Input & Output Devices
Audio Playback Devices
SDK Example
runtime
axcl_sample_runtime
Example of calling Runtime API.
1. Initialize the runtime via `axclInit`.
2. Activate the device via `axclrtSetDevice`.
3. Create a context for the main thread via `axclrtCreateDevice` (optional).
4. Create and destroy thread contexts (required).
5. Destroy the context of the main thread.
6. Deactivate the device via `axclrtResetDevice`.
7. Deinitialize the runtime via `axclFinalize`.
Usage
m5stack@raspberrypi5:~ $ axcl_sample_runtime --help
[INFO ][                            main][  36]: ============== V3.6.3_20250722020142 sample started Jul 22 2025 02:31:26 =============
usage: axcl_sample_runtime [options] ...
options:
  -d, --device    device index [-1, connected device num - 1], -1: traverse all devices (int [=-1])
      --json      axcl.json path (string [=./axcl.json])
      --reboot    reboot device
  -?, --help      print this message
Parameter Default Value Description
-d, --device -1, range: [-1, 0 - connected device num - 1] Specify the device index. -1: traverse all devices
--json axcl.json file path
--reboot NA Make the device panic and reboot.
Example 1
Query the properties of device #0.
m5stack@raspberrypi5:~ $ axcl_sample_runtime -d 0
json file
[INFO ][                      operator()][ 130]: [0001:01.0] software version: Ax_Version V3.6.3_20250722020142
[INFO ][                      operator()][ 131]: [0001:01.0] uid             : 0x600408144b65d204
[INFO ][                      operator()][ 132]: [0001:01.0] temperature     : 49263
[INFO ][                      operator()][ 133]: [0001:01.0] total mem size  : 968356   KB
[INFO ][                      operator()][ 134]: [0001:01.0] free  mem size  : 815084   KB
[INFO ][                      operator()][ 135]: [0001:01.0] total cmm size  : 7208960  KB
[INFO ][                      operator()][ 136]: [0001:01.0] free  cmm size  : 7190084  KB
[INFO ][                      operator()][ 137]: [0001:01.0] avg cpu loading : 0.0%
[INFO ][                      operator()][ 138]: [0001:01.0] avg npu loading : 0.0%
[INFO ][                      operator()][ 149]: malloc 1048576 bytes memory from device  1 success, addr = 0x14926f000
[INFO ][                            main][ 215]: ============== V3.6.3_20250722020142 sample exited Jul 22 2025 02:31:26 ==============
Example 2
Manually make device #0 panic by sending echo c > /proc/sysrq-trigger, then reboot and download the firmware again.
m5stack@raspberrypi5:~ $ axcl_sample_runtime -d 0 --reboot
json file
[INFO ][                      operator()][ 134]: [0001:01.0] free  mem size  : 814888   KB
[INFO ][                      operator()][ 137]: [0001:01.0] avg cpu loading : 1.2%
[INFO ][                            main][ 178]: panic device 0x1
[INFO ][                            main][ 185]: wait for device 0x1 to reboot in 60 seconds
[FAIL ][                            main][ 203]: device 0x1 reboot timeout
axcl_sample_memory
Example of memory copy between HOST and DEVICE.
         HOST          |               DEVICE
      host_mem[0] -----------> dev_mem[0]
                                    |---------> dev_mem[1]
      host_mem[1] <----------------------------------|
1. Allocate host_mem[2] by `axclrtMallocHost` and dev_mem[2] by `axclrtMalloc`.
2. axclrtMemcpy(dev_mem[0], host_mem[0], size, AXCL_MEMCPY_HOST_TO_DEVICE)
3. axclrtMemcpy(dev_mem[1], dev_mem[0], size, AXCL_MEMCPY_DEVICE_TO_DEVICE)
4. axclrtMemcpy(host_mem[1], dev_mem[1], size, AXCL_MEMCPY_DEVICE_TO_HOST)
5. memcmp(host_mem[0], host_mem[1], size)
Usage
m5stack@raspberrypi5:~ $ axcl_sample_memory --help
[INFO ][                            main][  32]: ============== V3.6.3_20250722020142 sample started Jul 22 2025 02:31:27 ==============
usage: axcl_sample_memory [options] ...
options:
  -d, --device    device index from 0 to connected device num - 1 (int [=0])
-d, --device 0, range: [0 - connected device num -1] Specify the device index
Example
m5stack@raspberrypi5:~ $ axcl_sample_memory  -d 0
[INFO ][                           setup][ 112]: json: ./axcl.json
json file
[INFO ][                           setup][ 131]: device index: 0, bus number: 1
[INFO ][                            main][  51]: alloc host and device memory, size: 0x800000
[INFO ][                            main][  63]: memory [0]: host 0x7fff277fc010, device 0x14926f000
[INFO ][                            main][  63]: memory [1]: host 0x7fff26ff8010, device 0x149a6f000
[INFO ][                            main][  69]: memcpy from host memory[0] 0x7fff277fc010 to device memory[0] 0x14926f000
[INFO ][                            main][  75]: memcpy device memory[0] 0x14926f000 to device memory[1] 0x149a6f000
[INFO ][                            main][  81]: memcpy device memory[1] 0x149a6f000 to host memory[0] 0x7fff26ff8010
[INFO ][                            main][  88]: compare host memory[0] 0x7fff277fc010 and host memory[1] 0x7fff26ff8010 success
[INFO ][                         cleanup][ 146]: deactive device 1 and cleanup axcl
[INFO ][                            main][ 106]: ============== V3.6.3_20250722020142 sample exited Jul 22 2025 02:31:27 ==============
native
axcl_sample_sys
  • Example usage of the native SYS module, including:
  • Allocation and release of non-cached CMM memory.
  • Allocation and release of cached CMM memory.
  • Allocation and release from a general memory pool.
  • Allocation and release from a private memory pool.
  • Module linking and query.
Usage
m5stack@raspberrypi5:~ $ axcl_sample_sys --help
usage: axcl_sample_sys [options] ...
options:
  -d, --device    device index from 0 to connected device num - 1 (unsigned int [=0])
Example
m5stack@raspberrypi5:~ $ axcl_sample_sys -d 0
[INFO ][                            main][  35]: json: ./axcl.json
json file
[INFO ][                            main][  55]: device index: 0, bus number: 1
[INFO ][           sample_sys_alloc_free][  82]: sys_alloc_free begin
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14926f000,pVirAddr=0xffffafafe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14936f000,pVirAddr=0xffffaf9fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14946f000,pVirAddr=0xffffaf8fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14956f000,pVirAddr=0xffffaf7fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14966f000,pVirAddr=0xffffaf6fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14976f000,pVirAddr=0xffffaf5fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14986f000,pVirAddr=0xffffaf4fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x14996f000,pVirAddr=0xffffaf3fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x149a6f000,pVirAddr=0xffffaf2fe000
[INFO ][           sample_sys_alloc_free][  91]: alloc PhyAddr= 0x149b6f000,pVirAddr=0xffffaf1fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14926f000,pVirAddr=0xffffafafe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14936f000,pVirAddr=0xffffaf9fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14946f000,pVirAddr=0xffffaf8fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14956f000,pVirAddr=0xffffaf7fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14966f000,pVirAddr=0xffffaf6fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14976f000,pVirAddr=0xffffaf5fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14986f000,pVirAddr=0xffffaf4fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x14996f000,pVirAddr=0xffffaf3fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x149a6f000,pVirAddr=0xffffaf2fe000
[INFO ][           sample_sys_alloc_free][ 100]: free PhyAddr= 0x149b6f000,pVirAddr=0xffffaf1fe000
[INFO ][           sample_sys_alloc_free][ 103]: sys_alloc_free end success
[INFO ][     sample_sys_alloc_cache_free][ 115]: sys_alloc_cache_free begin
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14926f000,pVirAddr=0xffffafafe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14936f000,pVirAddr=0xffffaf9fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14946f000,pVirAddr=0xffffaf8fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14956f000,pVirAddr=0xffffaf7fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14966f000,pVirAddr=0xffffaf6fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14976f000,pVirAddr=0xffffaf5fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14986f000,pVirAddr=0xffffaf4fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x14996f000,pVirAddr=0xffffaf3fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x149a6f000,pVirAddr=0xffffaf2fe000
[INFO ][     sample_sys_alloc_cache_free][ 124]: alloc PhyAddr= 0x149b6f000,pVirAddr=0xffffaf1fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14926f000,pVirAddr=0xffffafafe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14936f000,pVirAddr=0xffffaf9fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14946f000,pVirAddr=0xffffaf8fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14956f000,pVirAddr=0xffffaf7fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14966f000,pVirAddr=0xffffaf6fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14976f000,pVirAddr=0xffffaf5fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14986f000,pVirAddr=0xffffaf4fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x14996f000,pVirAddr=0xffffaf3fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x149a6f000,pVirAddr=0xffffaf2fe000
[INFO ][     sample_sys_alloc_cache_free][ 133]: free PhyAddr= 0x149b6f000,pVirAddr=0xffffaf1fe000
[INFO ][     sample_sys_alloc_cache_free][ 136]: sys_alloc_cache_free end success
[INFO ][          sample_sys_commom_pool][ 148]: sys_commom_pool begin
[INFO ][          sample_sys_commom_pool][ 157]: AXCL_SYS_Init success!
[INFO ][          sample_sys_commom_pool][ 167]: AXCL_POOL_Exit success!
[INFO ][          sample_sys_commom_pool][ 199]: AXCL_POOL_SetConfig success!
[INFO ][          sample_sys_commom_pool][ 208]: AXCL_POOL_Init success!
[INFO ][          sample_sys_commom_pool][ 222]: AXCL_POOL_GetBlock success!BlkId:0x5E002000
[INFO ][          sample_sys_commom_pool][ 233]: AXCL_POOL_Handle2PoolId success!(Blockid:0x5E002000 --> PoolId=2)
[INFO ][          sample_sys_commom_pool][ 244]: AXCL_POOL_Handle2PhysAddr success!(Blockid:0x5E002000 --> PhyAddr=0x14ad8d000)
[INFO ][          sample_sys_commom_pool][ 255]: AXCL_POOL_Handle2MetaPhysAddr success!(Blockid:0x5E002000 --> MetaPhyAddr=0x14a18b000)
[INFO ][          sample_sys_commom_pool][ 265]: AXCL_POOL_ReleaseBlock success!Blockid=0x5e002000
[INFO ][          sample_sys_commom_pool][ 275]: AXCL_POOL_Exit success!
[INFO ][          sample_sys_commom_pool][ 285]: AXCL_SYS_Deinit success!
[INFO ][          sample_sys_commom_pool][ 288]: sys_commom_pool end success!
[INFO ][         sample_sys_private_pool][ 310]: sys_private_pool begin
[INFO ][         sample_sys_private_pool][ 319]: AXCL_SYS_Init success!
[INFO ][         sample_sys_private_pool][ 329]: AXCL_POOL_Exit success!
[INFO ][         sample_sys_private_pool][ 349]: AXCL_POOL_CreatePool[0] success
[INFO ][         sample_sys_private_pool][ 367]: AXCL_POOL_CreatePool[1] success
[INFO ][         sample_sys_private_pool][ 378]: AXCL_POOL_GetBlock success!BlkId:0x5E001000
[INFO ][         sample_sys_private_pool][ 389]: AXCL_POOL_Handle2PoolId success!(Blockid:0x5E001000 --> PoolId=1)
[INFO ][         sample_sys_private_pool][ 400]: AX_POOL_Handle2PhysAddr success!(Blockid:0x5E001000 --> PhyAddr=0x149879000)
[INFO ][         sample_sys_private_pool][ 411]: AXCL_POOL_Handle2MetaPhysAddr success!(Blockid:0x5E001000 --> MetaPhyAddr=0x149477000)
[INFO ][         sample_sys_private_pool][ 421]: AXCL_POOL_ReleaseBlock success!Blockid=0x5e001000
[INFO ][         sample_sys_private_pool][ 430]: AXCL_POOL_DestroyPool[1] success!
[INFO ][         sample_sys_private_pool][ 438]: AXCL_POOL_DestroyPool[0] success!
[INFO ][         sample_sys_private_pool][ 448]: AXCL_SYS_Deinit success!
[INFO ][         sample_sys_private_pool][ 451]: sys_private_pool end success!
[INFO ][                 sample_sys_link][ 472]: sample_sys_link begin
[INFO ][                 sample_sys_link][ 487]: AXCL_SYS_Init success!
[INFO ][                 sample_sys_link][ 554]: AXCL_SYS_Deinit success!
[INFO ][                 sample_sys_link][ 557]: sample_sys_link end success!
axcl_sample_vdec
Example of H264 and H265 Video Decoder (VDEC).
  1. Load .mp4 file or .h264/.h265 raw bitstream file.
  2. Demux nalu frames via ffmpeg.
  3. Send nalus to the video decoder frame by frame.
  4. Receive decoded nv12 image information.
Usage
m5stack@raspberrypi5:~ $ axcl_sample_vdec --help
[INFO ][                            main][  43]: ============== V3.6.3_20250722020142 sample started Jul 22 2025 02:31:31 ==============
usage: axcl_sample_vdec --url=string [options] ...
options:
  -i, --url       mp4|.264|.265 file path (string)
      --count     grp count (int [=1])
  -w, --width     frame width (int [=1920])
  -h, --height    frame height (int [=1080])
      --VdChn     channel id (int [=0])
      --yuv       transfer nv12 from device (int [=0])
-d, --device 0, range: [0 - connected device num -1] Specify the device index.
-i, --url NA Specify the path of the stream file.
--count 1 Specify the number of groups.
-w, --width 1920 Specify the width of the decoded YUV image.
-h, --height 1080 Specify the height of the decoded YUV image.
--VdChn 0 Specify the VDEC channel.
0: Outputs the original width and height of the input stream.
1: Output range [48x48, 4096x4096], supports width/height scaling.
2: Output range [48x48, 1920x1080], supports width/height scaling.
--yuv 0 1: Transfer decoded YUV image from device. 0: Do not transfer image.
Note:
If you encounter the following error:
axcl_sample_vdec: error while loading shared libraries: libavcodec.so.61: cannot open shared object file: No such file or directory
Please set the environment variables first using the following command:
$ export LD_LIBRARY_PATH=/usr/lib/axcl/ffmpeg:$LD_LIBRARY_PATH
Example
m5stack@raspberrypi5:~ $ axcl_sample_vdec -i input.mp4 -d 0
[INFO ][                            main][  68]: json: ./axcl.json
json file
[INFO ][                            main][  88]: device index: 0, bus number: 1
[INFO ][             ffmpeg_init_demuxer][ 439]: [0] url: input.mp4
[INFO ][             ffmpeg_init_demuxer][ 502]: [0] url input.mp4: codec 96, 1280x688, fps 30
[INFO ][                            main][ 116]: init sys
[INFO ][                            main][ 125]: init vdec
[INFO ][                            main][ 139]: start decoder 0
[INFO ][sample_get_vdec_attr_from_stream_info][ 252]: stream info: 1280x688 payload 96 fps 30
[INFO ][ sample_get_decoded_image_thread][ 311]: [decoder  0] decode thread +++
[INFO ][                            main][ 176]: start demuxer 0
[INFO ][          ffmpeg_dispatch_thread][ 189]: [0] +++
[INFO ][             ffmpeg_demux_thread][ 295]: [0] +++
[INFO ][             ffmpeg_demux_thread][ 328]: [0] reach eof
[INFO ][             ffmpeg_demux_thread][ 435]: [0] demuxed    total 281 frames ---
[INFO ][          ffmpeg_dispatch_thread][ 272]: [0] dispatched total 281 frames ---
[WARN ][ sample_get_decoded_image_thread][ 357]: [decoder  0] flow end
[INFO ][ sample_get_decoded_image_thread][ 392]: [decoder  0] total decode 281 frames
[INFO ][ sample_get_decoded_image_thread][ 398]: [decoder  0] dfecode thread ---
[INFO ][                            main][ 197]: stop decoder 0
[INFO ][                            main][ 202]: decoder 0 is eof
[INFO ][                            main][ 227]: stop demuxer 0
[INFO ][                            main][ 235]: deinit vdec
[INFO ][                            main][ 239]: deinit sys
[INFO ][                            main][ 243]: axcl deinit
[INFO ][                            main][ 247]: ============== V3.6.3_20250722020142 sample exited Jul 22 2025 02:31:31 ==============
axcl_sample_venc
Examples of H264, H265, JPEG, and MJPEG Encoders (VENC).
Usage
m5stack@raspberrypi5:~ $ axcl_sample_venc --help
[INFO][SAMPLE-VENC][main][39]: Build at Jul 22 2025 02:31:34
Usage:  axcl_sample_venc [options] -i input file
  -H --help                        help information
## Options for sample
  -i[s] --input                         Read input video sequence from file. [input.yuv]
  -o[s] --output                        Write output HEVC/H.264/jpeg/mjpeg stream to file.[stream.hevc]
  -W[n] --write                         whether write output stream to file.[1]
                                        0: do not write
                                        1: write
  -f[n] --dstFrameRate                  1..1048575 Output picture rate numerator. [30]
  -j[n] --srcFrameRate                  1..1048575 Input picture rate numerator. [30]
  -n[n] --encFrameNum                   the frame number want to encode. [0]
  -N[n] --chnNum                        total encode channel number. [0]
  -t[n] --encThdNum                     total encode thread number. [1]
  -p[n] --bLoopEncode                   enable loop mode to encode. 0: disable. 1: enable. [0]
  --codecType                           encoding payload type. [0]
                                        0 - SAMPLE_CODEC_H264
                                        1 - SAMPLE_CODEC_H265
                                        2 - SAMPLE_CODEC_MJPEG
                                        3 - SAMPLE_CODEC_JPEG
  --bChnCustom                          whether encode all payload type. [0]
                                        0 - encode all payload type
                                        1 - encode payload type codecType specified by codecType.
