产品上手指引
AI 智能体
Chat Coding(聊天造物)
IoT 测量仪表
输入输出设备
音频播放设备
Ethernet 摄像头
拨码开关&引脚切换
YOLO World
YOLO World v2
YOLO-Worldv2 该模型的详细模型导出、量化、编译的流程请参考《再谈 YOLO World 部署》
  • 模型:yoloworldv2_4cls_50_npu3.axmodel
  • 输入图片:ssd_horse.jpg
  • 输入文本:dog.bin, 对应的 4 分类 'dog' 'horse' 'sheep' 'cow'
提示
参考YOLO11章节 获取获取并解压整合包。
运行
./axcl_demo/axcl_yolo_world_open_vocabulary -m axcl_demo/yoloworldv2_4cls_50_npu3.axmodel -t axcl_demo/dog.bin -i axcl_demo/ssd_horse.jpg
运行结果如下:
m5stack@raspberrypi:~/rsp $ ./axcl_demo/axcl_yolo_world_open_vocabulary -m axcl_demo/yoloworldv2_4cls_50_npu3.axmodel -t axcl_demo/dog.bin -i axcl_demo/ssd_horse.jpg
model file : axcl_demo/yoloworldv2_4cls_50_npu3.axmodel
image file : axcl_demo/ssd_horse.jpg
text_feature file : axcl_demo/dog.bin
img_h, img_w : 640 640
axclrtEngineCreateContextt is done.
axclrtEngineGetIOInfo is done.
grpid: 0
input size: 2
        1 x 640 x 640 x 3
        1 x 4 x 512
output size: 3
        1 x 80 x 80 x 68
        1 x 40 x 40 x 68
        1 x 20 x 20 x 68
Engine push input is done.
post process cost time:0.25 ms
Repeat 1 times, avg time 4.52 ms, max_time 4.52 ms, min_time 4.52 ms
detection num: 2
 1:  91%, [ 215,   71,  421,  374], class2
 0:  67%, [ 144,  204,  197,  346], class1
YOLO World v2 CLI
获取源码 并上传到 raspberrypi5 或使用 git 命令拉取。
  1. 拉取代码
git clone https://github.com/AXERA-TECH/yoloworld.axera.git
  1. 进入项目目录
cd yoloworld.axera
提示
后续操作在此目录执行。
文件说明:
m5stack@raspberrypi:~/rsp/yoloworld.axera $ ls -lh
total 36K
-rwxrwxr-x 1 m5stack m5stack 2.1K Aug 12 11:26 build_aarch64.sh
-rwxrwxr-x 1 m5stack m5stack  775 Aug 12 11:26 build.sh
-rw-rw-r-- 1 m5stack m5stack 1.5K Aug 12 11:26 CMakeLists.txt
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 11:26 include
drwxrwxr-x 3 m5stack m5stack 4.0K Aug 12 14:46 pyyoloworld
-rw-rw-r-- 1 m5stack m5stack 1.9K Aug 12 11:26 README.md
drwxrwxr-x 4 m5stack m5stack 4.0K Aug 12 11:26 src
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 11:26 tests
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 11:26 toolchains
  1. 安装依赖
sudo apt update
sudo apt install cmake libopencv-dev -y
  1. 编译代码
mkdir build && cd build
cmake .. && make -j4 install
cd ..
  1. 获取模型和词表
wget https://github.com/AXERA-TECH/yoloworld.axera/releases/download/v0.1/clip_b1_u16_ax650.axmodel
wget https://github.com/AXERA-TECH/yoloworld.axera/releases/download/v0.1/yolo_u16_ax650.axmodel
wget https://github.com/AXERA-TECH/yoloworld.axera/releases/download/v0.1/vocab.txt
  1. 运行
./build/test_detect_by_text --yoloworld yolo_u16_ax650.axmodel --tenc clip_b1_u16_ax650.axmodel -v vocab.txt -i ssd_horse.jpg --classes person,car,dog,horse
运行结果如下:
m5stack@raspberrypi:~/rsp/yoloworld.axera $ ./build/test_detect_by_text --yoloworld yolo_u16_ax650.axmodel --tenc clip_b1_u16_ax650.axmodel -v vocab.txt -i ssd_horse.jpg --classes person,car,dog,horse
open libax_sys.so failed
open libax_engine.so failed
[I][                             run][  31]: AXCLWorker start with devid 0
label-0 class_names: person
label-1 class_names: car
label-2 class_names: dog
label-3 class_names: horse
yoloworld_path: yolo_u16_ax650.axmodel
text_encoder_path: clip_b1_u16_ax650.axmodel
tokenizer_path: vocab.txt
input size: 2
    name:   images [unknown] [unknown]
        1 x 640 x 640 x 3   size: 1228800
    name: txt_feats [unknown] [unknown]
        1 x 4 x 512   size: 8192
output size: 3
        1 x 80 x 80 x 68   size: 1740800
        1 x 40 x 40 x 68   size: 435200
        1 x 20 x 20 x 68   size: 108800
[I][                       yw_create][ 408]: num_classes: 4, num_features: 512, input w: 640, h: 640
is_output_nhwc: 1
input size: 1
    name: text_token [unknown] [unknown]
        1 x 77   size: 308
output size: 1
        1 x 1 x 512   size: 2048
[I][               load_text_encoder][  44]: text feature len 512
[I][                  load_tokenizer][  60]: text token len 77
[I][                  yw_set_classes][ 463]: label-0 class_names: person
[I][                  yw_set_classes][ 463]: label-1 class_names: car
[I][                  yw_set_classes][ 463]: label-2 class_names: dog
[I][                  yw_set_classes][ 463]: label-3 class_names: horse
yw_set_classes time: 12.76 ms
preprocess 1.04
inference 19.06
postprocess 0.27
yw_detect time: 20.45 ms
object-0 class_id: 3 score: 0.88 box: 215 69 206 304
object-1 class_id: 0 score: 0.88 box: 271 13 76 220
object-2 class_id: 0 score: 0.77 box: 430 123 20 54
object-3 class_id: 2 score: 0.75 box: 144 203 52 143
object-4 class_id: 1 score: 0.65 box: 0 105 131 91
object-5 class_id: 0 score: 0.37 box: 402 130 7 16
object-6 class_id: 0 score: 0.16 box: 413 134 13 16
[I][                             run][  81]: AXCLWorker exit with devid 0
[2025-08-12 16:00:53.491][55020][C][device][print][18]: allocated device memories: 7
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x1497ae000] : 0x134 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x1495de000] : 0x1a900 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x1497af000] : 0x800 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x149573000] : 0x6a400 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x1493ca000] : 0x1a9000 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x1493c8000] : 0x2000 bytes
[2025-08-12 16:00:53.491][55020][C][device][print][20]: [0x14929c000] : 0x12c000 bytes
YOLO World v2 Web
  1. 创建虚拟环境
python -m venv yolo
  1. 激活虚拟环境
source yolo/bin/activate
  1. 安装依赖包
pip install -r pyyoloworld/requirements.txt
  1. 复制动态库
cp build/libyoloworld.so pyyoloworld/
  1. 启动服务
python pyyoloworld/gradio_example.py --yoloworld yolo_u16_ax650.axmodel --tenc clip_b1_u16_ax650.axmodel --vocab vocab.txt
正在运行后信息如下:
(yolo) m5stack@raspberrypi:~/rsp/yoloworld.axera $ python pyyoloworld/gradio_example.py --yoloworld yolo_u16_ax650.axmodel --tenc clip_b1_u16_ax650.axmodel --vocab vocab.txt
Trying to load: /home/m5stack/rsp/yoloworld.axera/pyyoloworld/aarch64/libyoloworld.so
❌ Failed to load: /home/m5stack/rsp/yoloworld.axera/pyyoloworld/aarch64/libyoloworld.so
   /home/m5stack/rsp/yoloworld.axera/pyyoloworld/aarch64/libyoloworld.so: cannot open shared object file: No such file or directory
🔍 File not found. Please verify that libclip.so exists and the path is correct.
Trying to load: /home/m5stack/rsp/yoloworld.axera/pyyoloworld/libyoloworld.so
✅ Successfully loaded: /home/m5stack/rsp/yoloworld.axera/pyyoloworld/libyoloworld.so
input size: 2
output size: 3
is_output_nhwc: 1
input size: 1
        1 x 77   size: 308
output size: 1
* Running on local URL:  http://0.0.0.0:7860
* To create a public link, set `share=True` in `launch()`.
  1. 在浏览器中打开 127.0.0.1:7860,添加图片,输入要检测的类别,点击检测
