Unit AC Measure Home Assistant Integration
This tutorial will introduce how to use the Unit AC Measure AC electrical parameter measurement unit with the AtomS3R main controller and integrate it into Home Assistant to achieve real-time monitoring of AC voltage, current, active power, and energy consumption.
Environment Setup
  1. Install Home Assistant 2026.2.0 or later by following the official Home Assistant documentation.
  2. Install the ESPHome Device Builder add-on by following the official ESPHome documentation. This tutorial uses ESPHome 2026.2.2 or later.
Hardware Products
2. Firmware Build & Flash
Build Time
The first build may take some time, depending on the performance of the Home Assistant host and network quality.
Create Device
  1. Open the ESPHome Dashboard. If the initial guidance interface appears, click CONTINUE.
  1. Click the green + button in the lower right corner to start creating a new device.
  1. Click New Device Setup to enter the device creation wizard.
  1. Enter the device name and click NEXT.
  1. Select the device type, click ESP32S3.
  1. Click SKIP to skip the encryption key setting.
  1. Click EDIT to enter the YAML configuration page and customize device functions.
Modify Configuration
External Components Configuration
Add the External Components configuration in the YAML file to load the unit_acmeasure sensor driver.
external_components:
    components: unit_acmeasure
    refresh: 0s
I2C Bus Configuration
Add the I2C component to configure the communication pins between Unit AC Measure and AtomS3R.
i2c:
  sda: GPIO2
  scl: GPIO1
  scan: true
The PORT.A interface of AtomS3R corresponds to SDA: GPIO2, SCL: GPIO1. If using other ports, please adjust according to the actual pins.
Sensor Configuration
Add the Sensor component to enable AC measurement-related sensor entities.
  - platform: unit_acmeasure
    address: 0x42
    update_interval: 2s
    voltage:
    current:
    power:
    apparent_power:
    power_factor:
    energy:
Main Parameter Descriptions:
Parameter Value Description
address 0x42 I2C address of Unit AC Measure.
update_interval 2s Time interval for updating AC measurement values to Home Assistant.
voltage AC Voltage Reports the AC voltage (RMS) of the measured circuit.
current AC Current Reports the AC current (RMS).
power Active Power Reports the active power in Watts (W).
apparent_power Apparent Power Reports the apparent power in Volt-Amperes (VA).
power_factor Power Factor Reports the power factor (ratio of active power to apparent power).
energy Energy Reports the accumulated energy consumption.
Compile Firmware
  1. After completing the YAML modification, click SAVE in the upper right corner to save the configuration, then click INSTALL.
  1. Select Manual Download in the pop-up window.
  1. Wait for the firmware compilation to complete, click Download and select Factory format (Previously Modern) to save the firmware locally.
Tip
The complete example configuration can be found at Unit AC Measure. The first build may take some time depending on the performance and network environment of the Home Assistant host.
Flash Firmware
  1. Connect AtomS3R to the computer using a USB Type-C cable. Open ESPHome Web and click CONNECT.
  1. In the pop-up serial port selection window, select the correct serial port number.
  1. Click INSTALL.
  1. Select the firmware file downloaded in step 3 and start flashing.
Important
The device must be reset after flashing is complete; otherwise, the firmware may not start normally.
3. Getting Started
  1. In Home Assistant, click Settings > Devices & Services in sequence to enter the integration management page.
  1. Find the Unit AC Measure device in the Discovered area, click CONFIGURE, and follow the wizard to complete the configuration.
  1. After the device is added, multiple sensor entities can be seen on the device details page, such as AC Voltage, AC Current, Active Power, Apparent Power, Power Factor, and Energy, along with their real-time values.
  1. Finally, add these sensor entities to the dashboard to monitor AC electrical parameters and power consumption in real-time.