  --log                                 log info level. [2]
                                        0 : ERR
                                        1 : WARN
                                        2 : INFO
                                        3 : DEBUG
  --devId                               device index from 0 to connected device num - 1. [0]
  --bStrmCached                         output stream use cached memory. [0]
  --bAttachHdr                          support attach headers(sps/pps) to PB frame for h.265. [0]
## Parameters affecting input frame and encoded frame resolutions and cropping:
  -w[n] --picW                          Width of input image in pixels.
  -h[n] --picH                          Height of input image in pixels.
  -X[n] --cropX                         image horizontal cropping offset, must be even. [0]
  -Y[n] --cropY                         image vertical cropping offset, must be even. [0]
  -x[n] --cropW                         Height of encoded image
  -y[n] --cropH                         Width of encoded image
  --maxPicW                             max width of input image in pixels.
  --maxPicH                             max height of input image in pixels.
  --bCrop                               enable crop encode, 0: disable 1: enable crop. [0]
## Parameters picture stride:
  --strideY                             y stride
  --strideU                             u stride
  --strideV                             v stride
## Parameters  for pre-processing frames before encoding:
  -l[n] --picFormat                     Input YUV format. [1]
                                        1 - AX_FORMAT_YUV420_PLANAR (IYUV/I420)
                                        3 - AX_FORMAT_YUV420_SEMIPLANAR (NV12)
                                        4 - AX_FORMAT_YUV420_SEMIPLANAR_VU (NV21)
                                        13 - AX_FORMAT_YUV422_INTERLEAVED_YUYV (YUYV/YUY2)
                                        14 - AX_FORMAT_YUV422_INTERLEAVED_UYVY (UYVY/Y422)
                                        37 - AX_FORMAT_YUV420_PLANAR_10BIT_I010
                                        42 - AX_FORMAT_YUV420_SEMIPLANAR_10BIT_P010
## Parameters  affecting GOP pattern, rate control and output stream bitrate:
  -g[n] --gopLen                        Intra-picture rate in frames. [30]
                                        Forces every Nth frame to be encoded as intra frame.
                                        0 = Do not force
  -B[n] --bitRate                       target bitrate for rate control, in kbps. [2000]
  --ltMaxBt                             the long-term target max bitrate.
  --ltMinBt                             the long-term target min bitrate.
  --ltStaTime                           the long-term rate statistic time.
  --shtStaTime                          the short-term rate statistic time.
  --minQpDelta                          Difference between FrameLevelMinQp and MinQp
  --maxQpDelta                          Difference between FrameLevelMaxQp and MaxQp
## Parameters  qp:
  -q[n] --qFactor                       0..99, Initial target QP of jenc. [90]
  -b[n] --bDblkEnable                   0: disable Deblock 1: enable Deblock. [0]
  --startQp                             -1..51, start qp for first frame. [16]
  --vq                                  0..9 video quality level for vbr, def 0, min/max qp is invalid when vq != 0
  --minQp                               0..51, Minimum frame header qp for any picture. [16]
  --maxQp                               0..51, Maximum frame header qp for any picture. [51]
  --minIqp                              0..51, Minimum frame header qp for I picture. [16]
  --maxIqp                              0..51, Maximum frame header qp for I picture. [51]
  --chgPos                              vbr/avbr chgpos 20-100, def 90
  --stillPercent                        avbr still percent 10-100 def 25
  --stillQp                             0..51, the max QP value of I frame for still scene. [0]
  --deltaQpI                            -51..51, QP adjustment for intra frames. [-2]
  --maxIprop                            1..100, the max I P size ratio. [100]
  --minIprop                            1..maxIprop, the min I P size ratio. [1]
  --IQp                                 0..51, qp of the i frame. [25]
  --PQp                                 0..51, qp of the p frame. [30]
  --BQp                                 0..51, qp of the b frame. [32]
  --fixedQp                             -1..51, Fixed qp for every frame(only for Mjpeg)
                                          -1 : disable fixed qp mode.
                                          [0, 51] : value of fixed qp.
  --ctbRcMode                           0: diable ctbRc; 1: quality first; 2: bitrate first 3: quality and bitrate balance
  --qpMapQpType                         0: disable qpmap; 1: deltaQp; 2: absQp
  --qpMapBlkUnit                        0: 64x64, 1: 32x32, 2: 16x16;
  --qpMapBlkType                        0: disable; 1: skip mode; 2: Ipcm mode
  -r[n] --rcMode                        0: CBR 1: VBR 2: AVBR 3: QPMAP 4:FIXQP 5:CVBR. [0]
  -M[n] --gopMode                       gopmode. 0: normalP. 1: oneLTR. 2: svc-t. [0]
## other:
  --vbCnt                               total frame buffer number of pool [1, 100]. [10]
  --inFifoDep                           input fifo depth. [4]
  --outFifoDep                          output fifo depth. [4]
  --syncSend                            send frame mode. -1: block mode, >=0:non-block, in ms.
  --syncGet                             get stream mode. -1: block mode, >=0:non-block, in ms.
  --bLinkMode
  --strmBitDep                          encode stream bit depth. [8]
                                         8 : encode 8bit
                                         10: encode 10bit
  --strmBufSize                         output stream buffer size. [0]
                                        0: use default memory setting in sdk.
                                        >0:alloc some memory by user.
  --virILen                             virtual I frame duration. should less than gop length.
