本教程将介绍如何使用 Chain DualKey 可编程双键开发板集成至 Home Assistant,实现按键与扩展模块控制。
ESPHome 2025.1.2 版本编写,如遇编译错误,建议先切换至该版本进行验证。)
本小节将说明如何基于 yaml 配置文件重新编译项目,便于二次开发、功能修改或新增功能。
CONTINUE。
New Device Setup。
NEXT。
ESP32-S3。
SKIP。
EDIT 编辑 YAML 文件,通过 YAML 文件自定义设备功能。
Master 作为系统的主控制器。在连接扩展传感器时,需要正确区分连接方向以及 ID 编号顺序。
根据扩展传感器连接在 Master 的哪一侧,选择对应的 uart_id:
chain_uart_left。chain_uart_right。chain_id 表示扩展传感器相对于 Master 的位置:
uart_id: chain_uart_left。chain_id: 1。uart:
- id: chain_uart_right
tx_pin: GPIO6
rx_pin: GPIO5
baud_rate: 115200
- id: chain_uart_left
tx_pin: GPIO48
rx_pin: GPIO47
baud_rate: 115200
- platform: adc
pin: GPIO10
update_interval: 1s
- platform: adc
pin: GPIO2
update_interval: 1s
- platform: adc
pin: GPIO9
update_interval: 1s
output:
- platform: gpio
pin: GPIO40
light:
internal: true
pin: GPIO21
num_leds: 2
chipset: ws2812
rgb_order: GRB
restore_mode: ALWAYS_OFF
- platform: partition
name: "Key Light 1"
segments:
- id: key_light_raw
to: 0
name: "Key Light 2"
segments:
- id: key_light_raw
to: 1
binary_sensor:
- platform: gpio
pin:
number: GPIO17
inverted: true
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
- light.turn_on:
transition_length: 0ms
on_release:
- light.turn_off: key_light_2
- platform: gpio
pin:
number: GPIO0
inverted: true
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
- light.turn_on:
on_release:
- light.turn_off: key_light_1
- platform: gpio
pin:
number: GPIO7
mode: INPUT
- platform: gpio
pin:
number: GPIO8
mode: INPUT external_components:
components: [m5stack_chain_key]
refresh: 0s
binary_sensor:
- platform: m5stack_chain_key
name: "Chain Key Button"
uart_id: xx
chain_id: xx
update_interval: 50ms
output:
chain_key_id: chain_key_1
channel: rgb_red
channel: rgb_green
channel: rgb_blue
light:
- platform: rgb
red: chain_key_rgb_r
green: chain_key_rgb_g
blue: chain_key_rgb_b external_components:
components: [m5stack_chain_angle]
refresh: 0s
- platform: m5stack_chain_angle
uart_id: xx
chain_id: xx
output:
chain_angle_id: chain_angle_1
channel: rgb_red
channel: rgb_green
channel: rgb_blue
light:
- platform: rgb
red: chain_angle_rgb_r
green: chain_angle_rgb_g
blue: chain_angle_rgb_b external_components:
components: [m5stack_chain_encoder]
refresh: 0s
- platform: m5stack_chain_encoder
uart_id: xx
chain_id: xx
update_interval: 100ms
output:
chain_encoder_id: chain_encoder_1
channel: rgb_red
channel: rgb_green
channel: rgb_blue
light:
- platform: rgb
red: chain_encoder_rgb_r
green: chain_encoder_rgb_g
blue: chain_encoder_rgb_b
binary_sensor:
chain_encoder_id: chain_encoder_1 external_components:
components: [m5stack_chain_joystick]
refresh: 0s
- platform: m5stack_chain_joystick
name: "Chain Joystick X"
uart_id: xx
chain_id: xx
axis: x
name: "Chain Joystick Y"
uart_id: xx
chain_id: xx
axis: y
output:
chain_joystick_id: chain_joystick_x
channel: rgb_red
channel: rgb_green
channel: rgb_blue
light:
- platform: rgb
red: chain_joystick_rgb_r
green: chain_joystick_rgb_g
