Unit AudioPlayer Arduino Tutorial
2.Play Basic Settings
Unit AudioPlayer realizes the audio playback function by receiving instructions. The signal is output through a 3.5mm socket, providing clear audio output and supporting loop playback and combined playback. It also returns the information corresponding to the current instruction's operation through the serial port. By using the Unit AudioPlayer, we can achieve audio playback and flexible control.
Initialization and Playback Mode
  • 1.Initialization
    Use audioplayer.begin() to set the serial port for connecting the host with the Unit AudioPlayer and initialize the return status flag. The parameters to be passed in are in sequence: serial port number, signal receiving pin number, and signal sending pin number.
  • 2.Play Mode
    Using audioplayer.setPlayMode() allows you to set the song playback mode. The Unit AudioPlayer supports 7 playback modes, and the detailed information is as follows in the table:
Mode description value
AUDIO_PLAYER_MODE_ALL_LOOP Play all the songs in sequence in a loop 00
AUDIO_PLAYER_MODE_SINGLE_LOOP Loop the current song repeatedly 01
AUDIO_PLAYER_MODE_FOLDER_LOOP Play all the songs in the current folder in sequence and in a loop 02
AUDIO_PLAYER_MODE_RANDOM Randomly play the songs on the current disc 03
AUDIO_PLAYER_MODE_SINGLE_STOP Play the current song once 04
AUDIO_PLAYER_MODE_ALL_ONCE Play all songs one by one in sequence 05
AUDIO_PLAYER_MODE_FOLDER_ONCE Play all songs in the current folder once 06
Song Index Number
Using audioplayer.selectAudioNum() allows you to switch to playing the specified song. Currently, Unit AudioPlayer only supports selecting songs by index number.
Vital Note
The index number is sorted from earliest to latest based on the time when the song was saved to the SD card. The later the saving time, the larger the index number, not exactly based on the song file name.
Example:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113
#include <M5GFX.h>
#include <unit_audioplayer.hpp>
AudioPlayerUnit audioplayer;
m5::touch_detail_t touchDetail;
LGFX_Button button_pre, button_play, button_next;
    auto cfg            = M5.config();
    cfg.serial_baudrate = 115200;
    M5.begin(cfg);
    M5.Power.setExtOutput(true);
    M5.Lcd.fillScreen(WHITE);
    M5.Lcd.setTextFont(&fonts::DejaVu18);
    M5.Lcd.setTextColor(TFT_BLACK);
    M5.Display.drawString("Unit AudioPlayer Example", 0, 0);
    int8_t port_a_pin1 = -1, port_a_pin2 = -1;
    port_a_pin1 = M5.getPin(m5::pin_name_t::port_a_pin1);
    port_a_pin2 = M5.getPin(m5::pin_name_t::port_a_pin2);
    Serial.printf("getPin: RX:%d TX:%d\n", port_a_pin1, port_a_pin2);
    //To change the serial port, please modify this section.
    while (!audioplayer.begin(&Serial1, port_a_pin1, port_a_pin2)) {//Default UART Num: 1,
    Serial.println("Unit AudioPlayer is ready");
    audioplayer.setPlayMode(AUDIO_PLAYER_MODE_SINGLE_STOP);//Default Play Mode: single stop
    audioplayer.playAudio();
    audioplayer.selectAudioNum(1);//Default Audio Num: 1
    M5.Display.drawString("Audio Num:1", 0, 80);
    audioplayer.setVolume(25);
    button_pre.initButton(&M5.Lcd, 47, 215, 60, 60, TFT_WHITE, TFT_PINK, TFT_BLACK, "<", 1, 1);
    button_pre.drawButton();
    button_play.initButton(&M5.Lcd, 157, 215, 60, 60, TFT_WHITE, TFT_PINK, TFT_BLACK, ">\\||", 1, 1);
    button_play.drawButton();
    button_next.initButton(&M5.Lcd, 267, 215, 60, 60, TFT_WHITE, TFT_PINK, TFT_BLACK, ">", 1, 1);
    button_next.drawButton();
    static uint8_t lastPlayStatus = 255;
    static uint8_t lastAudioNum = 0, lastVolume = 0;
    static bool refreshAudioNum = false;
    uint8_t playStatus = audioplayer.checkPlayStatus();
    uint8_t volume     = audioplayer.getVolume();
    uint8_t audioNum   = 0;
    if (refreshAudioNum) {
        audioNum        = audioplayer.getCurrentAudioNumber();
        audioNum = lastAudioNum;
    if (playStatus != lastPlayStatus) {
        static String playStatusStr;
        if (playStatus == AUDIO_PLAYER_STATUS_PAUSED) {
            playStatusStr = "Paused";
        } else if (playStatus == AUDIO_PLAYER_STATUS_STOPPED) {
            playStatusStr = "Stopped";
        } else if (playStatus == AUDIO_PLAYER_STATUS_PLAYING) {
            playStatusStr = "Playing";
        M5.Display.fillRect(0, 40, 320, 20, WHITE);
        M5.Display.drawString("Play Status:" + playStatusStr, 0, 40);
        lastPlayStatus = playStatus;
    if (volume != lastVolume) {
        M5.Display.fillRect(0, 120, 320, 20, WHITE);
        M5.Display.drawString("Volume:" + String(volume), 0, 120);
        lastVolume = volume;
    if (audioNum != lastAudioNum && audioNum != AUDIO_PLAYER_STATUS_ERROR) {
        M5.Display.fillRect(0, 80, 320, 20, WHITE);
        M5.Display.drawString("Audio Num:" + String(audioNum), 0, 80);
        lastAudioNum = audioNum;
    touchDetail = M5.Touch.getDetail();
    if (touchDetail.isPressed()) {
        if(button_pre.contains(touchDetail.x, touchDetail.y)){
            Serial.println("Btn_pre pressed");
            audioplayer.previousAudio();
            refreshAudioNum = true;
        else if(button_play.contains(touchDetail.x, touchDetail.y)){
            Serial.println("Btn_play pressed");
                audioplayer.pauseAudio();
                Serial.println("pause_audio");
                Serial.println("play_audio");
        else if(button_next.contains(touchDetail.x, touchDetail.y)){
            Serial.println("Btn_next pressed");
            audioplayer.nextAudio();
3. Compile and Upload
  • 1.Download Mode: Before burning the program into different devices, they need to enter download mode. This step may vary depending on the main control device. Please refer to the Arduino IDE Getting Started Tutorial page for a list of specific device download tutorials and steps.
    For CoreS3, press and hold the reset button (for about 2 seconds) until the internal green LED lights up, then release it. The device will enter download mode, waiting for the firmware to be burned.
  • 2.Select the device port, click the compile and upload button in the upper-left corner of the Arduino IDE, and wait for the program to finish compiling and uploading to the device.
4.Simple Music Player
