Input & Output Devices
Audio Playback Devices
FFmpeg
Environment Preparation
The AXCL_FFMPEG dynamic libraries are located in /usr/lib/axcl/ffmpeg, and the AXCL_FFMPEG executable is located in /usr/bin/axcl/ffmpeg.
Before running FFmpeg, you must set the dynamic library search path by configuring the environment variable:
export LD_LIBRARY_PATH="/usr/lib/axcl/ffmpeg:$LD_LIBRARY_PATH";
How to Use
m5stack@raspberrypi5:~ $ /usr/bin/axcl/ffmpeg/ffmpeg -c:v h264_axdec -i input.mp4 -f rawvideo -pix_fmt yuv420p output.yuv
How to Rebuild FFmpeg
The SDK version of FFmpeg is based on version 7.1, with precompiled .so libraries and ffmpeg binary files available for direct linking and execution.
If you need to recompile FFmpeg, follow these steps:
  1. Download FFmpeg-n7.1.tar.gz from GitHub, and copy it to the axcl/3rdparty/ffmpeg directory.
  2. Extract it:
tar -zxvf FFmpeg-n7.1.tar.gz
  1. Apply the patch:
patch -p3 < FFmpeg-n7.1.patch
  1. Compile:
  • For arm64
cd axcl/3rdparty/ffmpeg
make host=arm64 clean all install
The target files will be located at:
lib: axcl/out/axcl_linux_arm64/lib/ffmpeg
bin: axcl/out/axcl_linux_arm64/bin/ffmpeg
  • For x86
make host=x86 clean all install
lib: axcl/out/axcl_linux_x86/lib/ffmpeg
bin: axcl/out/axcl_linux_x86/bin/ffmpeg
