Input & Output Devices
Audio Playback Devices
Whisper
  • This section only guides you on how to run the precompiled voice-to-text example based on Whisper Small on Raspberry Pi 5;
  • For model conversion and example source code compilation, please refer to whisper.axcl.
  1. Download
git clone https://github.com/ml-inory/whisper.axcl.git
  1. Compile
cd whisper.axcl
mkdir -p build && cd build
cmake -DCMAKE_INSTALL_PREFIX=../install -DCMAKE_BUILD_TYPE=Release ..
make install -j4
  1. Precompiled Model
Download the precompiled model from Baidu Netdisk
  1. Run Whisper
cd install
./whisper -w ../demo.wav
Execution Result:
(base) axera@raspberrypi:~/qtang/whisper.axcl/install $ ./whisper -w ../demo.wav
encoder: ../models/small-encoder.axmodel
decoder_main: ../models/small-decoder-main.axmodel
decoder_loop: ../models/small-decoder-loop.axmodel
wav_file: ../demo.wav
language: zh
Load encoder take 3336.25 ms
Load decoder_main take 6091.89 ms
Load decoder_loop take 5690.05 ms
Read positional_embedding
Encoder run take 190.26 ms
First token: 17556       take 51.49ms
Next Token: 20844        take 30.15 ms
Next Token: 7781         take 30.21 ms
Next Token: 20204        take 30.20 ms
Next Token: 28455        take 30.17 ms
Next Token: 31962        take 30.02 ms
Next Token: 6336         take 30.09 ms
Next Token: 254          take 30.22 ms
Next Token: 2930         take 30.14 ms
Next Token: 236          take 30.14 ms
Next Token: 36135        take 30.12 ms
Next Token: 15868        take 30.18 ms
Next Token: 252          take 30.01 ms
Next Token: 1546         take 30.17 ms
Next Token: 46514        take 30.17 ms
Next Token: 50257        take 30.15 ms
All Token: take 503.68ms, 31.77 token/s
All take 735.09ms
Result: Even a near standstill in trading occurred.
