Input & Output Devices
Audio Playback Devices
T-LiTe User Manual
Product Introduction
T-Lite is an integrated online thermal imaging temperature measurement device, composed of M5StickC-Plus and HAT THERMAL, equipped with an MLX90640 infrared sensor and ESP32 microcontroller, supporting Wi-Fi, paired with a 135×240 screen and a 160mAh battery. It features high-temperature alerts, supports real-time data viewing via cloud/LAN, and can be applied in scenarios such as temperature detection alerts and biological movement monitoring.
Basic Operations
Power On/Off
  • Single-click PWR to power on.
  • Long-press PWR to power off.
Switching Preview Modes
T-Lite supports switching UI layouts, temperature color display modes, and temperature value display modes.
  • Switch UI Layout Mode: Long-press Button B.
  • Switch Temperature Color Display Mode: Single-click Button A.
  • Switch Temperature Value Display Mode: Single-click Button B.
Entering Configuration Menu
Single-click the PWR button to enter the main menu interface.
The main menu interface is as follows:
  • Network: Network settings, including operation mode, Wi-Fi settings, etc.
  • Cloud: Cloud monitoring settings, such as data upload intervals.
  • Alarm: Alert settings. Configure trigger conditions, including above/below thresholds or disabling alerts.
  • Sensor: Sensor settings, including refresh rate, noise filtering, monitor, and emissivity.
  • Range: Temperature range settings, including enabling/disabling auto-range and setting upper/lower limits.
  • Others: Additional settings, such as language, CPU frequency, buzzer volume, screen brightness, LAN video stream quality, and factory reset.
Remote Viewing
Operation Modes
T-Lite offers four modes for viewing temperature data:
  • Offline Mode: Standalone operation, only viewable on the device screen.
  • LAN Mode: Connect to Wi-Fi for local network access via IP.
  • Cloud Mode: Connect to Wi-Fi to upload image data to the Ezdata server for remote viewing.
  • LAN + Cloud Mode: Supports both LAN preview and remote image viewing.
Network Configuration
  1. Single-click the power button to turn on the device.
  2. Single-click the PWR button to enter the settings menu.
  1. Select Network and press Button A to confirm.
  2. Under Network, select Wi-Fi Setting and set it to AP mode using Button A.
  1. Connect your phone or computer to the Wi-Fi: T-Lite_xxx (default password: 12341234).
    The phone will automatically enter the Wi-Fi setup page.
  1. Enter the available Wi-Fi name and password on your phone/computer, then click Save. Wait for the device to connect to Wi-Fi.
LAN Preview
  1. After connecting to Wi-Fi, access the device via its local IP: 192.168.x.x (visible in the top menu or under LAN Monitor).
  2. Click Stream Image and enter the confirmation code to preview the current image.
Cloud Preview
  1. After connecting to Wi-Fi, select Network and press Button A.
  2. Navigate to Cloud Online QR using Button B and press Button A.
  3. Scan the QR code to access the remote image URL, then enter the confirmation code to preview.
LAN + Cloud Mode
This mode enables both LAN and cloud preview simultaneously.
Setup: After connecting to Wi-Fi, select Running Mode on the T-Lite device and set it to LAN+CLOUD using Button A. Then follow the steps for LAN and Cloud preview.
Emissivity Configuration
Adjusting emissivity based on usage scenarios improves temperature measurement accuracy.
Steps:
  1. Power on the device by pressing PWR.
  2. Press PWR to enter the settings menu.
  1. Select Sensor with Button B and press Button A.
  2. Under Sensor, navigate to Emissivity and press Button A to adjust.
  • Button A: Decrease value.
  • Button B: Increase value.
  1. Press PWR to save.
Factory Reset
This will erase all custom configurations.
  1. Power on the device with PWR.
  2. Press PWR to enter settings.
  3. Select Others with Button B and press Button A.
  4. Choose Factory Reset and confirm with Button A.