Example 1
Enable two channels to encode 1080p NV12 format (Channel 0: H.264, Channel 1: H.265)
$ axcl_sample_venc -w 1920 -h 1080 -i 1080p_nv12.yuv -N 2 -l 3
Example 2
Enable two channels to cyclically encode 3840x2160 NV21 format (Channel 0: H.264, Channel 1: H.265), encode 10 frames
$ axcl_sample_venc -w 3840 -h 2160 -i 3840x2160_nv21.yuv -N 2 -l 4 -n 10
Example 3
Encode an MJPEG stream, resolution 1920x1080, YUV420P format, encode 5 frames
$ axcl_sample_venc -w 1920 -h 1080 -i 1920x1080_yuv420p.yuv -N 1 --bChnCustom 1 --codecType 2 -l 1 -n 5
axcl_sample_dmadim
DMA example, including:
Perform memory copy (memcpy) between two device memories via AXCL_DMA_MemCopy
Set device memory to 0xAB (memset) via AXCL_DMA_MemCopy
Calculate checksum via AXCL_DMA_CheckSum
Crop 1/4 of an image starting from (0, 0) via AXCL_DMA_MemCopyXD (AX_DMADIM_2D)
Usage
usage: ./axcl_sample_dmadim --image=string --width=unsigned int --height=unsigned int [options] ...
options:
  -i, --image     nv12 image file path (string)
  -w, --width     width of nv12 image (unsigned int)
  -h, --height    height of nv12 image (unsigned int)
-i, --image NA Input image file path
-w, --width NA Width of the input image
-h, --height NA Height of the input image
Example
$ axcl_sample_dmadim -i 1920x1080.nv12.yuv -w 1920 -h 1080 -d 0
[INFO ][                            main][  30]: ============== V3.5.0_20250515190238 sample started May 15 2025 19:29:17 ==============
[INFO ][                            main][  46]: json: ./axcl.json
json file
[INFO ][                            main][  66]: device index: 0, bus number: 3
[INFO ][                        dma_copy][ 119]: dma copy device memory succeed, from 0x14926f000 to 0x14966f000
[INFO ][                      dma_memset][ 139]: dma memset device memory succeed, 0x14926f000 to 0xab
[INFO ][                    dma_checksum][ 166]: dma checksum succeed, checksum = 0xaaa00000
[INFO ][                      dma_copy2d][ 281]: [0] dma memcpy 2D succeed
[INFO ][                      dma_copy2d][ 281]: [1] dma memcpy 2D succeed
[INFO ][                      dma_copy2d][ 308]: ./dma2d_output_image_960x540.nv12 is saved
[INFO ][                      dma_copy2d][ 328]: dma copy2d nv12 image pass
[INFO ][                            main][  82]: ============== V3.5.0_20250515190238 sample exited May 15 2025 19:29:17 ==============
axcl_sample_ive
Example of Intelligent Video Engine (IVE).
Note:
  • The sample code is for API demonstration purposes only, but in practice you need to use specific configuration parameters according to your application context.
  • For parameter limitations, please refer to the document titled 42 - AX IVE API.
  • The memory for filling input and output data must be allocated by the user.
  • The input and output image data must be specified by the user.
  • The number of input images (or data) from different CV modules may vary.
  • The data type of the 2D image must be explicitly defined, or use the default value.
  • These key parameters are formatted as a JSON string or JSON file. Please refer to the .json files and code in certain directories under /opt/data/ive/.
Usage
m5stack@raspberrypi5:~ $ axcl_sample_ive --help
Usage : axcl_sample_ive -c case_index [options]
        -d | --device_id: Device index from 0 to connected device num - 1, optional
        -c | --case_index:Calc case index, default:0
                0-DMA.
                1-DualPicCalc.
                2-HysEdge and CannyEdge.
                3-CCL.
                4-Erode and Dilate.
                5-Filter.
                6-Hist and EqualizeHist.
                7-Integ.
                8-MagAng.
                9-Sobel.
                10-GMM and GMM2.
                11-Thresh.
                12-16bit to 8bit.
                13-Multi Calc.
                14-Crop and Resize.
                15-CSC.
                16-CropResize2.
                17-MatMul.
        -e | --engine_choice:Choose engine id, default:0
                0-IVE; 1-TDP; 2-VGP; 3-VPP; 4-GDC; 5-DSP; 6-NPU; 7-CPU; 8-MAU.
                For Crop and Resize case, cropimage support IVE/VGP/VPP engine, cropresize and cropresize_split_yuv support VGP/VPP engine.
                For CSC case, support TDP/VGP/VPP engine.
                For CropResize2 case, support VGP/VPP engine.
                For MatMul case, support NPU/MAU engine.
        -m | --mode_choice:Choose test mode, default:0
                For DualPicCalc case, indicate dual pictures calculation task:
                  0-add; 1-sub; 2-and; 3-or; 4-xor; 5-mse.
                For HysEdge and CannyEdge case, indicate hys edge or canny edge calculation task:
                  0-hys edge; 1-canny edge.
                For Erode and Dilate case, indicate erode or dilate calculation task:
                  0-erode; 1-dilate.
                For Hist and EqualizeHist case, indicate hist or equalize hist calculation task:
                  0-hist; 1-equalize hist.
                For GMM and GMM2 case, indicate gmm or gmm2 calculation task:
                  0-gmm; 1-gmm2.
                For Crop and Resize case, indicate cropimage, cropresize, cropresize_split_yuv calculation task:
                  0-crop image; 1-crop_resize; 2-cropresize_split_yuv.
                For CropResize2 case, indicate crop_resize2 or cropresize2_split_yuv calculation task:
                  0-crop_resize2; 1-cropresize2_split_yuv.
        -t | --type_image:Image type index refer to IVE_IMAGE_TYPE_E(IVE engine) or AX_IMG_FORMAT_E(other engine)
                Note:
                  1. For all case, both input and output image types need to be specified in the same order as the specified input and output file order.
                  2. If no type is specified, i.e. a type value of -1 is passed in, then a legal type is specified, as qualified by the API documentation.
                  3. Multiple input and output image types, separated by spaces.
                  4. For One-dimensional data (such as AX_IVE_MEM_INFO_T type data), do not require a type to be specified.
        -i | --input_files:Input image files, if there are multiple inputs, separated by spaces.
        -o | --output_files:Output image files or dir, if there are multiple outputs, separated by spaces
                Note:for DMA, Crop Resize, blob of CCL case and CropResize2 case must be specified as directory.
        -w | --width:Image width of inputs, default:1280.
        -h | --height:Image height of inputs, default:720.
        -p | --param_list:Control parameters list or file(in json data format)
                Note:
                  1. Please refer to the json file in the '/opt/data/ive/' corresponding directory of each test case.
                  2. For MagAng, Multi Calc and CSC case, no need control parameters.
        -a | --align_need:Does the width/height/stride need to be aligned automatically, default:0.
                  0-no; 1-yes.
        -? | --help:Show usage help.
Example 1
DMA usage (Source resolution: 1280 x 720, Input / Output type: U8C1, Control parameters configured using JSON file)
$ axcl_sample_ive -c 0 -w 1280 -h 720 -i /opt/data/ive/common/1280x720_u8c1_gray.yuv -o /opt/data/ive/dma/ -t 0 0 -p /opt/data/ive/dma/dma.json
Example 2
MagAndAng usage (Source resolution: 1280 x 720, Data type of input parameters (grad_h, grad_v): U16C1, Data type of output parameter (ang_output): U8C1)
$ axcl_sample_ive -c 8 -w 1280 -h 720 -i /opt/data/ive/common/1280x720_u16c1_gray.yuv /opt/data/ive/common/1280x720_u16c1_gray_2.yuv -o /opt/data/ive/common/mag_output.bin /opt/data/ive/common/ang_output.bin -t 9 9 9 0
json
  1. dma.json
    • mode, x0, y0, h_seg, v_seg, elem_size and set_val are the value of respective member in structure AX_IVE_DMA_CTRL_T such as enMode, u16CrpX0, u16CrpY0, u8HorSegSize, u8VerSegRows, u8ElemSize, u64Val.
    • w_out and h_out is respectivly the width and height of output image, only for AX_IVE_DMA_MODE_DIRECT_COPY mode in DMA.
  2. dualpics.json
    • x and y are the value of u1q7X and u1q7Y in structure AX_IVE_ADD_CTRL_T for ADD CV.
    • mode is the value of enMode in structure AX_IVE_SUB_CTRL_T for Sub CV.
    • mse_coef is the value of u1q15MseCoef in structure AX_IVE_MSE_CTRL_T for MSE CV.
  3. ccl.json
    • mode is the value of enMode of structure AX_IVE_CCL_CTRL_T for CCL CV.
  4. ed.json
    • mask is all values of au8Mask[25] in structure AX_IVE_ERODE_CTRL_T for Erode CV or AX_IVE_DILATE_CTRL_T for Dilate CV.
  5. filter.json
    • mask is all values of as6q10Mask[25] in structure AX_IVE_FILTER_CTRL_T for Filter CV.
  6. hist.json
    • histeq_coef is the value of u0q20HistEqualCoef in structure AX_IVE_EQUALIZE_HIST_CTRL_T for EqualizeHist CV.
  7. integ.json
    • out_ctl is the value of enOutCtrl in structure AX_IVE_INTEG_CTRL_T for Integ CV.
  8. sobel.json
    • mask is the value of as6q10Mask[25] in structure AX_IVE_SOBEL_CTRL_T for Sobel CV.
  9. gmm.json
    • init_var, min_var, init_w, lr, bg_r, var_thr and thr are respectivly the value of u14q4InitVar, u14q4MinVar, u1q10InitWeight, u1q7LearnRate, u1q7BgRatio, u4q4VarThr and u8Thr in structure AX_IVE_GMM_CTRL_T for GMM CV.
  10. gmm2.json:
    • init_var, min_var, max_var, lr, bg_r, var_thr, var_thr_chk, ct and thr are respectivly the value of u14q4InitVar, u14q4MinVar, u14q4MaxVar, u1q7LearnRate, u1q7BgRatio, u4q4VarThr, u4q4VarThrCheck, s1q7CT and u8Thr in structure AX_IVE_GMM2_CTRL_T for GMM2 CV.
  11. thresh.json
    • mode, thr_l, thr_h, min_val, mid_val and max_val are repectivly the value of enMode, u8LowThr, u8HighThr, u8MinVal, u8MidVal and u8MaxVal in structure AX_IVE_THRESH_CTRL_T for Thresh CV.
  12. 16bit_8bit.json
    • mode, gain and bias are repectivly the value of enMode, s1q14Gain and s16Bias in structure AX_IVE_16BIT_TO_8BIT_CTRL_T for 16BitTo8Bit CV.
  13. crop_resize.json
    • When CropImage is enabled, num is the value of u16Num in structure AX_IVE_CROP_IMAGE_CTRL_T and boxs is the array type of crop image in which x,y,w and h are respecivly the value of u16X, u16Y, u16Width and u16Height in structure AX_IVE_RECT_U16_T.
    • When CropResize or CropResizeForSplitYUV mode is enabled, num is the value of u16Num in structure AX_IVE_CROP_RESIZE_CTRL_T and align0, align1, enAlign[1], bcolor, w_out and h_out are respectivly the value of enAlign[0], enAlign[1], u32BorderColor, width and height of output image.
  14. crop_resize2.json
    • num is the value of u16Num in structure AX_IVE_CROP_IMAGE_CTRL_T.
    • res_out is the arrayes of width and height of output image.
    • src_boxs is the array of cropped range from source image, dst_boxs is the array of range to resized image.
  15. matmul.json
    • mau_i, ddr_rdw, en_mul_res, en_topn_res, order and topn are respectivly the value of enMauId, s32DdrReadBandwidthLimit, bEnableMulRes, bEnableTopNRes, enOrder and s32TopN in structure AX_IVE_MAU_MATMUL_CTRL_T.
    • type_in is the value of stMatQ and stMatB in structure AX_IVE_MAU_MATMUL_INPUT_T.
    • type_mul_res and type_topn_res are the value of stMulRes and sfTopNRes in structure AX_IVE_MAU_MATMUL_OUTPUT_T.
