Unit Grove to Grove Arduino Tutorial
2. Example
Example Description
Unit Grove to Grove can measure the current passing through the Grove interface and supports controlling the power supply line. This Unit provides two IO interfaces: one for reading the current analog signal and the other for controlling the power switch with a digital signal.
Current Calculation
1 2 3 4
uint32_t adc_raw    = adc1_get_raw((adc1_channel_t)ADC1_CHANNEL_7);
uint32_t voltage_mv = (uint32_t)(esp_adc_cal_raw_to_voltage(adc_raw, adc_chars));
float voltage       = (voltage_mv - offset) / 1000.0f;
float grove_current = (voltage / 50.0f / 0.02f);
Power Switch
1 2 3 4 5
pinMode(POWER_CTL_PIN, OUTPUT);
// Power on!
digitalWrite(POWER_CTL_PIN, HIGH);
// Power off!
digitalWrite(POWER_CTL_PIN, LOW);
Full Program
Based on M5Unified and M5GFX, basic display and switch control are added to implement current reading and touch control of the power switch.
ADC Channel Notes:
In this example, we use the ADC input pin of ESP32-S3, GPIO8, so during initialization, it should be configured as ADC1_CHANNEL_7. If you are using a different mainboard, please refer to the relevant ESP32 chip manual, check the ADC section for the GPIO and channel details, and adjust the example program accordingly.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
#include "driver/adc.h"
#include "esp_adc_cal.h"
#include "math.h"
#define POWER_CTL_PIN 9
#define ANALOG_PIN    8
esp_adc_cal_characteristics_t *adc_chars;
bool power_status = false;
float offset      = 0.0f;
void adc_init()
    gpio_pad_select_gpio(ANALOG_PIN);
    gpio_set_direction((gpio_num_t)ANALOG_PIN, GPIO_MODE_INPUT);
    adc1_config_width(ADC_WIDTH_BIT_12);
    adc1_config_channel_atten(ADC1_CHANNEL_7, ADC_ATTEN_DB_11);
    adc_chars = (esp_adc_cal_characteristics_t *)calloc(1, sizeof(esp_adc_cal_characteristics_t));
    esp_adc_cal_characterize(ADC_UNIT_1, ADC_ATTEN_DB_11, ADC_WIDTH_BIT_12, 3300, adc_chars);
void cal_adc_offset()
    float sum = 0;
    for (int i = 0; i < 100; i++) {
        sum += voltage_mv;
    offset = sum / 100.0f;
    // Power on!
    digitalWrite(POWER_CTL_PIN, power_status);
    M5.Display.println(power_status ? "Grove Power On" : "Grove Power Off");
    adc_init();
    cal_adc_offset();
time_t last_update_time = 0;
    auto t = M5.Touch.getDetail();
    if (t.wasClicked() || M5.BtnA.wasClicked()) {
        Serial.println("click!");
        power_status = !power_status;
        M5.Display.fillRect(0, 0, 320, 50, BLACK);
        M5.Display.setCursor(0, 0);
        if (!power_status) {
            cal_adc_offset();
    if (millis() - last_update_time > 1000) {
        last_update_time = millis();
        M5.Display.fillRect(0, 50, 320, 100, BLACK);
        M5.Display.setCursor(0, 50);
        M5.Display.printf("Grove Current:%.3fA\r\n", grove_current);
        Serial.printf("Grove Current:%.3fA\r\n", grove_current);
3. Compilation and Upload
  • 1.Download Mode: Before burning the program to different devices, you need to enter download mode. The steps may vary depending on the mainboard. Please refer to the Arduino IDE Getting Started Guide for a list of tutorials at the bottom to see the specific operations.
  • To enter download mode on CoreS3, press and hold the reset button (for about 2 seconds) until the internal green LED lights up, then release it. The device will enter download mode, awaiting the upload.
  • 2.Select the device port, then click the compile and upload button in the upper-left corner of the Arduino IDE, and wait for the program to compile and upload to the device.
4. Current Monitoring & Power Control
You can control the power supply switch of the Unit Grove to Grove via the touchscreen, and the current value status will be displayed in real time.
