Unit CO2/CO2L Home Assistant Integration
This tutorial will introduce how to use the Unit CO2/CO2L sensor to integrate into Home Assistant, achieving real-time monitoring of carbon dioxide, temperature, and humidity.
Environment Setup
  1. Install Home Assistant by following the official Home Assistant documentation.
  2. Install the ESPHome Device Builder add-on by following the official ESPHome documentation.
  3. Refer to the following resources:
Hardware Products
  • Unit CO2
  • Unit CO2L
  • A compatible controller (such as an Atom, Stamp, Stick, Core, or Basic series device)
Unit CO2 requires a compatible controller to integrate with Home Assistant. Select the controller model and interface pins according to your project.
2. Modify Configuration
The I²C component needs to be enabled in the ESPHome configuration:
i2c:
  sda: GPIOXX
  scl: GPIOXX
  scan: true
The GPIO pins here vary depending on the main controller used. For example, using Atom Lite as the controller:
i2c:
  sda: GPIO26
  scl: GPIO32
Example configuration for Unit CO2/CO2L:
yaml
1 2 3 4 5 6 7 8
  - platform: scd4x
    co2:
    temperature:
    humidity:
3. Getting Started
Once added to the Dashboard, you can view the sensor data in Home Assistant.
