Input & Output Devices
Audio Playback Devices
SuperResolution
SuperResolution is a model that transforms low-resolution images into high-resolution images through deep learning or other algorithms, aimed at enhancing image details and visual quality.
  1. Manually download the model and upload it to raspberrypi5, or pull the model repository via the following command.
If git lfs is not installed, please refer to git lfs installation guide for installation.
git clone https://huggingface.co/AXERA-TECH/SuperResolution
File Description:
m5stack@raspberrypi:~/rsp/SuperResolution $ ls -lh
total 20K
-rw-rw-r-- 1 m5stack m5stack 3.8K Sep  4 18:49 config.json
drwxrwxr-x 4 m5stack m5stack 4.0K Sep  4 18:49 model_convert
drwxrwxr-x 5 m5stack m5stack 4.0K Sep  4 19:12 python
-rw-rw-r-- 1 m5stack m5stack 2.3K Sep  4 18:49 README.md
drwxrwxr-x 2 m5stack m5stack 4.0K Sep  4 19:03 video
    python -m venv sr
  2. Activate the virtual environment
    source sr/bin/activate
  3. Install dependencies
    pip install opencv-python torch torchvision tqdm scikit-image
  4. Run
    python python/run_axmodel.py --model model_convert/axmodel/edsr_baseline_x2_1.axmodel --dir_demo video/test_1920x1080.mp4
Execution result:
(sr) m5stack@raspberrypi:~/rsp/SuperResolution $ python python/run_axmodel.py --model model_convert/axmodel/edsr_baseline_x2_1.axmodel --dir_demo video/test_1920x1080.mp4
[INFO] SOC Name: AX650N
[INFO] Compiler version: 4.2 6bff2f67
100%|█████████████████████████████████████████| 267/267 [06:21<00:00,  1.43s/it]
Total time: 275.618 seconds for 267 frames
Average time: 1.032 seconds for each frame
Original video screenshot:
Output video screenshot:
