Input & Output Devices
Audio Playback Devices
MeloTTS
  • This section only explains how to run the precompiled MeloTTS text-to-speech demo on Raspberry Pi 5;
  • For model conversion and example source code compilation, please refer to melotts.axcl.
  1. Download
git clone https://github.com/ml-inory/melotts.axcl.git
chmod +x build_aarch64.sh
./build_aarch64.sh
  1. Precompiled Models
cd melotts.axcl
./download_models.sh
Precompiled model download links:
  1. Compile
For aarch64 platform:
./build_aarch64.sh
  1. Run MeloTTS
In the melotts.axcl project root directory, run:
./install/melotts -s sentence
Example for running with English model:
./install/melotts -e ../MeloTTS-English-ax650/encoder-en.onnx -d ../MeloTTS-English-ax650/decoder-en-au.axmodel -l ../MeloTTS-English-ax650/lexicon-en.txt -t ../MeloTTS-English-ax650/tokens-en.txt --g ../MeloTTS-English-ax650/g-en-au.bin -s "M5Stack is a leading provider of IoT solutions, committed to providing developers worldwide with convenient and flexible development components and tools."
Example Output:
m5stack@raspberrypi5:~/melotts.axcl $ ./install/melotts -e ../MeloTTS-English-ax650/encoder-en.onnx -d ../MeloTTS-English-ax650/decoder-en-au.axmodel -l ../MeloTTS-English-ax650/lexicon-en.txt -t ../MeloTTS-English-ax650/tokens-en.txt --g ../MeloTTS-English-ax650/g-en-au.bin -s "M5Stack is a leading provider of IoT solutions, committed to providing developers worldwide with convenient and flexible development components and tools."
encoder: ../MeloTTS-English-ax650/encoder-en.onnx
decoder: ../MeloTTS-English-ax650/decoder-en-au.axmodel
lexicon: ../MeloTTS-English-ax650/lexicon-en.txt
token: ../MeloTTS-English-ax650/tokens-en.txt
sentence: M5Stack is a leading provider of IoT solutions, committed to providing developers worldwide with convenient and flexible development components and tools.
wav: output.wav
speed: 0.800000
sample_rate: 44100
Load encoder
Load decoder model
Encoder run take 535.47ms
decoder slice num: 9
Decode slice(1/9) take 40.15ms
Decode slice(2/9) take 39.87ms
Decode slice(3/9) take 39.86ms
Decode slice(4/9) take 39.75ms
Decode slice(5/9) take 40.19ms
Decode slice(6/9) take 39.79ms
Decode slice(7/9) take 39.77ms
Decode slice(8/9) take 39.82ms
Decode slice(9/9) take 40.34ms
Saved audio to output.wav
