Input & Output Devices
Audio Playback Devices
SDK API
Overview
AXCL API is divided into two parts: the Runtime API and the Native API. The Runtime API is an independent set of APIs, currently only including Memory for memory management and Engine API for driving the Axera(TM) NPU to work. When the AXCL API is used in the form of a compute card without using codec functions, all computation tasks can be completed using only the Runtime API. When codec functions are required, you need to understand the Native API and the related contents of the FFMPEG module.
runtime
Using the Runtime API allows the NPU to be called on the host system to perform computing functions. The Memory API can allocate and free memory space on both the host and the compute card, while the Engine API can complete all NPU functionalities from model initialization and IO settings to inference.
runtime
axclInit
axclError axclInit(const char *config);
Description:
System initialization, synchronous interface.
Parameters:
  • config [IN]: Specifies the path to the JSON configuration file.
    • Users can configure system parameters through the JSON configuration file. Currently, log level settings are supported. Format refer to FAQ.
    • NULL or a non-existent JSON file can be passed, in which case the system uses the default configuration.
Limitations:
  • Must be paired with axclFinalize for system cleanup.
  • This interface must be called before invoking any AXCL interface-based application.
  • Can be called only once within a single process.
axclFinalize
axclError axclFinalize();
Description:
System de-initialization, releasing AXCL resources within the process, synchronous interface.
Limitations:
  • Must be paired with axclInit.
  • Before the application process exits, this interface should be explicitly called for de-initialization.
  • For C++ applications, it is not recommended to call this in the destructor. Otherwise, the process may exit abnormally upon termination due to an uncertain destruction order of singletons.
axclrtGetVersion
axclError axclrtGetVersion(int32_t *major, int32_t *minor, int32_t *patch);
Description:
Query the system version number, synchronous interface.
Parameters:
  • major [OUT]: Major version number.
  • minor [OUT]: Minor version number.
  • patch [OUT]: Patch version number.
Limitations:
No special restrictions.
axclrtGetSocName
const char *axclrtGetSocName();
Description:
Query the current chip SOC name string, synchronous interface.
Limitations:
axclrtSetDevice
axclError axclrtSetDevice(int32_t deviceId);
Description:
Specify the device in the current process or thread, while implicitly creating a default Context, synchronous interface.
Parameters:
  • deviceId [IN]: Device ID.
Limitations:
  • This interface implicitly creates a default Context internally, which is automatically released by the system in axclrtResetDevice and must not be explicitly destroyed using axclrtDestroyContext.
  • In multiple threads within the same process, if the deviceId specified in this interface is the same, the implicitly created Context will also be the same.
  • Must be paired with axclrtResetDevice to release the device resources used by this process; internally uses reference counting to allow multiple calls, and only releases resources when the reference count reaches 0.
  • In a multi-device scenario, you can switch devices within the process using this interface or axclrtSetCurrentContext.
axclrtResetDevice
axclError axclrtResetDevice(int32_t deviceId);
Description:
Reset the device and release resources on the device, including both implicitly and explicitly created Contexts, synchronous interface.
Parameters:
Limitations:
  • For Contexts explicitly created using axclrtCreateContext, it is recommended to explicitly destroy them using axclrtDestroyContext before calling this interface to release device resources.
  • Must be paired with axclrtSetDevice; the system will automatically reclaim default Context resources.
  • Internally uses reference counting to allow multiple calls, and only releases resources when the reference count reaches 0.
  • When the application process exits, make sure axclrtResetDevice is called, especially after handling exception signals; otherwise, this may cause a C++ terminated abort exception.
axclrtGetDevice
axclError axclrtGetDevice(int32_t *deviceId);
Description:
Get the current device ID in use, synchronous interface.
Parameters:
  • deviceId [OUT]: Device ID.
Limitations:
axclrtGetDeviceCount
axclError axclrtGetDeviceCount(uint32_t *count);
Description:
Get the total number of connected devices, synchronous interface.
Parameters:
  • count [OUT]: Number of devices.
Limitations:
axclrtGetDeviceList
axclError axclrtGetDeviceList(axclrtDeviceList *deviceList);
Description:
Get the IDs of all connected devices, synchronous interface.
Parameters:
  • deviceList [OUT]: Information of all connected device IDs.
Limitations:
axclrtSynchronizeDevice
axclError axclrtSynchronizeDevice();
Description:
Synchronously execute all tasks on the current device, synchronous interface.
Limitations:
At least one device must be active.
axclrtGetDeviceProperties
axclError axclrtGetDeviceProperties(int32_t deviceId, axclrtDeviceProperties *properties);
Description:
Retrieve information such as device UID, CPU usage, NPU usage, and memory, synchronous interface.
Limitations:
axclrtCreateContext
axclError axclrtCreateContext(axclrtContext *context, int32_t deviceId);
Description:
Explicitly create a Context in the current thread, synchronous interface.
Parameters:
  • context [OUT]: Handle for the created Context.
Limitations:
  • If a user-created sub-thread needs to call the AXCL API, it must explicitly create a Context using this interface or bind one using axclrtSetCurrentContext.
  • If the specified device has not been activated, this interface will activate it first internally.