blue: chain_joystick_rgb_b
binary_sensor:
chain_joystick_id: chain_joystick_x external_components:
components: [m5stack_chain_tof]
refresh: 0s
- platform: m5stack_chain_tof
uart_id: xx
chain_id: xx
output:
m5stack_chain_tof_id: chain_tof_1
channel: rgb_red
channel: rgb_green
channel: rgb_blue
light:
- platform: rgb
red: chain_tof_rgb_r
green: chain_tof_rgb_g
blue: chain_tof_rgb_b 下面的代码示例是根据上图所示的连接顺序进行配置的。
使用的模块:Chain Angle、Chain Encoder、Chain ToF、Chain Joystick、Chain Key。
components:
m5stack_chain_angle,
m5stack_chain_encoder,
m5stack_chain_tof,
m5stack_chain_joystick,
m5stack_chain_key,
refresh: 0s 使用的模块:主控左 / 右侧 HY2.0 接口上的所有 Chain 系列模块共用的 UART 总线。
chain_uart_right 和 chain_uart_left 分别对应主控右侧和左侧的 HY2.0 接口。后续 Chain 模组的 uart_id 需要与实际连接方向保持一致。captive_portal:
uart:
tx_pin: GPIO6
rx_pin: GPIO5
baud_rate: 115200
tx_pin: GPIO48
rx_pin: GPIO47
baud_rate: 115200 使用的模块:Chain Encoder、Chain Angle、Chain ToF、Chain Joystick(X/Y)、DualKey 电池相关 ADC 传感器。
uart_id: chain_uart_right
chain_id: 1
name: "ToF Distance"
chain_id: 3
chain_id: 2
chain_id: 1
axis: x
chain_id: 1
axis: y
- platform: adc
pin: GPIO10
update_interval: 1s
- platform: adc
pin: GPIO2
update_interval: 1s
- platform: adc
pin: GPIO9
update_interval: 1s 使用的模块:Chain Encoder、Chain Key、Chain Joystick、Chain Angle、Chain ToF 的 RGB 灯以及 DualKey 的电源控制。
pwr_en GPIO 输出用于控制 Chain 扩展总线的供电,通常需要保持开启,以保证连接在总线上的模块可以正常工作。output:
- platform: gpio
pin: GPIO40
channel: rgb_red
channel: rgb_green
channel: rgb_blue
channel: rgb_red
channel: rgb_green
channel: rgb_blue
channel: rgb_red
channel: rgb_green
channel: rgb_blue
channel: rgb_red
channel: rgb_green
channel: rgb_blue
channel: rgb_red
channel: rgb_green
channel: rgb_blue 使用的模块:DualKey 上的 WS2812 按键灯,以及各 Chain 模组上的 RGB 指示灯。
key_light_raw 分区成 key_light_1 和 key_light_2),同时也为各个 Chain 模组定义了对应的 RGB 灯光实体,方便在 Home Assistant 中分别控制。light:
internal: true
pin: GPIO21
num_leds: 2
chipset: ws2812
rgb_order: GRB
segments:
- id: key_light_raw
to: 1
segments:
- id: key_light_raw
to: 0
- platform: rgb
- platform: rgb
- platform: rgb
- platform: rgb
- platform: rgb
blue: chain_tof_rgb_b 使用的模块:DualKey 上的机械按键和侧边拨码开关,以及 Chain Key、Chain Encoder、Chain Joystick 上的按键。
KEY 1、KEY 2)及其对应的背光联动、总线上一个 Chain Key 模组的按键、编码器按键、摇杆按键,以及两个侧边开关(SWITCH 1、SWITCH 2)。你可以根据实际使用场景在 Home Assistant 中重命名这些实体。binary_sensor:
- platform: gpio
pin:
number: GPIO17
inverted: true
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
- light.turn_on:
on_release:
- platform: gpio
pin:
number: GPIO0
inverted: true
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- delayed_off: 10ms
on_press:
- light.turn_on:
on_release:
name: "Key Module Button"
chain_id: 2
- platform: gpio
pin:
number: GPIO7
mode: INPUT
- platform: gpio
pin:
number: GPIO8
mode: INPUT SAVE 和 INSTALL,在弹出的对话框中选择 Manual Download。
Download,并选择 Factory format(Previously Modern) 选项下载固件。
CONNECT 连接设备。
INSTALL。
Settings > Devices & Services 查看设备。
Discovered 区域中找到对应的设备。
