Chain DualKey Home Assistant Integration
This tutorial will introduce how to integrate the Chain DualKey programmable dual-key development board into Home Assistant to achieve button and expansion module control.
Preparation
In this tutorial, the firmware is compiled and uploaded under ESPHome 2025.1.2. If you encounter compilation/upload issues, please consider switching ESPHome to this version.
Create Device
  1. Create a new device. Click the green button in the bottom right corner to create the device.
  1. Create device name.
  • Click CONTINUE.
  • Click New Device Setup.
  • Enter the device name and click NEXT.
  1. Select device type.
  • Click ESP32-S3.
  • Click SKIP.
  1. Edit YAML file. Click EDIT; we can customize device functions through the YAML file.
Device Configuration
Master serves as the system's main controller. When connecting expansion sensors, it is necessary to correctly distinguish the connection direction and ID numbering sequence.
Direction Selection
Depending on which side of the Master the expansion sensor is connected to, select the corresponding uart_id:
  • Connected to the Master's left side → Use chain_uart_left.
  • Connected to the Master's right side → Use chain_uart_right.
ID Numbering Rules
chain_id indicates the position of the expansion sensor relative to the Master:
  • Numbering starts from the module closest to the Master.
  • IDs increase sequentially (ID:1 → ID:2 → ID:3 …).
  • The left and right sides are numbered independently.
  • Refer to the image above to determine the correct sequence.
Configuration Example
  • uart_id: chain_uart_left.
  • chain_id: 1.
Chain DualKey
uart:
  - id: chain_uart_right
    tx_pin: GPIO6
    rx_pin: GPIO5
    baud_rate: 115200
  - id: chain_uart_left
    tx_pin: GPIO48
    rx_pin: GPIO47
    baud_rate: 115200
  - platform: adc
    pin: GPIO10
    update_interval: 1s
  - platform: adc
    pin: GPIO2
    update_interval: 1s
  - platform: adc
    pin: GPIO9
    update_interval: 1s
output:
  - platform: gpio
    pin: GPIO40
light:
    internal: true
    pin: GPIO21
    num_leds: 2
    chipset: ws2812
    rgb_order: GRB
    restore_mode: ALWAYS_OFF
  - platform: partition
    name: "Key Light 1"
    segments:
      - id: key_light_raw
        to: 0
    name: "Key Light 2"
    segments:
      - id: key_light_raw
        to: 1
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO17
      inverted: true
      mode: INPUT_PULLUP
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      - light.turn_on:
          transition_length: 0ms
    on_release:
      - light.turn_off: key_light_2
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode: INPUT_PULLUP
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      - light.turn_on:
    on_release:
      - light.turn_off: key_light_1
  - platform: gpio
    pin:
      number: GPIO7
      mode: INPUT
  - platform: gpio
    pin:
      number: GPIO8
      mode: INPUT
Chain Key
external_components:
    components: [m5stack_chain_key]
    refresh: 0s
binary_sensor:
  - platform: m5stack_chain_key
    name: "Chain Key Button"
    uart_id: xx
    chain_id: xx
    update_interval: 50ms
output:
    chain_key_id: chain_key_1
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
light:
  - platform: rgb
    red: chain_key_rgb_r
    green: chain_key_rgb_g
    blue: chain_key_rgb_b
Chain Angle
    components: [m5stack_chain_angle]
    refresh: 0s
  - platform: m5stack_chain_angle
    uart_id: xx
    chain_id: xx
output:
    chain_angle_id: chain_angle_1
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
light:
  - platform: rgb
    red: chain_angle_rgb_r
    green: chain_angle_rgb_g
    blue: chain_angle_rgb_b
Chain Encoder
    components: [m5stack_chain_encoder]
    refresh: 0s
  - platform: m5stack_chain_encoder
    uart_id: xx
    chain_id: xx
    update_interval: 100ms
output:
    chain_encoder_id: chain_encoder_1
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
light:
  - platform: rgb
    red: chain_encoder_rgb_r
    green: chain_encoder_rgb_g
    blue: chain_encoder_rgb_b
binary_sensor:
Chain Joystick
    components: [m5stack_chain_joystick]
    refresh: 0s
  - platform: m5stack_chain_joystick
    name: "Chain Joystick X"
    uart_id: xx
    chain_id: xx
    axis: x
    name: "Chain Joystick Y"
    uart_id: xx
    chain_id: xx
    axis: y
output:
    chain_joystick_id: chain_joystick_x
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
light:
  - platform: rgb
    red: chain_joystick_rgb_r
    green: chain_joystick_rgb_g
    blue: chain_joystick_rgb_b
binary_sensor:
Chain ToF
    components: [m5stack_chain_tof]
    refresh: 0s
  - platform: m5stack_chain_tof
    uart_id: xx
    chain_id: xx
output:
    m5stack_chain_tof_id: chain_tof_1
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
light:
  - platform: rgb
    red: chain_tof_rgb_r
    green: chain_tof_rgb_g
    blue: chain_tof_rgb_b
Example
The following code example is configured according to the connection sequence shown in the image above.
External Components
Modules used: Chain Angle, Chain Encoder, Chain ToF, Chain Joystick, Chain Key.
  • Add External component. This configuration block is used to introduce all Chain series-related external components. If a module (e.g., Chain Encoder or Chain ToF) is not used, the corresponding entry can be removed from the components list.
    components:
        m5stack_chain_angle,
        m5stack_chain_encoder,
        m5stack_chain_tof,
        m5stack_chain_joystick,
        m5stack_chain_key,
    refresh: 0s
UART Components
Modules used: The UART bus shared by all Chain series modules on the Master's left/right HY2.0 interfaces.
  • Add Uart component. In this example, chain_uart_right and chain_uart_left correspond to the HY2.0 interfaces on the right and left sides of the Master, respectively. Subsequent Chain module uart_id settings need to match the actual connection direction.
captive_portal:
uart:
    tx_pin: GPIO6
    rx_pin: GPIO5
    baud_rate: 115200
    tx_pin: GPIO48
    rx_pin: GPIO47
    baud_rate: 115200
Sensor Components
Modules used: Chain Encoder, Chain Angle, Chain ToF, Chain Joystick (X/Y), DualKey battery-related ADC sensors.
  • Add Sensor component. In this example, Chain Encoder (ID 1), Chain Angle (ID 2), and Chain ToF (ID 3) are connected in order on the right side of the Master, and Chain Joystick (ID 1, X/Y axes) is connected on the left side. ADC channels related to battery level (BAT, VBUS, CHARGE) are also enabled as sensors.
    uart_id: chain_uart_right
    chain_id: 1
    name: "ToF Distance"
    chain_id: 3
    chain_id: 2
    chain_id: 1
    axis: x
    chain_id: 1
    axis: y
  - platform: adc
    pin: GPIO10
    update_interval: 1s
  - platform: adc
    pin: GPIO2
    update_interval: 1s
  - platform: adc
    pin: GPIO9
    update_interval: 1s
Output Components
Modules used: RGB lights of Chain Encoder, Chain Key, Chain Joystick, Chain Angle, Chain ToF, and DualKey power control.
  • Add Output component. The pwr_en GPIO output is used to control power supply to the Chain expansion bus, which usually needs to remain on to ensure that modules connected to the bus can operate normally.
output:
  - platform: gpio
    pin: GPIO40
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
    channel: rgb_red
    channel: rgb_green
    channel: rgb_blue
Light Components
Modules used: WS2812 key lights on DualKey, and RGB indicator lights on each Chain module.
  • Add Light component. This section configures the RGB backlight for each button on the DualKey (partitioned from key_light_raw into key_light_1 and key_light_2), while also defining corresponding RGB light entities for each Chain module for separate control in Home Assistant.
light:
    internal: true
    pin: GPIO21
    num_leds: 2
    chipset: ws2812
    rgb_order: GRB
    segments:
      - id: key_light_raw
        to: 1
    segments:
      - id: key_light_raw
        to: 0
  - platform: rgb
  - platform: rgb
  - platform: rgb
  - platform: rgb
  - platform: rgb
Binary Sensor Components
Modules used: Mechanical buttons and side DIP switches on DualKey, as well as buttons on Chain Key, Chain Encoder, and Chain Joystick modules.
  • Add Binary Sensor component. This section defines all input related to buttons: two mechanical keys (KEY 1, KEY 2) and their corresponding backlight interaction, the button of a Chain Key module on the bus, the encoder button, the joystick button, and two side switches (SWITCH 1, SWITCH 2). You can rename these entities in Home Assistant based on your actual use cases.
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO17
      inverted: true
      mode: INPUT_PULLUP
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      - light.turn_on:
    on_release:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: true
      mode: INPUT_PULLUP
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
    on_press:
      - light.turn_on:
    on_release:
    name: "Key Module Button"
    chain_id: 2
  - platform: gpio
    pin:
      number: GPIO7
      mode: INPUT
  - platform: gpio
    pin:
      number: GPIO8
      mode: INPUT
Download and Flash Firmware
  1. After modification, click SAVE and INSTALL in the top right corner, then select Manual Download in the pop-up dialog.
  1. Once firmware compilation is complete, click Download and select the Factory format(Previously Modern) option to download the firmware.
Tip
Click m5stack_chain to view the complete example configuration. The first build may take some time, depending on the performance of the Home Assistant host and network quality.
  1. Connect the device to the host using a USB Type‑C cable. Open ESPHome Web and click CONNECT to connect the device.
  1. Find the corresponding serial port number.
  1. Click INSTALL.
  1. Select the compiled firmware for uploading.
  1. After firmware flashing is complete, the device needs to be re-powered to perform a hardware reset.
Quick Start
  1. In Home Assistant, click Settings -> Device & services to view the device.
  1. We can find the corresponding device in the Discover section.
  1. After adding the device, the data will be displayed correctly.
  1. Finally, add these entities to the Dashboard to obtain the following display effect.
