Input & Output Devices
Audio Playback Devices
FAQ
Device Not Found
Error code 0x8030010b
m5stack@raspberrypi:~ $ axcl-smi
[08-11 16:01:16:933][E][smi][device_manager][  20]: axcl init fail, ret = 0x8030010b
[2025-08-11 16:01:16.933][2110][E][device manager][init][39]: open /dev/axcl_host fail, errno: 2 No such file or directory
| AXCL-SMI  V3.6.3_20250722020142                                  Driver  V3.6.3_20250722020142 |
| Card  Name                     Firmware                                                          | Bus-Id       | Memory-Usage |
| Fan   Temp                Pwr:Usage/Cap                                                          | CPU      NPU | CMM-Usage    |
| Processes:        |
| Card      PID  Process Name                                                   NPU Memory Usage   |
Troubleshooting steps:
  • Use ls pci to check if the device Multimedia video controller: Axera Semiconductor Co., Ltd Device 0650 (rev 01) is present.
  • Check if the LLM-8850 Card is properly seated; disconnect power to the Raspberry Pi and restart.
  • Uninstall and reinstall the driver.
