-- 1 m5stack m5stack  23K Aug 11 17:09 run_img2img_onnx_infer.py
-rw-rw-r-- 1 m5stack m5stack 7.8K Aug 11 17:09 run_txt2img_axe_infer_new.py
-rw-rw-r-- 1 m5stack m5stack 7.3K Aug 11 17:09 run_txt2img_axe_infer.py
-rw-rw-r-- 1 m5stack m5stack 7.4K Aug 11 17:09 run_txt2img_onnx_infer.py
  1. 创建虚拟环境
python -m venv sd
  1. 激活虚拟环境
source sd/bin/activate
  1. 安装依赖包
sudo apt install cmake -y
  • 文生图
python run_txt2img_axe_infer.py
运行结果:
(sd) m5stack@raspberrypi:~/rsp/lcm-lora-sdv1-5$ python run_txt2img_axe_infer.py
prompt: Self-portrait oil painting, a beautiful cyborg with golden hair, 8k
text_tokenizer: ./models/tokenizer
text_encoder: ./models/text_encoder
unet_model: ./models/unet.axmodel
vae_decoder_model: ./models/vae_decoder.axmodel
time_input: ./models/time_input_txt2img.npy
save_dir: ./txt2img_output_axe.png
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.4 9215b7e5
text encoder take 4466.2ms
[INFO] Compiler version: 3.3 972f38ca
load models take 22582.9ms
unet once take 433.6ms
unet once take 433.5ms
unet once take 433.3ms
unet loop take 1736.7ms
vae inference take 914.2ms
save image take 254.3ms
  • 图生图
运行结果:
text encoder take 2962.1ms
load models take 14483.6ms
unet once take 433.2ms
unet once take 433.4ms
unet loop take 1736.4ms
vae inference take 914.0ms
save image take 233.2ms
