Unit Kmeter-ISO Arduino Tutorial
1. Preparations
Dependent Libraries
The above driver libraries such as M5Unified.h and M5Unit-KmeterISO require additional dependency libraries (e.g., M5HAL, M5Utility, etc.). If you are installing via the Arduino Library Manager, please install all dependencies as prompted.
2. Example
Case Illustration
This case takes Unit KMeter-ISO as an example to collect temperature.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57
#include "M5UnitKmeterISO.h"
M5UnitKmeterISO kmeter;
auto& lcd = M5.Display;
uint8_t error_status = 0;
long delay_time = 0;
    M5.Display.setTextColor(YELLOW);
    M5.Display.setTextSize(1);
    M5.Display.setCursor(0, 0);
    M5.Display.clear();
    while (!kmeter.begin(&Wire, KMETER_DEFAULT_ADDR, pin_num_sda, pin_num_scl, 100000L)) {
        Serial.println("Unit KmeterISO not found");
    M5.Display.clear();
    // Serial.println("ok");
    if (millis() > delay_time) {
        error_status = kmeter.getReadyStatus();
        if (error_status == 0) {
            M5.Display.printf("Celsius Temp:  %.2fC\r\n",
                          ((float)(kmeter.getCelsiusTempValue())) / 100);
            M5.Display.printf("Fahrenheit Temp:  %.2fF\r\n",
                          ((float)(kmeter.getFahrenheitTempValue())) / 100);
            M5.Display.printf(
                "Chip Celsius Temp:  %.2fC\r\n",
                ((float)(kmeter.getInternalCelsiusTempValue())) / 100);
            M5.Display.printf(
                "Chip Fahrenheit Temp:  %.2fF\r\n",
                ((float)(kmeter.getInternalFahrenheitTempValue())) / 100);
            M5.Display.print(kmeter.getReadyStatus());
3. Compile and Upload
    1. Download Mode:
      Before programming, different devices need to enter download mode, and the procedure may vary depending on the main controller. For details, please refer to the device programming download tutorials listed at the bottom of the Arduino IDE Quick Start Guide.
    • For CoreS3, press and hold the reset button (for about 2 seconds) until the internal green LED lights up, then release it. The device will then enter download mode and await programming. The green LED turns off after the button is released, confirming that the device is in download mode.
    1. Select the Device Port:
      Click the compile and upload button at the top left of the Arduino IDE, and wait for the program to compile and be uploaded to the device.
4. Temperature collection
