StickC-Plus Buzzer
Example
1 2 3 4 5 6 7 8 9 10
#include <M5StickCPlus.h>
    M5.Beep.tone(4000, 300);
begin
Syntax:
void begin();
Description:
  • Initialize Buzzer, this function will be called automatically when you pass M5.begin();.
Parameters:
  • null
Return:
  • null
update
Syntax:
void update();
Description:
  • Update Buzzer Play status, for the function which set Play duration, need to call this function continuously to update the status. This function will be called automatically when you pass M5.update();.
Parameters:
  • null
Return:
  • null
end
Syntax:
void end();
Description:
  • Inverse initialization, free Buzzer IO resources.
Parameters:
  • null
Return:
  • null
mute
Syntax:
void mute();
Description:
  • Mute Play
Parameters:
  • null
Return:
  • null
tone
Syntax:
void tone(uint16_t frequency);
void tone(uint16_t frequency, uint32_t duration);
Description:
  • Control of tone frequency
Parameters:
  • uint16_t frequency:
    • tone frequency
  • uint32_t duration:
    • duration time
Return:
  • null
beep
Syntax:
void beep();
Description:
  • Controlled audible beep, default audible frequency 4000Hz, duration 100ms
Parameters:
  • null
Return:
  • null
setBeep
Syntax:
void setBeep(uint16_t frequency, uint16_t duration);
Description:
  • Configuring parameters for the Beep tone
Parameters:
    • beep frequency
    • beep duration
Return:
  • null
write
Syntax:
void write(uint8_t value);
Description:
  • Write Buzzer Driver DAC Analog Values
Parameters:
  • uint8_t value:
    • DAC Analog Value
Return:
  • null
setVolume
Syntax:
void setVolume(uint8_t volume);
Description:
  • Sets the Play volume, valid only for the playMusic function.
Parameters:
  • uint8_t volume:
    • volume
Return:
  • null
playMusic
Syntax:
void playMusic(const uint8_t *music_data, uint16_t sample_rate);
Description:
  • Play of raw PCM audio data
Parameters:
  • const uint8_t *music_data:
    • Play Data Pointer
  • uint16_t sample_rate:
    • Play data sample rate
Return:
  • null