  • Call axclrtDestroyContext to explicitly release Context resources.
  • Multiple threads can share the same Context (bound by axclrtSetCurrentContext), but task execution depends on the system’s thread scheduling order. Users must manage and maintain execution synchronization order between threads themselves. For multi-threading, it is recommended to create a dedicated Context for each thread to improve maintainability.
axclError axclrtDestroyContext(axclrtContext context);
Description:
Explicitly destroy a Context, synchronous interface.
Parameters:
  • context [IN]: Handle for the created Context.
Limitations:
axclError axclrtSetCurrentContext(axclrtContext context);
Description:
Bind the Context for a thread to run with, synchronous interface.
Parameters:
  • context [IN]: Context handle.
Limitations:
  • If this interface is called multiple times to bind a Context to a thread, the last binding takes precedence.
  • If the device corresponding to the bound Context has been reset using axclrtResetDevice, the Context cannot be set for the thread, otherwise exceptions will occur.
  • It is recommended to use the Context in the same thread where it was created. If axclrtCreateContext is called in Thread A and the Context is used in Thread B, the user must ensure the task execution order under the same Context is maintained between the two threads.
axclrtGetCurrentContext
axclError axclrtGetCurrentContext(axclrtContext *context);
Description:
Get the Context handle bound to the thread, synchronous interface.
Parameters:
  • context [OUT]: The current Context handle.
Limitations:
memory
axclrtMalloc
axclError axclrtMalloc(void **devPtr, size_t size, axclrtMemMallocPolicy policy);
Description:
Allocate non-CACHED physical memory on the device side. The allocated memory pointer is returned via devPtr, synchronous interface.
Parameters:
  • devPtr [OUT]: Pointer to the allocated device-side physical memory.
  • size [IN]: Size of the allocated memory in bytes.
  • policy [IN]: Memory allocation policy, currently unused.
Limitations:
  • Allocates continuous physical memory from the device-side CMM memory pool.
  • Allocates non-CACHED memory, no consistency handling is required.
  • Use axclrtFree to release memory.
  • Frequent allocation and release will impact performance; it is recommended to use pre-allocation or secondary memory management to avoid frequent operations.
axclrtMallocCached
axclError axclrtMallocCached(void **devPtr, size_t size, axclrtMemMallocPolicy policy);
Description:
Allocate CACHED physical memory on the device side. The allocated memory pointer is returned via devPtr, synchronous interface.
Parameters:
Limitations:
  • Allocates CACHED memory, and the user must handle data consistency.
axclrtFree
axclError axclrtFree(void *devPtr);
Description:
Release memory allocated on the device side, synchronous interface.
Parameters:
  • devPtr [IN]: Device memory to be released.
Limitations:
axclrtMemFlush
axclError axclrtMemFlush(void *devPtr, size_t size);
Description:
Flush the data in the cache to DDR and invalidate the contents in the cache, synchronous interface.
Parameters:
  • devPtr [IN]: Starting address pointer of the DDR memory to be flushed.
  • size [IN]: Size of the DDR memory to be flushed, in bytes.
Limitations:
axclrtMemInvalidate
axclError axclrtMemInvalidate(void *devPtr, size_t size);
Description:
Invalidate the data in the cache, synchronous interface.
Parameters:
  • devPtr [IN]: Starting address pointer of the DDR memory whose cache data will be invalidated.
  • size [IN]: Size of the DDR memory, in bytes.
Limitations:
  • No special restrictions.
axclrtMallocHost
axclError axclrtMallocHost(void **hostPtr, size_t size);
Description:
Allocate virtual memory on the HOST, synchronous interface.
Parameters:
  • hostPtr [OUT]: Start address of the allocated memory.
  • size [IN]: Size of the allocated memory, in bytes.
Limitations:
  • Memory allocated with axclrtMallocHost must be released with axclrtFreeHost.
  • Frequent memory allocations and releases can impact performance; it is recommended to use pre-allocation or secondary memory management to avoid frequent operations.
  • Memory can also be allocated on the HOST using the standard malloc interface, but axclrtMallocHost is recommended.
axclrtFreeHost
axclError axclrtFreeHost(void *hostPtr);
Description:
Release memory allocated by axclrtMallocHost, synchronous interface.
Parameters:
  • hostPtr [IN]: Start address of the memory to be released.
Limitations:
axclrtMemset
axclError axclrtMemset(void *devPtr, uint8_t value, size_t count);
Description:
Only used to initialize device-side memory allocated by axclrtMalloc or axclrtMallocCached, synchronous interface.
Parameters:
  • devPtr [IN]: Start address of the device-side memory to initialize.
  • value [IN]: Value to set.
  • count [IN]: Length of the memory to initialize, in bytes.
Limitations:
axclrtMemcpy
axclError axclrtMemcpy(void *dstPtr, const void *srcPtr, size_t count, axclrtMemcpyKind kind);
Description:
Performs synchronous memory copy operations between HOST memory, between HOST and DEVICE memory, and within DEVICE memory.
Parameters:
  • devPtr [IN]: Destination memory address pointer.
  • srcPtr [IN]: Source memory address pointer.
  • count [IN]: Length of memory to be copied, in bytes.
  • kind [IN]: Type of memory copy.
    • [AXCL_MEMCPY_HOST_TO_HOST]: Memory copy within HOST memory.
    • [AXCL_MEMCPY_HOST_TO_DEVICE]: Copy from HOST virtual memory to DEVICE memory.
    • [AXCL_MEMCPY_DEVICE_TO_HOST]: Copy from DEVICE memory to HOST virtual memory.
    • [AXCL_MEMCPY_DEVICE_TO_DEVICE]: Memory copy within DEVICE.
    • [AXCL_MEMCPY_HOST_PHY_TO_DEVICE]: Copy from HOST continuous physical memory to DEVICE.
    • [AXCL_MEMCPY_DEVICE_TO_HOST_PHY]: Copy from DEVICE to HOST continuous physical memory.
Limitations:
  • The source and destination memory must comply with the requirements of kind.
axclrtMemcmp
axclError axclrtMemcmp(const void *devPtr1, const void *devPtr2, size_t count);
Description:
Performs memory comparison within the DEVICE, synchronous interface.
Parameters:
  • devPtr1 [IN]: Pointer to device memory address #1.
  • devPtr2 [IN]: Pointer to device memory address #2.
  • count [IN]: Length to compare, in bytes.
Limitations:
  • Only supports comparison of device memory; returns AXCL_SUCC(0) only if the memory contents are the same.
engine
axclrtEngineInit
axclError axclrtEngineInit(axclrtEngineVNpuKind npuKind);
Description:
Initializes the Runtime Engine. Must be called before using the Runtime Engine.
Parameters:
  • npuKind [IN]: Specifies the type of VNPU to initialize.
Limitations:
After using the Runtime Engine, the user must call axclrtEngineFinalize to clean up the Runtime Engine.
axclrtEngineGetVNpuKind
axclError axclrtEngineGetVNpuKind(axclrtEngineVNpuKind *npuKind);
Description:
Retrieves the initialized VNPU type of the Runtime Engine.
Parameters:
  • npuKind [OUT]: Returns the VNPU type.
Limitations:
The user must call axclrtEngineInit to initialize the Runtime Engine before calling this function.
axclError axclrtEngineFinalize();
Description:
Cleans up the Runtime Engine. Must be called after completing all operations.
Limitations:
The user must call axclrtEngineInit before calling this function.
axclrtEngineLoadFromFile
axclError axclrtEngineLoadFromFile(const char *modelPath, uint64_t *modelId);
Description:
Loads model data from a file and creates a model ID.
Parameters:
  • modelPath [IN]: Path to the offline model file.
  • modelId [OUT]: The model ID generated after loading, used as an identifier for subsequent operations.
Limitations:
axclrtEngineLoadFromMem
axclError axclrtEngineLoadFromMem(const void *model, uint64_t modelSize, uint64_t *modelId);
Description:
Loads offline model data from memory, with memory for model execution managed internally by the system.
Parameters:
  • model [IN]: Model data stored in memory.
  • modelSize [IN]: Size of the model data.
Limitations:
  • The model memory must be device memory, which the user must manage and release.
axclrtEngineUnload
axclError axclrtEngineUnload(uint64_t modelId);
Description:
This function is used to unload a model with the specified model ID.
Parameters:
  • modelId [IN]: The model ID to unload.
Limitations:
axclrtEngineGetModelCompilerVersion
const char* axclrtEngineGetModelCompilerVersion(uint64_t modelId);
Description:
This function retrieves the version of the toolchain used to build the model.
Parameters:
  • modelId [IN]: Model ID.
Limitations:
axclrtEngineSetAffinity
axclError axclrtEngineSetAffinity(uint64_t modelId, axclrtEngineSet set);
Description:
This function is used to set the model’s NPU affinity.
Parameters:
  • set [OUT]: Affinity set to apply.
Limitations:
Cannot be zero, and the mask bits set must not exceed the affinity range.
axclrtEngineGetAffinity
axclError axclrtEngineGetAffinity(uint64_t modelId, axclrtEngineSet *set);
Description:
This function retrieves the model’s NPU affinity.
Parameters:
  • set [OUT]: Returned affinity set.
Limitations:
axclrtEngineGetUsage
axclError axclrtEngineGetUsage(const char *modelPath, int64_t *sysSize, int64_t *cmmSize);
Description:
This function retrieves the required system memory size and CMM memory size for executing a model based on its file.
Parameters:
  • modelPath [IN]: Model path used to obtain memory information.
  • sysSize [OUT]: Working system memory size required to run the model.
  • cmmSize [OUT]: CMM memory size required to run the model.
Limitations:
axclrtEngineGetUsageFromMem
axclError axclrtEngineGetUsageFromMem(const void *model, uint64_t modelSize, int64_t *sysSize, int64_t *cmmSize);
Description:
This function retrieves the required system memory size and CMM memory size for executing a model based on its data in memory.
Parameters:
  • model [IN]: User-managed model memory.
Limitations:
Model memory must reside in device memory, which the user must manage and release.
axclrtEngineGetUsageFromModelId
axclError axclrtEngineGetUsageFromModelId(uint64_t modelId, int64_t *sysSize, int64_t *cmmSize);
Description:
This function retrieves the required system memory size and CMM memory size for executing a model based on its ID.
