产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
SuperResolution
SuperResolution 是一种通过深度学习或其他算法将低分辨率图像转换为高分辨率图像的模型,用于提升图像细节和视觉质量。
提示
git clone https://huggingface.co/AXERA-TECH/SuperResolution
文件说明:
m5stack@raspberrypi:~/rsp/SuperResolution $ ls -lh
total 20K
-rw-rw-r-- 1 m5stack m5stack 3.8K Sep  4 18:49 config.json
drwxrwxr-x 4 m5stack m5stack 4.0K Sep  4 18:49 model_convert
drwxrwxr-x 5 m5stack m5stack 4.0K Sep  4 19:12 python
-rw-rw-r-- 1 m5stack m5stack 2.3K Sep  4 18:49 README.md
drwxrwxr-x 2 m5stack m5stack 4.0K Sep  4 19:03 video
  1. 创建虚拟环境
python -m venv sr
  1. 激活虚拟环境
source sr/bin/activate
  1. 安装依赖包
pip install  opencv-python torch torchvision tqdm scikit-image
  1. 运行
python python/run_axmodel.py --model model_convert/axmodel/edsr_baseline_x2_1.axmodel --dir_demo video/test_1920x1080.mp4
运行结果:
(sr) m5stack@raspberrypi:~/rsp/SuperResolution $ python python/run_axmodel.py --model model_convert/axmodel/edsr_baseline_x2_1.axmodel --dir_demo video/test_1920x1080.mp4
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 6bff2f67
100%|█████████████████████████████████████████| 267/267 [06:21<00:00,  1.43s/it]
Total time: 275.618 seconds for 267 frames
Average time: 1.032 seconds for each frame
原视频截图:
输出视频截图:
