Input & Output Devices
Audio Playback Devices
DeepSeek-R1-Distill-Qwen-1.5B-GPTQ-Int4
  1. Click to download the model and upload it to raspberrypi5.
File Description
m5stack@raspberrypi:~/rsp/DeepSeek-R1-Distill-Qwen-1.5B-GPTQ-Int4$ ls -lh
total 2.9M
-rw-rw-r-- 1 m5stack m5stack    0 Aug 12 10:56 config.json
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 11:00 deepseek-r1-1.5b-gptq-int4-ax650
drwxrwxr-x 2 m5stack m5stack 4.0K Aug 12 10:56 deepseek-r1_tokenizer
-rw-rw-r-- 1 m5stack m5stack 4.2K Aug 12 10:56 deepseek-r1_tokenizer.py
-rw-rw-r-- 1 m5stack m5stack 976K Aug 12 10:58 main_axcl_aarch64
-rw-rw-r-- 1 m5stack m5stack 999K Aug 12 10:58 main_axcl_x86
-rw-rw-r-- 1 m5stack m5stack 932K Aug 12 10:58 main_prefill
-rw-rw-r-- 1 m5stack m5stack  277 Aug 12 10:56 post_config.json
-rw-rw-r-- 1 m5stack m5stack 7.4K Aug 12 10:56 README.md
-rw-rw-r-- 1 m5stack m5stack  533 Aug 12 10:56 run_deepseek-r1_1.5b_gptq_int4_ax650.sh
-rw-rw-r-- 1 m5stack m5stack  538 Aug 12 10:56 run_deepseek-r1_1.5b_gptq_int4_axcl_aarch64.sh
-rw-rw-r-- 1 m5stack m5stack  534 Aug 12 10:56 run_deepseek-r1_1.5b_gptq_int4_axcl_x86.sh
python -m venv deepseek
source deepseek/bin/activate
  1. Install dependencies
  1. Start the tokenizer parser
python deepseek-r1_tokenizer.py --port 12345
  1. Run the tokenizer service — Host IP defaults to localhost, port should be set to 12345.
    Once running, you should see something like this:
(deepseek) m5stack@raspberrypi:~/rsp/DeepSeek-R1-Distill-Qwen-1.5B-GPTQ-Int4 $ python deepseek-r1_tokenizer.py --port 12345
151646 <|begin▁of▁sentence|> 151643 <|end▁of▁sentence|>
<|begin▁of▁sentence|>You are DeepSeek-R1, You are a helpful assistant.<|User|>hello world<|Assistant|>
[151646, 151646, 2610, 525, 18183, 39350, 10911, 16, 11, 1446, 525, 264, 10950, 17847, 13, 151644, 14990, 1879, 151645]
http://localhost:12345
Tip
The following steps should be done in a new terminal on the raspberrypi.
  1. Grant execute permission
chmod +x main_axcl_aarch64 run_deepseek-r1_1.5b_gptq_int4_axcl_aarch64.sh
  1. Start the DeepSeek-R1-Distill-Qwen-1.5B model inference service
./run_deepseek-r1_1.5b_gptq_int4_axcl_aarch64.sh
After successfully starting, you should see:
m5stack@raspberrypi:~/rsp/DeepSeek-R1-Distill-Qwen-1.5B-GPTQ-Int4$ ./run_deepseek-r1_1.5b_gptq_int4_axcl_aarch64.sh
bos_id: 151646, eos_id: 151643
  3% | ██                                |   1 /  31 [0.00s<0.09s, 333.33 count/s] tokenizer init
  100% | ████████████████████████████████ |  31 /  31 [28.78s<28.78s, 1.08 count/s] init post axmodel ok
[I][                            Init][ 226]: max_token_len : 1023
[I][                            Init][ 231]: kv_cache_size : 256, kv_cache_num: 1023
    "enable_temperature": true,
    "penalty_window": 20,
    "repetition_penalty": 1.2,
    "temperature": 0.9,
    "top_k": 10,
    "top_p": 0.8
>> hello
Hello! I'm DeepSeek-R1, an AI assistant ready to help you with any questions or tasks you may have. How can I assist you today?
[N][                             Run][ 610]: hit eos,avg 13.29 token/s
Model Quant Method tftt (ms) token/s
DeepSeek-R1-Distill-Qwen-1.5B-GPTQ-Int4 w4a16 - 13.29