Parameters:
Limitations:
axclrtEngineGetModelType
axclError axclrtEngineGetModelType(const char *modelPath, axclrtEngineModelKind *modelType);
Description:
This function retrieves the model type based on its file.
Parameters:
  • modelPath [IN]: Model path used to retrieve model type.
  • modelType [OUT]: Returned model type.
Limitations:
axclrtEngineGetModelTypeFromMem
axclError axclrtEngineGetModelTypeFromMem(const void *model, uint64_t modelSize, axclrtEngineModelKind *modelType);
Description:
This function retrieves the model type based on model data in memory.
Parameters:
Limitations:
axclrtEngineGetModelTypeFromModelId
axclError axclrtEngineGetModelTypeFromModelId(uint64_t modelId, axclrtEngineModelKind *modelType);
Description:
This function retrieves the model type based on the model ID.
Parameters:
Limitations:
axclrtEngineGetIOInfo
axclError axclrtEngineGetIOInfo(uint64_t modelId, axclrtEngineIOInfo *ioInfo);
Description:
This function retrieves the model IO information based on the model ID.
Parameters:
  • ioInfo [OUT]: Returned axclrtEngineIOInfo pointer.
Limitations:
The user should call axclrtEngineDestroyIOInfo to release axclrtEngineIOInfo before the model ID is destroyed.
axclError axclrtEngineDestroyIOInfo(axclrtEngineIOInfo ioInfo);
Description:
This function destroys data of type axclrtEngineIOInfo.
Parameters:
  • ioInfo [IN]: axclrtEngineIOInfo pointer.
Limitations:
axclrtEngineGetShapeGroupsCount
axclError axclrtEngineGetShapeGroupsCount(axclrtEngineIOInfo ioInfo, int32_t *count);
Description:
This function retrieves the number of IO shape groups.
Parameters:
  • count [OUT]: Number of shape groups.
Limitations:
The Pulsar2 toolchain can specify multiple shapes during model conversion. Standard models typically have only one shape, so calling this function for normally converted models is unnecessary.
axclrtEngineGetNumInputs
uint32_t axclrtEngineGetNumInputs(axclrtEngineIOInfo ioInfo);
Description:
This function retrieves the number of model inputs from axclrtEngineIOInfo.
Parameters:
Limitations:
axclrtEngineGetNumOutputs
uint32_t axclrtEngineGetNumOutputs(axclrtEngineIOInfo ioInfo);
Description:
This function retrieves the number of model outputs from axclrtEngineIOInfo.
Parameters:
Limitations:
axclrtEngineGetInputSizeByIndex
uint64_t axclrtEngineGetInputSizeByIndex(axclrtEngineIOInfo ioInfo, uint32_t group, uint32_t index);
Description:
This function retrieves the size of a specific input based on axclrtEngineIOInfo.
Parameters:
  • group [IN]: Input shape group index.
  • index [IN]: Index of the input whose size is to be retrieved, starting from 0.
Limitations:
axclrtEngineGetOutputSizeByIndex
uint64_t axclrtEngineGetOutputSizeByIndex(axclrtEngineIOInfo ioInfo, uint32_t group, uint32_t index);
Description:
This function retrieves the size of a specific output based on axclrtEngineIOInfo.
Parameters:
  • group [IN]: Output shape group index.
  • index [IN]: Index of the output whose size is to be retrieved, starting from 0.
Limitations:
axclrtEngineGetInputNameByIndex
const char *axclrtEngineGetInputNameByIndex(axclrtEngineIOInfo ioInfo, uint32_t index);
Description:
This function retrieves the name of a specific input.
Parameters:
  • index [IN]: Input IO index.
Limitations:
The returned input tensor name has the same lifecycle as ioInfo.
axclrtEngineGetOutputNameByIndex
const char *axclrtEngineGetOutputNameByIndex(axclrtEngineIOInfo ioInfo, uint32_t index);
Description:
This function retrieves the name of a specific output.
Parameters:
  • index [IN]: Output IO index.
Limitations:
The returned output tensor name has the same lifecycle as ioInfo.
axclrtEngineGetInputIndexByName
int32_t axclrtEngineGetInputIndexByName(axclrtEngineIOInfo ioInfo, const char *name);
Description:
This function retrieves the input index based on the name of the input tensor.
Parameters:
  • ioInfo [IN]: Model description.
  • name [IN]: Input tensor name.
Limitations:
axclrtEngineGetOutputIndexByName
int32_t axclrtEngineGetOutputIndexByName(axclrtEngineIOInfo ioInfo, const char *name);
Description:
This function retrieves the output index based on the name of the output tensor.
Parameters:
  • name [IN]: Output tensor name.
Limitations:
axclrtEngineGetInputDims
axclError axclrtEngineGetInputDims(axclrtEngineIOInfo ioInfo, uint32_t group, uint32_t index, axclrtEngineIODims *dims);
Description:
This function retrieves the dimension information of a specified input.
Parameters:
  • index [IN]: Input tensor index.
  • dims [OUT]: Returned dimension information.
Limitations:
The storage space for axclrtEngineIODims is allocated by the user, and should be released before axclrtEngineIOInfo is destroyed.
axclrtEngineGetOutputDims
axclError axclrtEngineGetOutputDims(axclrtEngineIOInfo ioInfo, uint32_t group, uint32_t index, axclrtEngineIODims *dims);
Description:
This function retrieves the dimension information of a specified output.
Parameters:
  • index [IN]: Output tensor index.
Limitations:
axclrtEngineCreateIO
axclError axclrtEngineCreateIO(axclrtEngineIOInfo ioInfo, axclrtEngineIO *io);
Description:
This function creates data of type axclrtEngineIO.
Parameters:
  • io [OUT]: Created axclrtEngineIO pointer.
Limitations:
The user should call axclrtEngineDestroyIO to release axclrtEngineIO before the model ID is destroyed.
axclError axclrtEngineDestroyIO(axclrtEngineIO io);
Description:
This function destroys data of type axclrtEngineIO.
Parameters:
  • io [IN]: The axclrtEngineIO pointer to be destroyed.
Limitations:
axclrtEngineSetInputBufferByIndex
axclError axclrtEngineSetInputBufferByIndex(axclrtEngineIO io, uint32_t index, const void *dataBuffer, uint64_t size);
Description:
This function sets the input data buffer by IO index.
Parameters:
  • io [IN]: Address of the axclrtEngineIO data buffer.
  • dataBuffer [IN]: Address of the data buffer to add.
  • size [IN]: Size of the data buffer.
Limitations:
The data buffer must be in device memory, and the user is responsible for managing and releasing it.
axclrtEngineSetOutputBufferByIndex
axclError axclrtEngineSetOutputBufferByIndex(axclrtEngineIO io, uint32_t index, const void *dataBuffer, uint64_t size);
Description:
This function sets the output data buffer by IO index.
Parameters:
Limitations:
axclrtEngineSetInputBufferByName
axclError axclrtEngineSetInputBufferByName(axclrtEngineIO io, const char *name, const void *dataBuffer, uint64_t size);
Description:
This function sets the input data buffer by IO name.
Parameters:
Limitations:
axclrtEngineSetOutputBufferByName
axclError axclrtEngineSetOutputBufferByName(axclrtEngineIO io, const char *name, const void *dataBuffer, uint64_t size);
Description:
This function sets the output data buffer by IO name.
Parameters:
Limitations:
axclrtEngineGetInputBufferByIndex
axclError axclrtEngineGetInputBufferByIndex(axclrtEngineIO io, uint32_t index, void **dataBuffer, uint64_t *size);
Description:
This function retrieves the input data buffer by IO index.
Parameters:
  • dataBuffer [OUT]: Address of the data buffer.
Limitations:
axclrtEngineGetOutputBufferByIndex
axclError axclrtEngineGetOutputBufferByIndex(axclrtEngineIO io, uint32_t index, void **dataBuffer, uint64_t *size);
Description:
This function retrieves the output data buffer by IO index.
Parameters:
Limitations:
axclrtEngineGetInputBufferByName
axclError axclrtEngineGetInputBufferByName(axclrtEngineIO io, const char *name, void **dataBuffer, uint64_t *size);
Description:
This function retrieves the input data buffer by IO name.
Parameters:
Limitations:
axclrtEngineGetOutputBufferByName
axclError axclrtEngineGetOutputBufferByName(axclrtEngineIO io, const char *name, void **dataBuffer, uint64_t *size);
Description:
This function retrieves the output data buffer by IO name.
Parameters:
Limitations:
axclrtEngineSetDynamicBatchSize
axclError axclrtEngineSetDynamicBatchSize(axclrtEngineIO io, uint32_t batchSize);
Description:
This function sets the number of images processed at one time in a dynamic batching scenario.
Parameters:
  • io [IN]: Model inference IO.
  • batchSize [IN]: Number of images processed at one time.
Limitations:
axclrtEngineCreateContext
axclError axclrtEngineCreateContext(uint64_t modelId, uint64_t *contextId);
Description:
This function creates a model runtime context for the given model ID.
Parameters:
  • contextId [OUT]: Created context ID.
Limitations:
A model ID can have multiple runtime contexts, each running with its own settings and memory space.
axclrtEngineExecute
axclError axclrtEngineExecute(uint64_t modelId, uint64_t contextId, uint32_t group, axclrtEngineIO io);
Description:
This function performs synchronous inference for the model until the inference result is returned.
Parameters:
  • contextId [IN]: Model inference context.
  • group [IN]: Model shape group index.
Limitations:
axclrtEngineExecuteAsync
axclError axclrtEngineExecuteAsync(uint64_t modelId, uint64_t contextId, uint32_t group, axclrtEngineIO io, axclrtStream stream);
Description:
This function performs asynchronous inference for the model.
Parameters:
  • stream [IN]: Stream.
Limitations:
native
  • The AXCL NATIVE module supports the SYS, VDEC, VENC, IVPS, DMADIM, ENGINE, and IVE modules.
  • The AXCL NATIVE API parameters are exactly the same as those of the AX SDK API, the only difference being that the function names change from the original AX prefix to AXCL.
