Input & Output Devices
Audio Playback Devices
Air Quality / Air Quality v1.1 User Guide
Product Introduction
Air Quality / Air Quality v1.1 is an integrated low-power air quality monitoring device with a built-in multifunctional air quality sensor SEN55 and CO2 sensor SCD40. It can monitor PM1.0, PM2.5, PM4, PM10 particulate matter, temperature, humidity, VOC, and CO2 concentrations in the air, making it suitable for long-term online monitoring of air environments in homes, schools, industries, and hospitals.
About Device Power Supply
This product is powered by a built-in battery and supports low-power timed wake-up. It also supports external USB power, allowing it to keep operating without entering sleep mode so the sensors can work continuously and ensure data collection accuracy.
Learn
Power On/Off and Reset
  • Power On: Long press the Power Button.
  • Reset and Power Off:
    • When powered via USB, pressing Reset and Power Off will reset the device.
    • When powered by battery, pressing Reset and Power Off will turn off the device.
    • When powered via USB, the device cannot be turned off.
Button Operation
  • Single click Button A to enter the remote QR code page:
    • Single click Button A to return to the previous page
  • Single click Button B to enter the deployment page:
    • Single click Button A to return to the previous menu
    • Long press Button A for 5s to turn the buzzer on/off
    • Single click Button B to enable AP configuration
    • Long press Button B for 5s to restore factory settings
Set Up Remote Access
  1. Single click the power button to turn on the device, or use USB power.
  1. Press Button B to enter AP configuration mode. The screen will display the AP hotspot name and QR code for connection.
  1. Connect your phone to the AP hotspot AirQ-xxxxxx. After connecting, the screen will display the configuration QR code and IP address.
  1. Scan the configuration QR code on the device screen, or manually visit 192.168.4.1 to access the Wi-Fi configuration page. Configure the Wi-Fi, timezone, wake-up interval, and other information for the device, then click CONNECT.
The screen will now display the public access address for retrieving device data.
  1. Copy this address into your computer or mobile browser to remotely access the device's data reading page and get real-time data collection information.
(Note: The Data Share Link shown above is the raw data interface. For detailed data format information, refer to Raw Data Format.)
If the device is restarted, press Button B to enter the settings menu, then press Button B again to re-enter AP configuration mode.
Restore Factory Settings
Restoring factory settings will erase all custom configurations.
  1. With the device powered on, press Button B to enter the settings menu.
  1. Long press Button B for 5s. The device will restore factory settings and restart.
Video Introduction
