StickC-Plus2 Button
StickC-Plus2 Button input related APIs and case programs.
Note:
Include StickCP2.update() function in the main loop to read status update and minimize blocking, otherwise you may not be able to retrieve the status of key changes in time.
Example
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
#include "M5StickCPlus2.h"
    auto cfg = M5.config();
    StickCP2.begin(cfg);
    StickCP2.update();
    if (StickCP2.BtnA.wasPressed()) {
        Serial.println("A Btn Pressed");
    if (StickCP2.BtnA.wasReleased()) {
        Serial.println("A Btn Released");
    if (StickCP2.BtnB.wasPressed()) {
        Serial.println("B Btn Pressed");
    if (StickCP2.BtnB.wasReleased()) {
        Serial.println("B Btn Released");
    if (StickCP2.BtnPWR.wasClicked()) {
        Serial.println("PWR Btn Clicked");
    if (StickCP2.BtnPWR.wasHold()) {
        Serial.println("PWR Btn Hold");
API
M5StickC Plus2 library is based on the M5Unified library, the key part uses the Button_Class in the M5Unified library, for more key related APIs you can refer to the following document:
The status reading of the physical button (BtnPWR) on StickC-Plus2 depends on the power management chip. Currently, only "wasClicked" and "wasHold" can be used normally.