    Example:
    AX_S32 AXCL_SYS_Init(AX_VOID);
    AX_S32 AXCL_SYS_Deinit(AX_VOID);
    /* CMM API */
    AX_S32 AXCL_SYS_MemAlloc(AX_U64 *phyaddr, AX_VOID **pviraddr, AX_U32 size, AX_U32 align, const AX_S8 *token);
    AX_S32 AXCL_SYS_MemAllocCached(AX_U64 *phyaddr, AX_VOID **pviraddr, AX_U32 size, AX_U32 align, const AX_S8 *token);
    AX_S32 AXCL_SYS_MemFree(AX_U64 phyaddr, AX_VOID *pviraddr);
    AX_S32 AXCL_VDEC_Init(const AX_VDEC_MOD_ATTR_T *pstModAttr);
    AX_S32 AXCL_VDEC_Deinit(AX_VOID);
    AX_S32 AXCL_VDEC_ExtractStreamHeaderInfo(const AX_VDEC_STREAM_T *pstStreamBuf, AX_PAYLOAD_TYPE_E enVideoType,
                                             AX_VDEC_BITSTREAM_INFO_T *pstBitStreamInfo);
    AX_S32 AXCL_VDEC_CreateGrp(AX_VDEC_GRP VdGrp, const AX_VDEC_GRP_ATTR_T *pstGrpAttr);
    AX_S32 AXCL_VDEC_CreateGrpEx(AX_VDEC_GRP *VdGrp, const AX_VDEC_GRP_ATTR_T *pstGrpAttr);
    AX_S32 AXCL_VDEC_DestroyGrp(AX_VDEC_GRP VdGrp);
  • Please refer to the AX SDK API documentation, such as "AX SYS API Documentation.docx", "AX VDEC API Documentation.docx", etc.
  • The dynamic library .so naming has changed from the original libax_xxx.so to libaxcl_xxx.so. The comparison table is as follows:
Module AX SDK AXCL NATIVE SDK
SYS libax_sys.so libaxcl_sys.so
VDEC libax_vdec.so libaxcl_vdec.so
VENC libax_venc.so libaxcl_venc.so
IVPS libax_ivps.so libaxcl_ivps.so
DMADIM libax_dmadim.so libaxcl_dmadim.so
ENGINE libax_engine.so libaxcl_engine.so
IVE libax_ive.so libaxcl_ive.so
  • Some AX SDK APIs are not supported in AXCL NATIVE. The specific list is as follows:
Module AXCL NATIVE API Description
SYS AXCL_SYS_EnableTimestamp
AXCL_SYS_Sleep
AXCL_SYS_WakeLock
AXCL_SYS_WakeUnlock
AXCL_SYS_RegisterEventCb
AXCL_SYS_UnregisterEventCb
VENC AXCL_VENC_GetFd
AXCL_VENC_JpegGetThumbnail
IVPS AXCL_IVPS_GetChnFd
AXCL_IVPS_CloseAllFd
DMADIM AXCL_DMADIM_Cfg Callback function not supported, i.e., AX_DMADIM_MSG_T.pfnCallBack
IVE AXCL_IVE_NPU_CreateMatMulHandle
AX_IVE_NPU_DestroyMatMulHandle
AX_IVE_NPU_MatMul
PPL
architecture
libaxcl_ppl.so is a highly integrated module that implements typical pipeline (PPL). The architecture diagram is as follows:
| application                   |
| libaxcl_ppl.so                |
| libaxcl_lite.so               |
| axcl sdk                      |
| pcie driver                   |
libaxcl_lite.so and libaxcl_ppl.so are open-source libraries which located in axcl/sample/axclit and axcl/sample/ppl directories.
transcode
Refer to the source code of axcl_transcode_sample which located in path: axcl/sample/ppl/transode.
API
axcl_ppl_init
axcl runtime system and ppl initialization.
prototype
axclError axcl_ppl_init(const axcl_ppl_init_param* param);
parameter
parameter description in/out
param in
typedef enum {
    AXCL_LITE_NONE = 0,
    AXCL_LITE_VDEC = (1 << 0),
    AXCL_LITE_VENC = (1 << 1),
    AXCL_LITE_IVPS = (1 << 2),
    AXCL_LITE_JDEC = (1 << 3),
    AXCL_LITE_JENC = (1 << 4),
    AXCL_LITE_DEFAULT = (AXCL_LITE_VDEC | AXCL_LITE_VENC | AXCL_LITE_IVPS),
    AXCL_LITE_MODULE_BUTT
} AXCLITE_MODULE_E;
typedef struct {
    const char *json; /* axcl.json path */
    AX_S32 device;
    AX_U32 modules;
    AX_U32 max_vdec_grp;
    AX_U32 max_venc_thd;
} axcl_ppl_init_param;
json json file path pass to axclInit API. in
device device id in
modules bitmask of AXCLITE_MODULE_E according to PPL in
max_vdec_grp total VDEC groups of all processes in
max_venc_thrd max VENC threads of each process in
IMPORTANT:
  • AXCL_PPL_TRANSCODE: modules = AXCL_LITE_DEFAULT
  • max_vdec_grp should be equal to or greater than the total number of VDEC groups across all processes. For example, if 16 processes are launched, with each process having one decoder, max_vdec_grp should be set to at least 16.
