产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
MixFormerV2
MixFormerV2 是一种改进型的统一Transformer目标跟踪模型,通过融合特征提取与匹配过程,提升跟踪的精度与速度。
提示
git clone https://huggingface.co/AXERA-TECH/MixFormerV2
文件说明:
m5stack@raspberrypi:~/rsp/MixFormerV2 $ ls -lh
total 63M
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 ax630c
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 ax650
-rw-rw-r-- 1 m5stack m5stack  63M Aug 11 18:28 car.avi
-rw-rw-r-- 1 m5stack m5stack    0 Aug 11 18:28 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 11 18:28 onnx
-rw-rw-r-- 1 m5stack m5stack 4.0K Aug 11 18:28 README.md
-rw-rw-r-- 1 m5stack m5stack  15K Aug 11 18:28 run_mixformer2_axmodel.py
-rw-rw-r-- 1 m5stack m5stack  14K Aug 11 18:28 run_mixformer2_onnx.py
  1. 创建虚拟环境
python -m venv mixformer
  1. 激活虚拟环境
source mixformer/bin/activate
  1. 安装依赖包
pip install argparse numpy opencv-python glob2
  1. 运行
python3 run_mixformer2_axmodel.py --model-path ax650/mixformer_v2.axmodel --frame-path car.avi -r 10
运行结果:
(mixformer) m5stack@raspberrypi:~/rsp/MixFormerV2 $ python3 run_mixformer2_axmodel.py --model-path ax650/mixformer_v2.axmodel --frame-path car.avi -r 10
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.4-dirty 4ff37520-dirty
====================type================= [1079, 482] <class 'list'> <class 'list'>
第一帧初始化完毕!
Video: tracking     1011.0fps
Video: tracking     8.0fps
Reached the maximum number of frames (10). Exiting loop.
video: average finale average tracking fps 121.2 fps
