Input & Output Devices
Audio Playback Devices
LivePortrait
LivePortrait is a deep learning-based portrait-driven generation model that can transform static portraits into dynamic videos with realistic expressions and movements.
If git lfs is not installed, please refer to git lfs Installation Instructions for installation.
git clone https://huggingface.co/AXERA-TECH/LivePortrait
File Description:
m5stack@raspberrypi:~/rsp/LivePortrait $ ls -lh
total 16K
drwxrwxr-x 3 m5stack m5stack 4.0K Aug 13 09:41 assets
-rw-rw-r-- 1 m5stack m5stack    0 Aug 13 09:41 config.json
drwxrwxr-x 5 m5stack m5stack 4.0K Aug 13 09:41 python
-rw-rw-r-- 1 m5stack m5stack 5.7K Aug 13 09:41 README.md
  1. Create virtual environment
python -m venv lvpr
  1. Activate virtual environment
source lvpr/bin/activate
  1. Install dependencies
pip install -r python/requirements.txt
pip install requests tqdm
Run:
python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d8.jpg --models ./python/axmodels/ --output-dir ./axmodel_infer
Run result:
(lvpr) m5stack@raspberrypi:~/rsp/LivePortrait $ python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d8.jpg --models ./python/axmodels/ --output-dir ./axmodel_infer
[INFO] SOC Name: AX650N
[INFO] Compiler version: 3.3 144960ad
[INFO] Compiler version: 3.3 0f7260e8
FaceAnalysisDIY warmup time: 0.237s
LandmarkRunner warmup time: 0.183s
2025-08-13 10:04:42.914 | INFO     | __main__:main:727 - Start making driving motion template...
2025-08-13 10:04:43.782 | INFO     | __main__:main:747 - Prepared pasteback mask done.
2025-08-13 10:04:44.565 | INFO     | __main__:main:787 - The output of image-driven portrait animation is an image.
2025-08-13 10:04:50.566 | DEBUG    | __main__:warp_decode:647 - warp time: 5.997s
2025-08-13 10:04:50.902 | INFO     | __main__:main:881 - Animated image: ./axmodel_infer/s0--d8.jpg
2025-08-13 10:04:50.902 | INFO     | __main__:main:882 - Animated image with concat: ./axmodel_infer/s0--d8_concat.jpg
2025-08-13 10:04:50.920 | DEBUG    | __main__:<module>:894 - LivePortrait axmodel infer time: 18.068s
Original Image:
Output:
Video
Run:
python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d0.mp4 --models ./python/axmodels/ --output-dir ./axmodel_infer
Run result:
(lvpr) m5stack@raspberrypi:~/rsp/LivePortrait $ python ./python/infer.py --source ./assets/examples/source/s0.jpg --driving ./assets/examples/driving/d0.mp4 --models ./python/axmodels/ --output-dir ./axmodel_infer
FaceAnalysisDIY warmup time: 0.213s
LandmarkRunner warmup time: 0.180s
2025-08-13 10:14:47.779 | INFO     | __main__:main:727 - Start making driving motion template...
2025-08-13 10:15:04.110 | INFO     | __main__:main:747 - Prepared pasteback mask done.
2025-08-13 10:15:04.903 | INFO     | __main__:main:785 - The animated video consists of 78 frames.
2025-08-13 10:15:11.468 | DEBUG    | __main__:warp_decode:647 - warp time: 6.561s
2025-08-13 10:25:50.630 | DEBUG    | __main__:warp_decode:647 - warp time: 8.343s
2025-08-13 10:25:51.493 | INFO     | __main__:has_audio_stream:114 - Error occurred while probing video: ./assets/examples/driving/d0.mp4, you may need to install ffprobe! (https://ffmpeg.org/download.html) Now set audio to false!
2025-08-13 10:25:54.608 | INFO     | __main__:main:870 - Animated video: ./axmodel_infer/s0--d0.mp4
2025-08-13 10:25:54.609 | INFO     | __main__:main:871 - Animated video with concat: ./axmodel_infer/s0--d0_concat.mp4
2025-08-13 10:25:54.644 | DEBUG    | __main__:<module>:894 - LivePortrait axmodel infer time: 670.930s
Original Video:
Output:
