git clone https://huggingface.co/AXERA-TECH/Qwen3-1.7B
ファイル説明
m5stack@raspberrypi:~/rsp/Qwen3-1.7B$ ls -lh
total 4.4M
-rw-rw-r-- 1 m5stack m5stack 0 Aug 12 09:07 config.json
-rw-rw-r-- 1 m5stack m5stack 959K Aug 12 09:10 main_ax650
-rw-rw-r-- 1 m5stack m5stack 1.7M Aug 12 09:10 main_axcl_aarch64
-rw-rw-r-- 1 m5stack m5stack 1.8M Aug 12 09:10 main_axcl_x86
-rw-rw-r-- 1 m5stack m5stack 277 Aug 12 09:07 post_config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 09:07 qwen2.5_tokenizer
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 09:10 qwen3-1.7b-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 09:10 qwen3_tokenizer
-rw-rw-r-- 1 m5stack m5stack 7.6K Aug 12 09:07 qwen3_tokenizer_uid.py
-rw-rw-r-- 1 m5stack m5stack 12K Aug 12 09:07 README.md
-rw-rw-r-- 1 m5stack m5stack 2.5K Aug 12 09:07 run_qwen3_1.7b_int8_ctx_ax650.sh
-rw-rw-r-- 1 m5stack m5stack 2.5K Aug 12 09:07 run_qwen3_1.7b_int8_ctx_axcl_aarch64.sh
-rw-rw-r-- 1 m5stack m5stack 2.5K Aug 12 09:07 run_qwen3_1.7b_int8_ctx_axcl_x86.sh
python -m venv qwen
source qwen/bin/activate
pip install transformers jinja2 torch
python qwen3_tokenizer_uid.py --port 12345
(qwen) m5stack@raspberrypi:~/Qwen3-0.6B $ python qwen3_tokenizer_uid.py --port 12345
chmod +x main_axcl_aarch64 run_qwen3_1.7b_int8_ctx_axcl_aarch64.sh
./run_qwen3_1.7b_int8_ctx_axcl_aarch64.sh
起動成功時の表示例:
m5stack@raspberrypi:~/rsp/Qwen3-1.7B$ ./run_qwen3_1.7b_int8_ctx_axcl_aarch64.sh
[I][ Init][ 136]: LLM init start
[I][ Init][ 34]: connect http://127.0.0.1:12345 ok
[I][ Init][ 57]: uid: 95e7d5f3-fc8d-48ea-b489-1de9f37924d1
bos_id: -1, eos_id: 151645
3% | ██ | 1 / 31 [1.08s<33.54s, 0.92 count/s] tokenizer init ok[I][ Init][ 45]: LLaMaEmbedSelector use mmap
6% | ███ | 2 / 31 [1.08s<16.77s, 1.85 count/s] embed_selector init ok
[I][ run][ 30]: AXCLWorker start with devid 0
100% | ████████████████████████████████ | 31 / 31 [64.75s<64.75s, 0.48 count/s] init post axmodel ok,remain_cmm(3788 MB)
[I][ Init][ 237]: max_token_len : 2559
[I][ Init][ 240]: kv_cache_size : 1024, kv_cache_num: 2559
[I][ Init][ 248]: prefill_token_num : 128
[I][ Init][ 252]: grp: 1, prefill_max_token_num : 1
[I][ Init][ 252]: grp: 2, prefill_max_token_num : 512
[I][ Init][ 252]: grp: 3, prefill_max_token_num : 1024
[I][ Init][ 252]: grp: 4, prefill_max_token_num : 1536
[I][ Init][ 252]: grp: 5, prefill_max_token_num : 2048
[I][ Init][ 256]: prefill_max_token_num : 2048
________________________
| ID| remain cmm(MB)|
| 0| 3788|
[I][ load_config][ 282]: load config:
"enable_temperature": false,
"penalty_window": 20,
"repetition_penalty": 1.2,
"temperature": 0.9,
"top_k": 1,
"top_p": 0.8
[I][ Init][ 279]: LLM init ok
[I][ GenerateKVCachePrefill][ 335]: input token num : 21, prefill_split_num : 1 prefill_grpid : 2
[I][ GenerateKVCachePrefill][ 372]: input_num_token:21
[I][ main][ 236]: precompute_len: 21
[I][ main][ 237]: system_prompt: You are Qwen, created by Alibaba Cloud. You are a helpful assistant.
prompt >> hello
[I][ SetKVCache][ 628]: prefill_grpid:2 kv_cache_num:512 precompute_len:21 input_num_token:12
[I][ SetKVCache][ 631]: current prefill_max_token_num:1920
[I][ Run][ 869]: input token num : 12, prefill_split_num : 1
[I][ Run][ 901]: input_num_token:12
[I][ Run][1030]: ttft: 796.38 ms
<think>
</think>
[N][ Run][1182]: hit eos,avg 7.38 token/s
[I][ GetKVCache][ 597]: precompute_len:46, remaining:2002
prompt >>
