Unit ToF Home Assistant Integration
This tutorial will introduce how to integrate the Unit ToF high-precision laser ranging sensor into Home Assistant to achieve non-contact distance monitoring.
Environment Setup
  1. Install Home Assistant by following the official Home Assistant documentation.
  2. Install the ESPHome Device Builder add-on by following the official ESPHome documentation.
  3. Refer to the following resources:
Hardware Products
  • Unit ToF
  • A compatible controller (such as an Atom, Stamp, Stick, Core, or Basic series device)
Unit ToF requires a compatible controller to integrate with Home Assistant. Select the controller model and interface pins according to your project.
2. Modify Configuration
The I²C component needs to be enabled in the ESPHome configuration:
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here will vary depending on the main controller used. For example, using Atom Lite as the main controller:
i2c:
  sda: GPIO26
  scl: GPIO32
Unit ToF configuration example:
yaml
1 2 3 4 5 6
  - platform: vl53l0x
    name: "VL53L0x Distance"
    address: 0x29
    update_interval: 60s
    long_range: true
After saving the configuration file, compiling, and uploading the firmware, the device can be added to the Home Assistant integration.
