Unit CamS3-5MP Arduino Program Compilation & Upload
  1. Arduino IDE Installation: Refer to the Arduino IDE Installation Guide and finish installing the IDE.
  2. Board Manager Setup: Open Arduino IDE and click File > Preferences (Windows) or Arduino IDE > Preferences (macOS).
  1. Enter the following in the Additional Boards Manager URLs box:
https://espressif.github.io/arduino-esp32/package_esp32_index.json
  • Click Board Manager on the sidebar, search for esp32, and install the latest version of esp32 by Espressif Systems.
  1. Hardware Connection:
  1. Detect Hardware Version:
    Unit CamS3-5MP has two hardware versions. We need to run a snippet to detect the version.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
#include <Wire.h>
#define SIOD_GPIO_NUM 17
#define SIOC_GPIO_NUM 41
  Wire.begin(SIOD_GPIO_NUM, SIOC_GPIO_NUM);
  Serial.println("\n####################");
  Serial.println("Start checking Unit CamS3-5MP hardware version");
  byte version = readRegister(0x1f, 0x0200);
  if (version == 0x01) {
    Serial.println("New Version (0x01)");
  } else if (version == 0xFF) {
    Serial.println("Old Version (0xFF)");
    Serial.print("Unknown Version: 0x");
    Serial.println(version, HEX);
byte readRegister(byte slaveAddr, unsigned int regAddr) {
  Wire.beginTransmission(slaveAddr);
  Wire.write((byte)(regAddr >> 8));
  Wire.write((byte)(regAddr & 0xFF));
  Wire.endTransmission(false);
  Wire.requestFrom(slaveAddr, (byte)1);
  if (Wire.available()) {
    return Wire.read();
  return 0x00;
Paste the above code into Arduino IDE, select the M5UnitCAMS3 board under the esp32 board package, and click the upload button in the upper-left corner.
If the upload fails, short the G0 and GND pins on the header with the provided male-to-male jumper wire before powering on to enter download mode.
After uploading, open the Serial Monitor to view the output.
If the output shows New Version (0x01), it is the new hardware version; if Old Version (0xFF) appears, it is the old hardware version.
2. Old Hardware Compatibility Handling
New hardware users can skip this step.
Install version 3.1.0 of esp32 by Espressif Systems in the Board Manager sidebar.
Download libespressif_esp32-camera.zip, extract it to obtain libespressif__esp32-camera.a, and replace the original file in the following path:
  • Windows
C:\Users\[Username]\AppData\Local\Arduino15\packages\esp32\tools\esp32-arduino-libs\idf-release_v5.3-083aad99-v2\esp32s3\lib\
  • macOS
/Users/[Username]/Library/Arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-083aad99-v2/esp32s3/lib/
  • Linux
/home/[Username]/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-083aad99-v2/esp32s3/lib/
3. Obtain the Example Program
Download CameraWebServer.zip, extract it, open CameraWebServer.ino, and enter the Wi-Fi SSID and password that Unit CamS3-5MP will connect to.
4. Program Compilation & Upload
In Arduino IDE, modify the following settings under the Tools menu:
  • Select Board: Tools -> Board -> esp32 -> M5UnitCAMS3
  • USB CDC Configuration: Tools -> USB CDC On Boot -> Enabled
  • PSRAM Configuration: Tools -> PSRAM -> OPI PSRAM
Select the correct port for the device, compile, and upload the program. The Serial Monitor should output an IP address. If nothing appears, re-plug the USB cable or verify that the baud rate is 115200.
5. Program Runtime Result
On a device in the same LAN as the Unit CamS3-5MP, open the IP address output by the program in a browser (including the http:// prefix). Click “Get Still” to capture a picture, or click “Start Stream” to view the live video stream.\