  • max_venc_thrd usually be configured as same as the total VENC channels of each process.
return
0 (AXCL_SUCC) if success, otherwise failure.
axcl_ppl_deinit
axcl runtime system and ppl deinitialization.
prototype
axclError axcl_ppl_deinit();
return
axcl_ppl_create
create ppl.
prototype
axclError axcl_ppl_create(axcl_ppl* ppl, const axcl_ppl_param* param);
parameter
ppl ppl handle created out
param parameters related to specified ppl in
typedef enum {
    AXCL_PPL_TRANSCODE = 0, /* VDEC -> IVPS ->VENC */
    AXCL_PPL_BUTT
} axcl_ppl_type;
typedef struct {
    axcl_ppl_type ppl;
    void *param;
} axcl_ppl_param;
AXCL_PPL_TRANSCODE parameters as shown as follows:
typedef AX_VENC_STREAM_T axcl_ppl_encoded_stream;
typedef void (*axcl_ppl_encoded_stream_callback_func)(axcl_ppl ppl, const axcl_ppl_encoded_stream *stream, AX_U64 userdata);
typedef struct {
    axcl_ppl_transcode_vdec_attr vdec;
    axcl_ppl_transcode_venc_attr venc;
    axcl_ppl_encoded_stream_callback_func cb;
    AX_U64 userdata;
} axcl_ppl_transcode_param;
vdec decoder attribute in
venc encoder attribute in
cb callback function to receive encoded nalu frame data in
userdata userdata bypass to axcl_ppl_encoded_stream_callback_func in
Warning
Avoid high-latency processing inside the axcl_ppl_encoded_stream_callback_func function
typedef struct {
    AX_PAYLOAD_TYPE_E payload;
    AX_U32 width;
    AX_U32 height;
    AX_VDEC_OUTPUT_ORDER_E output_order;
    AX_VDEC_DISPLAY_MODE_E display_mode;
} axcl_ppl_transcode_vdec_attr;
payload PT_H2644 \ PT_H265 in
width max. width of input stream in
height max. height of input stream in
output_order AX_VDEC_OUTPUT_ORDER_DISP \ AX_VDEC_OUTPUT_ORDER_DEC in
display_mode AX_VDEC_DISPLAY_MODE_PREVIEW \ AX_VDEC_DISPLAY_MODE_PLAYBACK in
Important:
  • output_order:
    • If decode sequence is same as display sequence such as IP stream, recommend to AX_VDEC_OUTPUT_ORDER_DEC to save memory.
    • If decode sequence is different to display sequence such as IPB stream, set AX_VDEC_OUTPUT_ORDER_DISP.
  • display_mode
    • AX_VDEC_DISPLAY_MODE_PREVIEW: preview mode which frame dropping is allowed typically for RTSP stream... etc.
    • AX_VDEC_DISPLAY_MODE_PLAYBACK: playback mode which frame dropping is not forbidden typically for local stream file.
typedef struct {
    AX_U32 width;
    AX_U32 height;
    AX_VENC_PROFILE_E profile;
    AX_VENC_LEVEL_E level;
    AX_VENC_TIER_E tile;
    AX_VENC_RC_ATTR_T rc;
    AX_VENC_GOP_ATTR_T gop;
} axcl_ppl_transcode_venc_attr;
payload PT_H264 \ PT_H265 in
width output width of encoded nalu frame in
height output height of encoded nalu frame in
profile h264 or h265 profile in
level h264 or h265 level in
tile tile in
rc rate control settings in
gop gop settings in
return
axcl_ppl_destroy
destroy ppl.
prototype
axclError axcl_ppl_destroy(axcl_ppl ppl)
parameter
ppl ppl handle created in
return
axcl_ppl_start
start ppl.
prototype
axclError axcl_ppl_start(axcl_ppl ppl);
parameter
return
axcl_ppl_stop
stop ppl.
prototype
axclError axcl_ppl_stop(axcl_ppl ppl);
parameter
return
axcl_ppl_send_stream
send nalu frame to ppl.
prototype
axclError axcl_ppl_send_stream(axcl_ppl ppl, const axcl_ppl_input_stream* stream, AX_S32 timeout);
parameter
stream nalu frame in
timeout timeout in milliseconds in
typedef struct {
    AX_U8 *nalu;
    AX_U32 nalu_len;
    AX_U64 pts;
    AX_U64 userdata;
} axcl_ppl_input_stream;
nalu pointer to nalu frame data in
nalu_len bytes of nalu frame data in
pts timestamp of nalu frame in
userdata userdata bypass to axcl_ppl_encoded_stream.stPack.u64UserData in
return
axcl_ppl_get_attr
get attribute of ppl.
