Unit IR Home Assistant Integration
This section describes the configuration methods and practical steps for integrating the Unit IR infrared transmitter/receiver unit into Home Assistant.
Environment Setup
  1. Install Home Assistant by following the official Home Assistant documentation.
  2. Install the ESPHome Device Builder add-on by following the official ESPHome documentation.
  3. Refer to the official ESPHome IR documentation:
  1. Confirm the GPIO pin definitions of the controller device (pins vary by controller).
Hardware Products
  • Unit IR
  • A compatible controller (such as an Atom, Stamp, Stick, Core, or Basic series device)
Unit IR requires a compatible controller to integrate with Home Assistant. Select the controller model and interface pins according to your project.
2. Modify Configuration
Configure IR Transmitter/Receiver
  1. Basic configuration example:
remote_receiver:
  pin: GPIOXX
  dump: all
remote_transmitter:
  pin: GPIOXX
  carrier_duty_percent: 50%
The GPIO pins will vary depending on the controller used. For example, using the AtomS3 series as a controller:
# GPIO1 input
remote_receiver:
  pin: GPIO1
  dump: all
# GPIO2 output
remote_transmitter:
  pin: GPIO2
  1. Once the IR configuration is complete, you can add devices like IR Climate. Taking a Midea air conditioner as an example:
climate:
  - platform: coolix # or media_ir
    visual:
      min_temperature: 18
      max_temperature: 30
      temperature_step: 1
  1. After saving, compile and upload the firmware. Add the device to Home Assistant to see the IR entity:
