CONTINUE.
New Device Setup to enter the device creation wizard.
NEXT.
ESP32S3.
SKIP to skip the encryption key setup.
EDIT to open the YAML editor and customize the device configuration.
esp32:
variant: esp32s3
flash_size: 8MB
cpu_frequency: 240MHz
framework:
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
psram:
mode: octal
speed: 80MHz
i2c:
- id: bsp_bus
sda:
number: GPIO45
ignore_strapping_warning: true
scl:
number: GPIO0
scan: true
- id: ext_bus
sda: GPIO38
scl: GPIO39 i2s_audio:
- id: i2s_audio_bus
i2s_lrclk_pin: GPIO6
i2s_bclk_pin: GPIO8
audio_dac:
- platform: es8311
i2c_id: ext_bus
bits_per_sample: 16bit
sample_rate: 48000
use_microphone: false
use_mclk: false
speaker:
- platform: i2s_audio
i2s_audio_id: i2s_audio_bus
i2s_dout_pin: GPIO5
dac_type: external
audio_dac: es8311_dac
sample_rate: 48000
channel: left media_player:
- platform: speaker
volume_min: 0.5
volume_max: 0.8
announcement_pipeline:
speaker: i2s_speaker
format: FLAC
sample_rate: 48000
num_channels: 1 spi:
clk_pin: GPIO15
mosi_pin: GPIO21
font:
- file: "gfonts://Roboto"
size: 14 Add pi4ioe5v6408 component
Add switch component
pi4ioe5v6408:
- id: pi4ioe5v6408_hub
i2c_id: ext_bus
address: 0x43
switch:
- platform: gpio
pin:
pi4ioe5v6408: pi4ioe5v6408_hub
number: 0
mode:
output: true
icon: "mdi:volume-high"
restore_mode: RESTORE_DEFAULT_ON lp5562:
i2c_id: bsp_bus
use_internal_clk: true
white_current: 17.5
output:
- platform: lp5562
lp5562_id: lp5562_led
channel: white
light:
- platform: monochromatic
name: "LCD Backlight"
output: lp5562_white_channel
icon: "mdi:television"
display:
- platform: mipi_spi
model: ST7789V
dc_pin: GPIO42
reset_pin: GPIO48
cs_pin: GPIO14
data_rate: 40MHz
update_interval: 1s
dimensions:
height: 128
width: 128
offset_width: 2
offset_height: 1
invert_colors: true
rotation: 180°
lambda: |-
it.fill(Color::BLACK);
it.print(
it.get_width() / 2,
it.get_height() / 2,
id(font_medium),
Color::WHITE,
TextAlign::CENTER,
"Audio-3.5 Base"
); After editing the YAML configuration, click SAVE in the top right, then click INSTALL.
In the popup dialog, select Manual Download.
Download and choose Factory format (Previously Modern) to save the firmware file locally.
CONNECT.
INSTALL.
Settings > Devices & Services to open the integration management page.
Discovered area, click CONFIGURE, and follow the prompts to complete the addition.