prototype
axclError axcl_ppl_get_attr(axcl_ppl ppl, const char* name, void* attr);
parameter
name attribute name in
attr attribute value out
 *            name                                     attr type        default
 *  axcl.ppl.id                             [R  ]       int32_t                            increment +1 for each axcl_ppl_create
 *  axcl.ppl.transcode.vdec.grp             [R  ]       int32_t                            allocated by ax_vdec.ko
 *  axcl.ppl.transcode.ivps.grp             [R  ]       int32_t                            allocated by ax_ivps.ko
 *  axcl.ppl.transcode.venc.chn             [R  ]       int32_t                            allocated by ax_venc.ko
 *  the following attributes take effect BEFORE the axcl_ppl_create function is called:
 *  axcl.ppl.transcode.vdec.blk.cnt         [R/W]       uint32_t          8                depend on stream DPB size and decode mode
 *  axcl.ppl.transcode.vdec.out.depth       [R/W]       uint32_t          4                out fifo depth
 *  axcl.ppl.transcode.ivps.in.depth        [R/W]       uint32_t          4                in fifo depth
 *  axcl.ppl.transcode.ivps.out.depth       [R  ]       uint32_t          0                out fifo depth
 *  axcl.ppl.transcode.ivps.blk.cnt         [R/W]       uint32_t          4
 *  axcl.ppl.transcode.ivps.engine          [R/W]       uint32_t   AX_IVPS_ENGINE_VPP      AX_IVPS_ENGINE_VPP|AX_IVPS_ENGINE_VGP|AX_IVPS_ENGINE_TDP
 *  axcl.ppl.transcode.venc.in.depth        [R/W]       uint32_t          4                in fifo depth
 *  axcl.ppl.transcode.venc.out.depth       [R/W]       uint32_t          4                out fifo depth
Important
axcl.ppl.transcode.vdec.blk.cnt: blk count is related to the DBP size of input stream, recommend to set dbp + 1.
return
axcl_ppl_set_attr
set attribute of ppl.
prototype
axclError axcl_ppl_set_attr(axcl_ppl ppl, const char* name, const void* attr);
parameter
name attribute name, refer to axcl_ppl_get_attr in
attr attribute value in
return
Error Codes
Definition
typedef int32_t axclError;
typedef enum {
    AXCL_SUCC                   = 0x00,
    AXCL_FAIL                   = 0x01,
    AXCL_ERR_UNKNOWN            = AXCL_FAIL,
    AXCL_ERR_NULL_POINTER       = 0x02,
    AXCL_ERR_ILLEGAL_PARAM      = 0x03,
    AXCL_ERR_UNSUPPORT          = 0x04,
    AXCL_ERR_TIMEOUT            = 0x05,
    AXCL_ERR_BUSY               = 0x06,
    AXCL_ERR_NO_MEMORY          = 0x07,
    AXCL_ERR_ENCODE             = 0x08,
    AXCL_ERR_DECODE             = 0x09,
    AXCL_ERR_UNEXPECT_RESPONSE  = 0x0A,
    AXCL_ERR_OPEN               = 0x0B,
    AXCL_ERR_EXECUTE_FAIL       = 0x0C,
    AXCL_ERR_BUTT               = 0x7F
} AXCL_ERROR_E;
#define AX_ID_AXCL           (0x30)
/* module */
#define AXCL_RUNTIME         (0x00)
#define AXCL_NATIVE          (0x01)
#define AXCL_LITE            (0x02)
/* runtime sub module */
#define AXCL_RUNTIME_DEVICE  (0x01)
#define AXCL_RUNTIME_CONTEXT (0x02)
#define AXCL_RUNTIME_STREAM  (0x03)
#define AXCL_RUNTIME_TASK    (0x04)
#define AXCL_RUNTIME_MEMORY  (0x05)
#define AXCL_RUNTIME_CONFIG  (0x06)
#define AXCL_RUNTIME_ENGINE  (0x07)
#define AXCL_RUNTIME_SYSTEM  (0x08)
 * | |   MODULE    |  AX_ID_AXCL | SUB_MODULE  |    ERR_ID   |
 * |1|--- 7bits ---|--- 8bits ---|--- 8bits ---|--- 8bits ---|
#define AXCL_DEF_ERR(module, sub, errid) \
    ((axclError)((0x80000000L) | (((module) & 0x7F) << 24) | ((AX_ID_AXCL) << 16 ) | ((sub) << 8) | (errid)))
#define AXCL_DEF_RUNTIME_ERR(sub, errid)    AXCL_DEF_ERR(AXCL_RUNTIME, (sub), (errid))
#define AXCL_DEF_NATIVE_ERR(sub,  errid)    AXCL_DEF_ERR(AXCL_NATIVE,  (sub), (errid))
#define AXCL_DEF_LITE_ERR(sub,    errid)    AXCL_DEF_ERR(AXCL_LITE,    (sub), (errid))
Note:
Error codes are divided into two types: AXCL Runtime Library and AX NATIVE SDK error codes, distinguished by the third byte of axclError.
If the third byte is equal to AX_ID_AXCL (0x30), it indicates an AXCL Runtime Library error code; otherwise, it indicates a Device-side AX NATIVE SDK module error code passed through to the HOST side.
  • AXCL Runtime Library error codes: Refer to the axcl_rt_xxx.h header file.
  • Device NATIVE SDK error codes are passed directly to the HOST side: Refer to the "AX Software Error Code Documentation".
Parsing
Visit AXCL Error Code Parser to parse error codes online.
