#include <m5_module_fan.hpp>
M5ModuleFan moduleFan;
uint8_t deviceAddr = MODULE_FAN_BASE_ADDR;
uint8_t dutyCycle = 80;
bool fan_status = true;
M5Canvas canvas(&M5.Display);
canvas.createSprite(320, 240);
canvas.setFont(&fonts::FreeSerifBold12pt7b);
canvas.setTextDatum(top_center);
canvas.setTextColor(WHITE);
while (!moduleFan.begin(&Wire1, deviceAddr, 12, 11, 400000)) {
Serial.printf("Module FAN Init faile\r\n");
canvas.drawString("Module FAN Init faile", 160, 120);
canvas.pushSprite(0, 0);
// Set the fan to rotate at 80% duty cycle
moduleFan.setPWMDutyCycle(dutyCycle);
moduleFan.setPWMFrequency(PWM_48KHZ);
moduleFan.setStatus(MODULE_FAN_ENABLE);
int pwm_config_index = moduleFan.getPWMFrequency();
String pwm_config_str = "";
switch (pwm_config_index) {
case PWM_1KHZ:
pwm_config_str = "1KHz";
break;
case PWM_12KHZ:
pwm_config_str = "12KHz";
break;
case PWM_24KHZ:
pwm_config_str = "24KHz";
break;
case PWM_48KHZ:
pwm_config_str = "48KHz";
break;
canvas.setCursor(0, 10);
canvas.clear();
canvas.printf("Work Status : %s\r\n", moduleFan.getStatus() == MODULE_FAN_ENABLE ? "RUNNING" : "STOP");
canvas.printf("PWM Frequency : %s\r\n", pwm_config_str.c_str());
canvas.printf("PWM Duty Cycle : %d\r\n", moduleFan.getPWMDutyCycle());
canvas.printf("RPM : %d\r\n", moduleFan.getRPM());
auto t = M5.Touch.getDetail();
if (t.wasClicked() || M5.BtnA.wasClicked()) {
fan_status = !fan_status;
if (fan_status) {
moduleFan.setStatus(MODULE_FAN_DISABLE);
}For CoreS3, press and hold the reset button (for about 2 seconds) until the internal green LED lights up, then release it. The device is now in download mode, waiting for programming. The green LED turns off after the button is released, confirming that the device is in download mode.
Touch the screen to control the fan start and stop, while viewing the current fan speed and configuration information on the screen.
