产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
Whisper
  • 本小节只指导如何在 Raspberry Pi 5 上运行预编译好的基于 Whipser Small 的语音转文字示例;
  • 模型转换、示例源码编译请参考 whisper.axcl
  1. 下载
git clone https://github.com/ml-inory/whisper.axcl.git
  1. 编译
cd whisper.axcl
mkdir -p build && cd build
cmake -DCMAKE_INSTALL_PREFIX=../install -DCMAKE_BUILD_TYPE=Release ..
make install -j4
  1. 预编译模型
预编译模型下载 百度网盘
  1. 运行 Whisper
cd install
./whisper -w ../demo.wav
运行结果:
(base) axera@raspberrypi:~/qtang/whisper.axcl/install $ ./whisper -w ../demo.wav
encoder: ../models/small-encoder.axmodel
decoder_main: ../models/small-decoder-main.axmodel
decoder_loop: ../models/small-decoder-loop.axmodel
wav_file: ../demo.wav
language: zh
Load encoder take 3336.25 ms
Load decoder_main take 6091.89 ms
Load decoder_loop take 5690.05 ms
Read positional_embedding
Encoder run take 190.26 ms
First token: 17556       take 51.49ms
Next Token: 20844        take 30.15 ms
Next Token: 7781         take 30.21 ms
Next Token: 20204        take 30.20 ms
Next Token: 28455        take 30.17 ms
Next Token: 31962        take 30.02 ms
Next Token: 6336         take 30.09 ms
Next Token: 254          take 30.22 ms
Next Token: 2930         take 30.14 ms
Next Token: 236          take 30.14 ms
Next Token: 36135        take 30.12 ms
Next Token: 15868        take 30.18 ms
Next Token: 252          take 30.01 ms
Next Token: 1546         take 30.17 ms
Next Token: 46514        take 30.17 ms
Next Token: 50257        take 30.15 ms
All Token: take 503.68ms, 31.77 token/s
All take 735.09ms
Result: 甚至出现交易几乎停滞的情况