    • q_shape and b_shape are the value of pShape in stMatQ and stMatB of structure AX_IVE_MAU_MATMUL_INPUT_T
axcl_sample_ivps
Example of Image and Video Processing System (IVPS), providing functions such as cropping, scaling, rotation, streaming, CSC, OSD, mosaic, and quadrilateral operations.
Usage
m5stack@raspberrypi5:~ $ axcl_sample_ivps -h
AXCL IVPS Sample. Build at Jul 22 2025 02:31:34
axcl_sample_ivps: option requires an argument -- 'h'
INFO   :[IVPS_ArgsParser:698] pipeline_ini: (null)
INFO   :[IVPS_ArgsParser:699] region_ini: (null)
Usage: /axcl_sample_ivps
        -d             (required) : device index from 0 to connected device num - 1
        -v             (required) : video frame input
        -g             (optional) : overlay input
        -s             (optional) : sp alpha input
        -n             (optional) : repeat number
        -r             (optional) : region config and update
        -l             (optional) : 0: no link 1. link ivps. 2: link venc. 3: link jenc
        --pipeline     (optional) : import ini file to config all the filters in one pipeline
        --pipeline_ext (optional) : import ini file to config all the filters in another pipeline
        --change       (optional) : import ini file to change parameters for one filter dynamicly
        --region       (optional) : import ini file to config region parameters
        --dewarp       (optional) : import ini file to config dewarp parameters, including LDC, perspective, fisheye, etc.
        --cmmcopy      (optional) : cmm copy API test
        --csc          (optional) : color space covert API test
        --fliprotation (optional) : flip and rotation API test
        --alphablend   (optional) : alpha blending API test
        --cropresize   (optional) : crop resize API test
        --osd          (optional) : draw osd API test
        --cover        (optional) : draw line/polygon API test
        -a             (optional) : all the sync API test
        --json         (optional) : axcl.json path
            -v  <PicPath>@<Format>@<Stride>x<Height>@<CropW>x<CropH>[+<CropX0>+<CropY0>]>
           e.g: -v /opt/bin/data/ivps/800x480car.nv12@3@800x480@600x400+100+50
           [-g] <PicPath>@<Format>@<Stride>x<Height>[+<DstX0>+<DstY0>*<Alpha>]>
           e.g: -g /opt/bin/data/ivps/rgb400x240.rgb24@161@400x240+100+50*150
           [-n] <repeat num>]
           [-r] <region num>]
        <PicPath>                     : source picture path
        <Format>                      : picture color format
                   3: NV12     YYYY... UVUVUV...
                   4: NV21     YYYY... VUVUVU...
                  10: NV16     YYYY... UVUVUV...
                  11: NV61     YYYY... VUVUVU...
                 161: RGB888   24bpp
                 165: BGR888   24bpp
                 160: RGB565   16bpp
                 197: ARGB4444 16bpp
                 203: RGBA4444 16bpp
                 199: ARGB8888 32bpp
                 201: RGBA8888 32bpp
                 198: ARGB1555 16bpp
                 202: RGBA5551 16bpp
                 200: ARGB8565 24bpp
                 204: RGBA5658 24bpp
                 205: ABGR4444 16bpp
                 211: BGRA4444 16bpp
                 207: ABGR8888 32bpp
                 209: BGRA8888 32bpp
                 206: ABGR1555 16bpp
                 210: BGRA5551 16bpp
                 208: ABGR8565 24bpp
                 212: BGRA5658 24bpp
                 224: BITMAP    1bpp
        <Stride>           (required) : picture stride (16 bytes aligned)
        <Stride>x<Height>  (required) : input frame stride and height (2 aligned)
        <CropW>x<CropH>    (required) : crop rect width & height (2 aligned)
        +<CropX0>+<CropY0> (optional) : crop rect coordinates
        +<DstX0>+<DstY0>   (optional) : output position coordinates
        <Alpha>            (optional) : ( (0, 255], 0: transparent; 255: opaque)
Example1:
        /axcl_sample_ivps -d 0 -v /opt/data/ivps/1920x1088.nv12@3@1920x1088@1920x1088  -n 1
Note:
  • -v is a required option with the input source image path and frame information.
    The cropping window should be within the height range of the source image, i.e., CropX0 + CropW <= Stride, CropY0 + CropH <= Height.
    If no cropping is performed, then CropW = Width, CropH = Height, CropX0 = 0, and CropY0 = 0.
  • -n specifies the number of times to process the source image. If the parameter is -1, it will loop indefinitely.
    To view the proc information of IVPS, set the processing count to a large value or keep it looping.
  • The input parameter after -r is the number of overlaid REGIONs, with the current maximum being 4.
    Overlaying REGION on the IVPS PIPELINE is an asynchronous operation, so it takes several frames to actually overlay onto the input source image.
    Therefore, to verify the REGION function, set the parameter after -n to be larger than 3. The value should be greater than 3.2.
Example 1
Process a source image (3840x2160 NV12 format) once
$ axcl_sample_ivps -v /opt/data/ivps/3840x2160.nv12@3@3840x2160@0x0+0+0 -d 0 -n 1
Example 2
Process a source image (800x480 RGB 888 format) with cropping (X0=128 Y0=50 W=400 H=200), process three times
$ axcl_sample_ivps -v /opt/data/ivps/800x480logo.rgb24@161@800x480@400x200+128+50 -d 0 -n 3
Example 3
Process a source image (3840x2160 NV12 format) five times and overlay three REGIONs
$ axcl_sample_ivps -v /opt/data/ivps/3840x2160.nv12@3@3840x2160@0x0+0+0 -d 0 -n 5 -r 3
axcl_sample_transcode
Example of transcoding. The pipeline (PPL) is as follows:
  2. Demux nalu via ffmpeg
  3. Send nalu frames to VDEC
  4. VDEC sends the decoded nv12 to IVPS (if resizing)
  5. IVPS sends the nv12 to VENC
  6. Send the encoded nalu frames to the host via VENC.
deployment
| sample                        |
| libaxcl_ppl.so                |
| libaxcl_lite.so               |
| AXCL SDK                      |
attributes
        attribute name                       R/W    attribute value type
 *  axcl.ppl.transcode.vdec.grp             [R  ]       int32_t                            allocated by ax_vdec.ko
 *  axcl.ppl.transcode.ivps.grp             [R  ]       int32_t                            allocated by ax_ivps.ko
 *  axcl.ppl.transcode.venc.chn             [R  ]       int32_t                            allocated by ax_venc.ko
 *  the following attributes take effect BEFORE the axcl_ppl_create function is called:
 *  axcl.ppl.transcode.vdec.blk.cnt         [R/W]       uint32_t          8                depend on stream DPB size and decode mode
 *  axcl.ppl.transcode.vdec.out.depth       [R/W]       uint32_t          4                out fifo depth
 *  axcl.ppl.transcode.ivps.in.depth        [R/W]       uint32_t          4                in fifo depth
 *  axcl.ppl.transcode.ivps.out.depth       [R  ]       uint32_t          0                out fifo depth
 *  axcl.ppl.transcode.ivps.blk.cnt         [R/W]       uint32_t          4
 *  axcl.ppl.transcode.ivps.engine          [R/W]       uint32_t   AX_IVPS_ENGINE_VPP      AX_IVPS_ENGINE_VPP|AX_IVPS_ENGINE_VGP|AX_IVPS_ENGINE_TDP
 *  axcl.ppl.transcode.venc.in.depth        [R/W]       uint32_t          4                in fifo depth
 *  axcl.ppl.transcode.venc.out.depth       [R/W]       uint32_t          4                out fifo depth
NOTE:
 The value of "axcl.ppl.transcode.vdec.blk.cnt" depends on input stream.
 Usually set to dpb + 1
Usage
$ axcl_sample_transcode --help
usage: axcl_sample_transcode --url=string [options] ...
options:
  -w, --width     output width, 0 means same as input (unsigned int [=0])
  -h, --height    output height, 0 means same as input (unsigned int [=0])
      --codec     encoded codec: [h264 | h265] (default: h265) (string [=h265])
      --loop      1: loop demux for local file  0: no loop(default) (int [=0])
      --dump      dump file path (string [=])
      --hwclk     decoder hw clk, 0: 624M, 1: 500M, 2: 400M(default) (unsigned int [=2])
      --ut        unittest
--codec h265 Specify the payload type.
--loop 0 1: Loop transcode until CTRL+C, 0: Do not loop.
--dump Specify the path to dump the file.
--hwclk 2 (400M) Set the clock of the VDEC in MHz.
--ut Internal use
m5stack@raspberrypi5:~ $ axcl_sample_transcode --help
axcl_sample_transcode: error while loading shared libraries: libavcodec.so.61: cannot open shared object file: No such file or directory
m5stack@raspberrypi5:~ $ export LD_LIBRARY_PATH=/usr/lib/axcl/ffmpeg:$LD_LIBRARY_PATH
Please first set the environment variable via
Example
Transcode the input 1080P@30fps 264 to 1080P@30fps 265 and save it to the /tmp/axcl/transcode.dump.pidxxx file.
$ axcl_sample_transcode -i bangkok_30952_1920x1080_30fps_gop60_4Mbps.mp4 -d 0 --dump /tmp/axcl/transcode.265
[INFO ][                            main][  67]: ============== V3.5.0_20250515190238 sample started May 15 2025 19:29:29 pid 91189 ==============
[WARN ][                            main][  92]: if enable dump, disable loop automatically
json file
[INFO ][                            main][ 131]: pid: 91189, device index: 0, bus number: 3
[INFO ][             ffmpeg_init_demuxer][ 439]: [91189] url: bangkok_30952_1920x1080_30fps_gop60_4Mbps.mp4
[INFO ][             ffmpeg_init_demuxer][ 502]: [91189] url bangkok_30952_1920x1080_30fps_gop60_4Mbps.mp4: codec 96, 1920x1080, fps 30
[INFO ][         ffmpeg_set_demuxer_attr][ 571]: [91189] set ffmpeg.demux.file.frc to 1
[INFO ][         ffmpeg_set_demuxer_attr][ 574]: [91189] set ffmpeg.demux.file.loop to 0
[INFO ][                            main][ 195]: pid 91189: [vdec 00] - [ivps -1] - [venc 00]
[INFO ][                            main][ 213]: pid 91189: VDEC attr ==> blk cnt: 8, fifo depth: out 4
[INFO ][                            main][ 214]: pid 91189: IVPS attr ==> blk cnt: 5, fifo depth: in 4, out 0, engine 1
[INFO ][                            main][ 216]: pid 91189: VENC attr ==> fifo depth: in 4, out 4
[INFO ][          ffmpeg_dispatch_thread][ 189]: [91189] +++
[INFO ][             ffmpeg_demux_thread][ 295]: [91189] +++
[INFO ][             ffmpeg_demux_thread][ 328]: [91189] reach eof
[INFO ][             ffmpeg_demux_thread][ 435]: [91189] demuxed    total 470 frames ---
[INFO ][          ffmpeg_dispatch_thread][ 272]: [91189] dispatched total 470 frames ---
[INFO ][                            main][ 247]: ffmpeg (pid 91189) demux eof
[2025-05-20 22:49:08.834][91195][W][axclite-venc-dispatch][dispatch_thread][44]: no stream in veChn 0 fifo
[INFO ][                            main][ 283]: total transcoded frames: 470
[INFO ][                            main][ 284]: ============== V3.5.0_20250515190238 sample exited May 15 2025 19:29:29 pid 91189 ==============
launch_transcode.sh supports starting multiple (up to 16) axcl_sample_transcode processes and automatically configuring LD_LIBRARY_PATH.
$ ./launch_transcode.sh 16 -i bangkok_30952_1920x1080_30fps_gop60_4Mbps.mp4  -d 3 --dump /tmp/axcl/transcode.265
The first parameter must be the number of axcl_sample_transcode processes. Range: [1, 16]
